12-11-2018, 18:21 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | NEW HUAWEI ALE-L21 with DIRECT eMMC PINOUT HUAWEI ALE-L21 : Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files LOG: Code: Welcome to Octoplus Pro JTAG Software version 1.6.9. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: FT SCR2000 2 Reader #3: Generic Usb Smart Card Reader 0 Reader #4: Generic Usb Smart Card Reader 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG2e Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB (15032.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147326505070E16D4EB1323 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG2e Product revision : 0.7 Product serial number : (hex) E16D4EB Manufacturing date : 01/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab800000 bytes Device sector size : 512 bytes Partition offset : 1826816 Number of sectors : 5242880 Device Manufacturer :hi6210sft Device Platform :hi6210sft Build ID :MRA58K Display Build ID :BalongC52B311 Release ID :6.0 Device Model :hi6210sft Device Name :hi6210sft Architecture ABI :arm64-v8a Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi Build Description :hi6210sft-user 6.0 MRA58K eng.jenkins.20170511.184310 test-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG2e_27_11_2018_10_31_51.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: vrl (00000400, 00000200) 256 KB P02: vrl_bkup (00000600, 00000200) 256 KB P03: mcuimage (00000800, 00000200) 256 KB P04: reserved0 (00000A00, 00000600) 768 KB P05: fastboot (00001000, 00002000) 4 MB P06: modemnvbkup (00003000, 00003000) 6 MB P07: nvme (00006000, 00002000) 4 MB P08: oeminfo (00008000, 00010000) 32 MB P09: splash (00018000, 00004000) 8 MB P10: modemnvm1 (0001C000, 00008000) 16 MB P11: modemnvm2 (00024000, 00008000) 16 MB P12: modemnvm3 (0002C000, 00008000) 16 MB P13: securetystorage (00034000, 00010000) 32 MB P14: 3rdmodemnvm (00044000, 00008000) 16 MB P15: 3rdmodemnvmback (0004C000, 00008000) 16 MB P16: reserved1 (00054000, 00006000) 12 MB P17: modemlog (0005A000, 00008000) 16 MB P18: splash2 (00062000, 00020000) 64 MB P19: misc (00082000, 00001000) 2048 KB P20: modemnvreserved (00083000, 0000C000) 24 MB P21: recovery2 (0008F000, 00020000) 64 MB P22: reserved2 (000AF000, 00010000) 32 MB P23: teeos (000BF000, 00002000) 4 MB P24: trustfirmware (000C1000, 00001000) 2048 KB P25: sensorhub (000C2000, 00008000) 16 MB P26: hifi (000CA000, 00006000) 12 MB P27: boot (000D0000, 0000C000) 24 MB P28: recovery (000DC000, 00020000) 64 MB P29: dtimage (000FC000, 00010000) 32 MB P30: modemimage (0010C000, 00020000) 64 MB P31: dsp (0012C000, 00004000) 8 MB P32: dfx (00130000, 00008000) 16 MB P33: 3rdmodem (00138000, 00002000) 4 MB P34: cache (0013A000, 00080000) 256 MB P35: hisitest0 (001BA000, 00001000) 2048 KB P36: hisitest1 (001BB000, 00001000) 2048 KB P37: hisitest2 (001BC000, 00002000) 4 MB P38: system (001BE000, 00500000) 2560 MB P39: cust (006BE000, 00100000) 512 MB P40: userdata (007BE000, 0159E000) 10.81 GB |
The Following User Says Thank You to starkrimes For This Useful Post: |
