06-10-2018, 18:25 | #1 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2125922 Status: Offline Sonork: 1601402 Thanks Meter: 112 | Motorola Xt1766 eMMC repair successfully done with Medusa Pro Box Welcome to Medusa Pro Software version 1.6.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4203EE64CE5BA4B1 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.3 Product serial number : (hex) EE64CE5B Manufacturing date : 10/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE63MB_09_06_2018_21_01_06.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.1; FW: 1.23. P00: GPT (00000000, 00000100) 128 KB P01: sbl1 (00000100, 00000400) 512 KB P02: rpm (00000500, 00000200) 256 KB P03: tz (00000900, 00000E00) 1792 KB P04: devcfg (00001900, 00000100) 128 KB P05: aboot (00001B00, 00000C00) 1536 KB P06: cmnlib (00002700, 00000200) 256 KB P07: cmnlib64 (00002900, 00000200) 256 KB P08: keymaster (00002B00, 00000200) 256 KB P09: prov (00002D00, 00000180) 192 KB P10: sbl1bak (00002F00, 00000400) 512 KB P11: rpmbak (00003300, 00000200) 256 KB P12: tzbak (00003700, 00000E00) 1792 KB P13: devcfgbak (00004700, 00000100) 128 KB P14: abootbak (00004900, 00000C00) 1536 KB P15: cmnlibbak (00005500, 00000200) 256 KB P16: cmnlib64bak (00005700, 00000200) 256 KB P17: keymasterbak (00005900, 00000200) 256 KB P18: provbak (00005B00, 00000180) 192 KB P19: modem (00005D00, 00032000) 100 MB P20: fsc (00037D00, 00000002) 1024 b P21: ssd (00037D02, 00000010) 8 KB P22: dsp (00037D12, 00008000) 16 MB P23: DDR (0003FE00, 00000040) 32 KB P24: sec (0003FE40, 00000020) 16 KB P25: utags (0003FF00, 00000400) 512 KB P26: utagsBackup (00040300, 00000400) 512 KB P27: modemst1 (00040700, 00001000) 2048 KB P28: modemst2 (00041700, 00001000) 2048 KB P29: fsg (00042700, 00004000) 8 MB P30: persist (00046700, 00010000) 32 MB P31: frp (00056700, 00000400) 512 KB P32: cid (00056B00, 00000100) 128 KB P33: logo (00056C00, 00008000) 16 MB P34: carrier (0005EC00, 00008000) 16 MB P35: metadata (00066C00, 00000400) 512 KB P36: kpan (00067000, 00004000) 8 MB P37: boot (0006B000, 00008000) 16 MB P38: recovery (00073000, 000080C8) 16.1 MB P39: misc (0007B100, 00000800) 1024 KB P40: limits (0007B900, 00000040) 32 KB P41: mota (0007BA00, 00000400) 512 KB P42: dip (0007BE00, 00000800) 1024 KB P43: syscfg (0007C600, 00000400) 512 KB P44: logs (0007CA00, 00001000) 2048 KB P45: apdp (0007DA00, 00000200) 256 KB P46: msadp (0007DC00, 00000200) 256 KB P47: dpo (0007DE00, 00000010) 8 KB P48: padA (0007DF00, 00002100) 4.125 MB P49: sp (00080000, 00004000) 8 MB P50: hw (00084000, 00004000) 8 MB P51: oem (00088000, 00148000) 656 MB P52: cache (001D0000, 00080000) 256 MB P53: system (00250000, 006C0000) 3456 MB P54: userdata (00910000, 0140EFDF) 10.03 GB Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE63MB_Gpt_0x0_0x100_09_06_2018_21_01_06.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.1; FW: 1.23. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE63MB_Cid_0x56b00_0x100_09_06_2018_21_01_06.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.1; FW: 1.23. Please select file. Selected file: F:/motorola/xt1766/SPERRY_SPRINT_NCQS26.69-64-5_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml/flashfile.xml. File parsing finished. Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Write data verification is enabled. Writing. Please wait... Writing partition sbl1... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition devcfg... Done. Writing partition aboot... Done. Writing partition cmnlib... Done. Writing partition cmnlib64... Done. Writing partition keymaster... Done. Writing partition prov... Done. Writing partition modem... Done. Writing partition dsp... Done. Erasing partition DDR... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Writing partition fsg... Done. Writing partition logo... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition oem... Done. Erasing partition cache... Done. Writing partition system (5 parts): Writing from file F:/motorola/xt1766/SPERRY_SPRINT_NCQS26.69-64-5_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.0 (1/5)... Done Writing from file F:/motorola/xt1766/SPERRY_SPRINT_NCQS26.69-64-5_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.1 (2/5)... Done Writing from file F:/motorola/xt1766/SPERRY_SPRINT_NCQS26.69-64-5_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.2 (3/5)... Done Writing from file F:/motorola/xt1766/SPERRY_SPRINT_NCQS26.69-64-5_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.3 (4/5)... Done Writing from file F:/motorola/xt1766/SPERRY_SPRINT_NCQS26.69-64-5_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.4 (5/5)... Done Writing partition system... Done. Erasing partition userdata... Done. Writing is finished. SW: 1.6.1; FW: 1.23. Last edited by Octopus box; 06-11-2018 at 04:53. |
The Following 4 Users Say Thank You to Bmszone For This Useful Post: |
06-11-2018, 13:12 | #2 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Bro, can U, please, share the picture of pinout and more details, I have 1 on my hands and want to know bro the process. Thanks. Last edited by Octopus box; 06-12-2018 at 04:41. |
