07-01-2017, 09:45 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Ordu TÜRKİYE
Member: 1918391 Status: Offline Thanks Meter: 73 | KLM8G1WE4A-A001-Samsung I9082 cant repair Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC 000000 Page size : 512 B Block size : 512 B Block count : 16776192 Size : 8.00 GB --------------------------------------------------------------- CID Info CID : 1501003030303030305620110726589D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 000000 Product revision : 5.6 Product serial number : (hex) 20110726 Manufacturing date : 05/2021 --------------------------------------------------------------- CSD Info CSD : 902701320F5903FFF6DBFFEF8A404023 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 512 Kbytes Boot2 size : 512 Kbytes RPMB size : 128 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 4026531840 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/000000_30_06_2017_19_08_27.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.9; FW: 1.19. Writing eMMC firmware from file: C:/Program Files (x86)/Octoplus Pro JTAG Software/EMMC_firmwares/KLM8G1WE4A-A001/KLM8G1WE4A-A001_FW.bin...Done. Finalizing...Done. Changing CID to 1501004D3847315741562011072658F1. Write CID error. Disconnected. EMMC writing firmware done. SW: 1.3.9; FW: 1.19. Please disconnect battery and USB cable. result connectable without testpoint but not repaired totally cant change cid and csd. please fix medusa team Code: Writing eMMC firmware from file: C:/Program Files (x86)/Octoplus Pro JTAG Software/EMMC_firmwares/KLM8G1WEMB-B031/KLM8G1WEMB-B031_FW.bin...Done. Finalizing...Done. Changing CID to 15010038574D42335256201305155813. Write CID succesfully completed. Disconnected. EMMC writing firmware done. SW: 1.3.9; FW: 1.19. Please disconnect battery and USB cable. Last edited by Octopus box; 07-01-2017 at 09:55. |
07-01-2017, 09:57 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Thanks for report, we will check and write You the result. Last edited by Octopus box; 07-03-2017 at 09:43. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
