03-31-2019, 19:28 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | 1ST WORLD SUPER TAB S7G (MTK CPU) REPAIRED DONE BY CHANGING NEW eMMC NAND 1ST WORLD SUPER TAB S7G (MTK CPU) REPAIRED DONE BY CHANGING NEW eMMC NAND WITH THE GREATEST OCTOPLUS BOX & ISP DIRECT LOG OLD eMMC (DAMAGED) : Code: Welcome to Octoplus Pro JTAG Software version 1.7.6. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: FT SCR2000 2 Reader #3: Generic Usb Smart Card Reader 0 Reader #4: Generic Usb Smart Card Reader 1 Reader #5: Generic Usb Smart Card Reader 2 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG2WA Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D4147325741015D0546FBBF29 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG2WA Product revision : 0.1 Product serial number : (hex) 5D0546FB Manufacturing date : 11/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 5087232 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2WA_31_03_2019_15_04_14.bin. Connect successful. --------------------------------------------------------------- LOG NEW eMMC (RECORVED FROM CONDOR TAB 901) Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG2GA Page size : 512 B Block size : 512 B Block count : 30502912 Size : 14.54 GB (14894.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D41473247410647CF4D4E905D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG2GA Full name : KLMAG2GE2A-A001 Product revision : 0.6 Product serial number : (hex) 47CF4D4E Manufacturing date : 09/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x06) 00000110 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x2 Part setting completed: 0x1 GP partition 1 size : 8 MB GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a2e00000 bytes Device sector size : 512 bytes Partition offset : 3039272 Number of sectors : 2097152 Device Manufacturer :TRA-901G Device Platform :clovertrail Build ID :TRA-901G Display Build ID :Condor_TRA-901G_20140528 Release ID :4.2.2 Device Model :TRA-901G Device Name :Condor_Electronics Architecture ABI :x86 Architecture ABI2 :armeabi-v7a Build Description :redhookbay-userdebug 4.2.2 TRA-901G eng.softteam.20140528.123111 test-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_31_03_2019_15_39_23.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: reserved (00000028, 00052000) 164 MB P02: panic (00052028, 00004000) 8 MB P03: factory (00056028, 00010000) 32 MB P04: misc (00066028, 00040000) 128 MB P05: config (000A6028, 00040000) 128 MB P06: cache (000E6028, 00180000) 768 MB P07: logs (00266028, 00080000) 256 MB P08: system (002E6028, 00200000) 1024 MB P09: data (004E6028, 0182CFD8) 12.09 GB LOG FORMAT THE eMMC Code: Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 1.7.6; FW: 1.24. Disconnected. LOG WRITE BOOT1, BOOT2, EXT-CSD FROM WORKED SUPER TAB S7G TO NEW eMMC Code: Writing EXT_CSD succesfully complete! Disconnected. Code: Switched to boot area partition 1. Opening C:/Users/STARKRIMES/Desktop/S7G MTK/(BOOT1_SUPER TAB_S7G_MTK) Samsung eMMC MAG2WA.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 1.7.6; FW: 1.24. Switched to boot area partition 2. Opening C:/Users/STARKRIMES/Desktop/S7G MTK/(BOOT2_SUPER TAB_S7G_MTK) Samsung eMMC MAG2WA.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 1.7.6; FW: 1.24. LOG CHANGING CID & CSD Code: Changing CID to 1501004D4147325741015D0546FBBF29. Write CID succesfully completed. Disconnected. LOG AFTER CHANGE NEW eMMC INFO WITH OLD ONE Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG2WA Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D4147325741015D0546FBBF29 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG2WA Product revision : 0.1 Product serial number : (hex) 5D0546FB Manufacturing date : 11/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2WA_31_03_2019_15_56_43.