02-09-2019, 00:59 | #3 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2335565 Status: Offline Thanks Meter: 6 | I actually managed to do it , i didn't think i could... i scraped the surface of the line extremely carefull and slow with a razor blade until the copper was visible, added some solder and soldered the jumper there. i was able to connect and read emmc information. and as you can see in this video i started doing a backup of all the partitions, but after some minutes it gives an error and disconnects , same tthing happends if i use smart repair button. the error pops up when writing one of the last (heavier)partitions . but if i retry smart repair right after i got that error. it fails randomly at any of the first partitions. what am i doing wrong? https://www.youtube.com/watch?v=EFJN...ture=********* https://ibb.co/sWwKD9c https://ibb.co/V9hyr3j https://ibb.co/YRmffTD Welcome to Octoplus Pro JTAG Software version 1.7.4. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Motorola Model : XT1922-7 SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/MOTOROLA_XT1922-7_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4203824CACB4450B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.3 Product serial number : (hex) 824CACB4 Manufacturing date : 04/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/QE63MB_06_02_2019_17_53_08.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.4; FW: 1.24. P00: GPT (00000000, 00000100) 128 KB P01: sbl1 (00000100, 00000400) 512 KB P02: rpm (00000500, 00000200) 256 KB P03: tz (00000900, 00000E00) 1792 KB P04: devcfg (00001900, 00000100) 128 KB P05: aboot (00001B00, 00000C00) 1536 KB P06: cmnlib (00002700, 00000800) 1024 KB P07: cmnlib64 (00002F00, 00000800) 1024 KB P08: keymaster (00003700, 00000800) 1024 KB P09: prov (00003F00, 00000180) 192 KB P10: sbl1bak (00004100, 00000400) 512 KB P11: rpmbak (00004500, 00000200) 256 KB P12: tzbak (00004900, 00000E00) 1792 KB P13: devcfgbak (00005900, 00000100) 128 KB P14: abootbak (00005B00, 00000C00) 1536 KB P15: cmnlibbak (00006700, 00000800) 1024 KB P16: cmnlib64bak (00006F00, 00000800) 1024 KB P17: keymasterbak (00007700, 00000800) 1024 KB P18: provbak (00007F00, 00000180) 192 KB P19: modem (00008100, 00032000) 100 MB P20: fsc (0003A100, 00000002) 1024 b P21: ssd (0003A102, 00000010) 8 KB P22: dsp (0003A112, 00008000) 16 MB P23: DDR (00042200, 00000040) 32 KB P24: sec (00042240, 00000020) 16 KB P25: utags (00042300, 00000400) 512 KB P26: utagsBackup (00042700, 00000400) 512 KB P27: modemst1 (00042B00, 00001000) 2048 KB P28: modemst2 (00043B00, 00001000) 2048 KB P29: fsg (00044B00, 00004000) 8 MB P30: persist (00048B00, 00010000) 32 MB P31: frp (00058B00, 00000400) 512 KB P32: cid (00058F00, 00000100) 128 KB P33: logo (00059000, 00008000) 16 MB P34: carrier (00061000, 00008000) 16 MB P35: metadata (00069000, 00000400) 512 KB P36: kpan (00069400, 00004000) 8 MB P37: boot (0006D400, 00008000) 16 MB P38: recovery (00075400, 000080C8) 16.1 MB P39: misc (0007D500, 00000800) 1024 KB P40: limits (0007DD00, 00000040) 32 KB P41: mota (0007DE00, 00000400) 512 KB P42: dip (0007E200, 00000800) 1024 KB P43: syscfg (0007EA00, 00000400) 512 KB P44: logs (0007EE00, 00001000) 2048 KB P45: apdp (0007FE00, 00000200) 256 KB P46: msadp (00080000, 00000200) 256 KB P47: dpo (00080200, 00000010) 8 KB P48: mmi_misc (00080300, 00000100) 128 KB P49: padA (00080400, 00007C00) 15.5 MB P50: sp (00088000, 00004000) 8 MB P51: hw (0008C000, 00004000) 8 MB P52: oem (00090000, 00130000) 608 MB P53: vendor (001C0000, 000C8000) 400 MB P54: cache (00288000, 00080000) 256 MB P55: system (00308000, 004B0000) 2400 MB P56: userdata (007B8000, 01566FDF) 10.7 GB Backuping Gpt partition... Opening C:/Program Files (x86)/Octoplus Pro JTAG Software/Backups/QE63MB_Gpt_0x0_0x100_06_02_2019_17_53_08.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.7.4; FW: 1.24. Backuping Cid partition... Opening C:/Program Files (x86)/Octoplus Pro JTAG Software/Backups/QE63MB_Cid_0x58f00_0x100_06_02_2019_17_53_08.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.7.4; FW: 1.24. Save to C:/Program Files (x86)/Octoplus Pro JTAG Software/Samsung eMMC QE63MB_mié. feb. 6 2019_17_54_01.mpt file...Reading partition GPT... Done. Reading partition sbl1... Done. Reading partition rpm... Done. Reading partition tz... Done. Reading partition devcfg... Done. Reading partition aboot... Done. Reading partition cmnlib... Done. Reading partition cmnlib64... Done. Reading partition keymaster... Done. Reading partition prov... Done. Reading partition sbl1bak... Done. Reading partition rpmbak... Done. Reading partition tzbak... Done. Reading partition devcfgbak... Done. Reading partition abootbak... Done. Reading partition cmnlibbak... Done. Reading partition cmnlib64bak... Done. Reading partition keymasterbak... Done. Reading partition provbak... Done. Reading partition modem... Done. Reading partition fsc... Done. Reading partition ssd... Done. Reading partition dsp... Done. Reading partition DDR... Done. Reading partition sec... Done. Reading partition utags... Done. Reading partition utagsBackup... Done. Reading partition modemst1... Done. Reading partition modemst2... Done. Reading partition fsg... Done. Reading partition persist... Done. Reading partition frp... Done. Reading partition cid... Done. Reading partition logo... Done. Reading partition carrier... Done. Reading partition metadata... Done. Reading partition kpan... Done. Reading partition boot... Done. Reading partition recovery... Done. Reading partition misc... Done. Reading partition limits... Done. Reading partition mota... Done. Reading partition dip... Done. Reading partition syscfg... Done. Reading partition logs... Done. Reading partition apdp... Done. Reading partition msadp... Done. Reading partition dpo... Done. Reading partition mmi_misc... Done. Reading partition padA... Done. Reading partition sp... Done. Reading partition hw... Done. Reading partition oem... Done. Reading partition vendor... Done. Reading partition cache... Done. Reading partition system... Done. Reading partition userdata... ERROR[008]: Data TX error. Attempting to read... Disconnected. |
The Following User Says Thank You to elmy24 For This Useful Post: |
