09-03-2016, 15:23 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Algeria Age: 42
Member: 56311 Status: Offline Thanks Meter: 273 | h818p write partitions but not power on Device : Toshiba eMMC 032G74 Page size : 512 b Block size : 512 b Block count : 61071360 Size : 29.12 GB -------------------------------------------------------- CID Info CID : 1101003033324737340062A13C4B22F3 Manufacturer ID : 0X11 Device/BGA : BGA(Discrete embeded) OEM/Application ID : 0X00 Product name : 032G74 Product revision : 0.0 Product serial number : (hex)62A13C4B Manufacturing date : 02/2015 -------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO -------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Boot partition enable : Device not boot enabled (default) Partition config : 00000000 Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/032G74_03_09_2016_15_04_51.bin. Connect successful. -------------------------------------------------------- Opening E:/H818P20e_00_0428.kdz file... Opening E:/H818P20e_00_0428.kdz file... Writting. Please wait... Writting partition PrimaryGPT... Done. Writting partition modem... Done. Writting partition pmic... Done. Writting partition sbl1... Done. Writting partition tz... Done. Writting partition sdi... Done. Writting partition hyp... Done. Writting partition rpm... Done. Writting partition aboot... Done. Writting partition persist... Done. Writting partition sec... Done. Writting partition rct... Done. Writting partition laf... Done. Writting partition boot... Done. Writting partition recovery... Done. Writting partition factory... Done. Writting partition raw_resources... Done. Writting partition cust... Done. Writting partition cust... Done. Writting partition BackupGPT... Done. Writting is finished. SW: 1.1.7; FW: 1.11. Disconnected |
09-12-2016, 11:17 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. If after repairing the phone it still doesn't go into Download Mode - most likely, your phone's flash chip doesn't allow to make repair. Some flash chips don't allow to make repair/write data (eMMC flash chip has write data protection and it doesn't allow to write boot or some other partitions even write process was shown successfully completed). In this case, You need to solder new flash chip and then make Repair. Currently no another solution. The problem also can be with version of phone's boot loaders. Boot loaders in firmware file, which You have written, can be not suitable with your phone. Try to make Factory Repair using different LG firmwares. Also, try to write Full Flash, that we have sent You to PM. |