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. LOG OF WRITING DUMP & FRESH FLASH TO NEW eMMC Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG2WA Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D4147325741015D0546FBBF29 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG2WA Product revision : 0.1 Product serial number : (hex) 5D0546FB Manufacturing date : 11/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 5087232 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2WA_31_03_2019_17_57_35.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. --------------------------------------------------------------- Selected scatter file: C:/Program Files (x86)/SarasSoft/UFS/UFS_SAMs/MT6582/BACKUP/MT6582_643AD5A811E9/MT6582_Scatter_MT6582_643AD5A811E9_newway82_tb_n_kk.txt. Scatter file type 2. Opened input file: C:/Program Files (x86)/SarasSoft/UFS/UFS_SAMs/MT6582/BACKUP/MT6582_643AD5A811E9/preloader_newway82_tb_n_kk.bin No eMMC descriptions found. Writing. Please wait... Write data verification is enabled. Writing partition PRELOADER... Write data verification is enabled. Done. Writing partition MBR... Done. Writing partition EBR1... Done. Writing partition PRO_INFO... Done. Writing partition NVRAM... Done. Writing partition PROTECT_F... Done. Writing partition PROTECT_S... Done. Writing partition SECCFG... Done. Writing partition UBOOT... Done. Writing partition BOOTIMG... Done. Writing partition RECOVERY... Done. Writing partition SEC_RO... Done. Writing partition MISC... Done. Writing partition LOGO... Done. Writing partition EBR2... Done. Writing partition EXPDB... Done. Writing partition ANDROID... Done. Writing partition CACHE... Done. Writing partition USRDATA... Done. Writing partition FAT... Done. Writing partition BMTPOOL... Done. Writing checksums...Done. Writing finished. SW: 1.7.6; FW: 1.24. --------------------------------------------------------------- p, li { white-space: pre-wrap; } Selected scatter file: C:/Users/STARKRIMES/Desktop/MT6582__SuperTab__SuperTab.S7G__SuperTab.S7G__4.4.2__ALPS.KK1.MP1.V2.38/MT6582_Android_scatter.txt. Scatter file type 2. Opened input file: C:/Users/STARKRIMES/Desktop/MT6582__SuperTab__SuperTab.S7G__SuperTab.S7G__4.4.2__ALPS.KK1.MP1.V2.38/preloader_newway82_tb_n_kk.bin Writing. Please wait... Write data verification is enabled. Writing partition PRELOADER... Write data verification is enabled. Done. Writing partition MBR... Done. Writing partition EBR1... Done. Writing partition UBOOT... Done. Writing partition BOOTIMG... Done. Writing partition RECOVERY... Done. Writing partition SEC_RO... Done. Writing partition LOGO... Done. Writing partition EBR2... Done. Writing partition ANDROID... Done. Writing partition CACHE... Done. Writing partition USRDATA... Done. Writing checksums...Done. Writing finished. SW: 1.7.6; FW: 1.24. NOTE : I didn't edit eMMC GEOMETRY CAUSE EVERYTHING IS SAME ON TABLE the eMMC'S ARE BGA 169 BALLS CID & CSD OLD eMMC MARKED WITH RED COLOR CID & CSD NEW eMMC MARKED WITH YELLOW COLOR FOR IMEI : ROOT THE TAB AND CHANGE WITH Chamelephon.apk OR USE OTHER BOX |
The Following 2 Users Say Thank You to starkrimes For This Useful Post: |
03-31-2019, 21:50 | #4 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | I dont remember if first Bad emmc have a firmware in medusa pro folder if yes try to write firmware for Samsung eMMC MAG2WA And for final log : Quote:
The Following User Says Thank You to rebainoor For This Useful Post: |
04-01-2019, 09:23 | #6 (permalink) | |
Member: 1191316 Status: Offline Thanks Meter: 900 | Quote:
https://www.datalight.com/solutions/...er-flash-media | |
The Following User Says Thank You to starkrimes For This Useful Post: |
04-14-2019, 22:30 | #8 (permalink) |
Freak Poster Join Date: Dec 2009 Location: pakistan
Member: 1192442 Status: Offline Sonork: 100.1638070 Thanks Meter: 15 | Hi friends i have a Amazon sv98ln tab MTK Cpu dead boot but its detect in USB port i tried to fix with emmc but not responding in medusa pro please can some tell me how do i repair this Tab with medusa pro ? thanks in Advance |
