Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus JTAG
Old 12-28-2016, 16:03   #1 (permalink)
Gsmserver's Avatar
Member: 21077
Thanks Meter: 116,340
Post 🐙 Octoplus JTAG PRO Software v.1.2.9 is out! 🐙
Dear friends!
We wish you and your family a sweet and beautiful New Year! Let this time bring happiness, love, and prosperity to your home and life.
May every day of the new year bring pleasant events, satisfaction from your achiements, new horizons, and happiness!
Thank you for every day out of 365 days we’ve spent together. Be sure we will further please you with new regular updates!
Please note, that we will be on holidays from December 29th till January 3rd. All support issues will be postponed during this period. See you next year!
Octoplus Box Team
Released new Samsung eMMC features: «Smart Report», «Factory Format», «Write CSD», «Write/Update firmware»).
Released writing firmware via USB for devices, based on Qualcomm CPUs (Qualcomm raw images with «rawprogram0.xml», «patch0.xml»).
Octoplus Box JTAG PRO Software v.1.2.9 Release Notes:
🐙 Added new features for Samsung eMMC chips:
  • Samsung Smart Report
    This feature shows extended info (check state) of Samsung eMMC chip such as:
    number of eMMC banks, initialization bad block count, optimal trim size and other information.
  • Samsung eMMC Factory Format
    This feature is intended to format Samsung eMMC chips.
    Note, that after performing Factory Format operation all eMMC data will be erased!
  • Samsung eMMC Write CSD
    This feature allows you to write data to CSD register in Samsung eMMC chips.
  • Samsung eMMC Write/Update firmware
    This feature allows you to update/write eMMC firmware on Samsung eMMC chip.
    If eMMC is not connected in Normal (General) Mode, to write eMMC firmware you should force it into Boot Mode using TestPoint.
    With this update we have added support and firmware for the following Samsung eMMC chips:
    - KMVTU000LM-B503 [VTU00M]
    - KMN5U000ZM-B203 [N5U00M]
    - KMKJS000VM-B309 [KJS00M]
    - KMK5U000VM-B309 [K5U00M]
    - KMJJS000WM-B409 [JJS00M]
    - KLMCG8GE4A-A001 [MCG8GA]
    - KLM8G1WE4A-A001 [M8G1WA]
    List of supported Samsung chips will expand in future software updates.
    To write/update firmware in mentioned above eMMC chips, do the following:
    1. Select «eMMC» interface option
    2. Select «Brand: eMMC_chips»
    3. Select eMMC chip part number in «Model:» software list
    4. Press «Help» button to view eMMC pinout and TestPoint picture. Acknowledge the manual.
    5. Solder all necessary wires to connect eMMC (if necessary, solder TP wire to force eMMC into Boot Mode, Product name will be displayed as 000000)
    6. Press «Connect» button to connect eMMC (if necessary, connect TP to GND)
    7. When connection is successful, release (disconnect) TP wire from GND and go to «eMMC service» tab in the software
    8. Press «Write/Update firmware» button, select proper eMMC chip from the list and press "Write/Update eMMC firmware" button
    NOTE: PLEASE DON’T SELECT INCORRECT eMMC (WITH NON MATCHING PART NUMBER)! WRITING INCORRECT FIRMWARE WILL DAMAGE YOUR EMMC!
🐙 Box firmware has been updated! To update firmware automatically, it is necessary to connect the Box and only then run the software.
Also, you can update Box firmware manually via «Update Box Firmware» button at «Welcome» tab in Octoplus JTAG PRO software.
Note, it won't be possible to use mentioned above Samsung eMMC features without updating Box firmware!
🐙 Released writing factory firmware via USB for devices, based on Qualcomm CPUs.
This feature («Repair devices based on Qualcomm CPU’s using XML files (*.xml)») allows you to Repair/Write factory firmware on devices,
based on Qualcomm CPUs using firmware with «rawprogram0.xml» and «patch0.xml».
To make Repair/Write firmware, do the following:
  1. Connect the device to PC in «Qualcomm…9008…» Mode. If necessary, use TP
  2. Select «USB» interface option
  3. Select «Brand: Custom Setting»
  4. Select proper «Device (Core)»
  5. Select proper Qualcomm loader in «Loader» list
  6. Press «Connect» button and wait while device will be connected
  7. Go to «Factory repair» tab
  8. Press «Repair devices based on Qualcomm CPU’s using XML files (*.xml)» button
  9. Select «rawprogram0.xml» and «patch0.xml» files
  10. Press «Write» button to write selected firmware
Note: some firmware’s XML may contain «modemst1» and «modemst2» partitions for writing.
Writing of these partitions may lead to loosing phone’s IMEI and calibration data.
Software will automatically deselect and skip writing of these partitions. If you need to write these partitions, you should manually select (check) them and confirm writing.
Also, software will automatically make backup (read) these partitions form the phone to «Backup» folder before writing firmware.
🐙 Added possibility to make Repair or Write flash without write data verification («Write data verification» option).
To make Smart Repair/Factory Repair/Write flash without write data verification, do the following:
connect the device, deselect (uncheck) «Write data verification» option in the software and perform Smart Repair/Factory Repair/Write flash operation.
🐙 Made some GUI changes.
🐙 All pinouts and repair procedures described in the manual ("Help" button in the software)
Also, we have improved routines of Sony phones connection, based on Qualcomm MSM7225A via Octoplus JTAG PRO Box
and we have uploaded «Octoplus JTAG Installer 1.9.5.1» into the Support Area and Octoplus Box site.
Download Octoplus JTAG PRO Software v.1.2.9
Find out more at: www.octoplusbox.com
The Following 25 Users Say Thank You to Gsmserver For This Useful Post:
Old 12-28-2016, 22:57   #2 (permalink)
Member: 125037
Sonork: 100.1649338
Thanks Meter: 254
It's always great see one of the best teams keep on working also when others are on holidays
Thanks a lot for your fantastic job and support.
Happy new 2017 !!!
Cheers
X4ce
Old 12-29-2016, 04:52   #3 (permalink)
Member: 1279781
Thanks Meter: 67
good update. but old feature on other box..
Old 12-29-2016, 07:54   #4 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
Kindly Add These Feature In Upcoming Future Update.
Read Emmc Firmware.
Read Qcom Phone In Factory Format Via USB/Emmc Connection.
Sony FTF Write In Emmc/USB Connection
Write Raw Firmware (ASUS) On Emmc/USB Connection.
LG Dz/Kdz Write Via USB.
MTK Flashing Via USB. (Secure N Non Secure Phones)
Huawei APP Extract N Write In Emmc/USB Connection.
Create XML For Qcom Phones In Emmc Connection.
It Will Give Extension To Users To Repair More Phones....N Add More Power To Box.
If You Add Unsigned Mode Enable Or Disable Security On MTK Via USB Will Be More Better. Spsly For Service Meizu Xiaomi ASUS Oppo N Other.
Great Update.........Happy New Year....
The Following User Says Thank You to hitech care For This Useful Post:
Old 12-29-2016, 16:45   #5 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,104
this is a big and most importent updat think you team
Old 12-29-2016, 21:09   #6 (permalink)
Crazy Poster
Member: 1712378
i need help related octopus , i have octopus box with lg and samsung,, i need jtag adition... is it possible to add jtag to my old octopus device... plz post me help ... or me need to purchase jtag box extra... i need help
Old 01-03-2017, 09:47   #7 (permalink)
Gsmserver's Avatar
Member: 21077
This is the right choice for you, activation only is not enough
Old 01-07-2017, 16:12   #8 (permalink)
m.haghnegahdar's Avatar
Member: 2097579
Thanks Meter: 43
i have octoplus but When I open my octoplus jtag displays the following message : box is not connected
Old 01-07-2017, 17:55   #9 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Re-install Box drivers from Octoplus Software installation folder, re-conect Box, check in PC Device Manager, whether driver was installed correctly and run Software again.
Old 01-08-2017, 06:55   #10 (permalink)
Member: 2097579
Thanks Meter: 43
I did these things, but the device gives me the same error
Old 01-08-2017, 06:59   #11 (permalink)
Member: 2097579
Thanks Meter: 43
please check your skype
Old 01-08-2017, 07:33   #12 (permalink)
Mubashir999's Avatar
Member: 2570477
Thanks Meter: 427
Medusa Team please give us special tutorial For repair jtag
Old 01-08-2017, 12:17   #13 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Hello.
To read repair manual (tutorial), just select necessary device model in Software list and press "Help" button. In manual You will also find JTAG pinout picture for selected model.
Also, You can look video manuals at our Youtube channels:
https://www.youtube.com/user/OctopusBox,
https://www.youtube.com/channel/UCJU...F0uLgMD2LoFKIw.
If You have problem with repairing the model, please create new thread, describe there the problem in details and we will try to help You.
Old 01-10-2017, 11:51   #14 (permalink)
Member: 1453066
Thanks Meter: 75
old octoplus box not working Octoplus JTAG PRO Software how can any help or any activation need ?
Old 01-10-2017, 11:57   #15 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Hi.
If You have an old Octoplus JTAG activation on your Octoplus card, You don't need any additional activation, just need to buy Medusa Pro Upgrade Kit: https://gsmserver.com/item/boxes-and...o-upgrade-kit/.
Also, You can contact to our managers in on-line Sales Chat ("Chat with us") at www.gsmserver.com, they will help You.
Page generated in 0.21880 seconds with 8 queries
