Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus JTAG
Old 10-11-2016, 16:59   #1 (permalink)
Gsmserver's Avatar
Member: 21077
Thanks Meter: 100,527
Post 🐙 Octoplus JTAG PRO v.1.2.1 - MTK repair, deleted data recovery and many more!! 🐙
Octoplus JTAG PRO Software v.1.2.1 is out!
With this Software update we are glad to present new advanced features and support of new devices.
On your numerous requests, we have released feature of repairing devices, which are based on MediaTek CPUs using scatter!
Also added new eMMC functionality - «Boot partition enable» and for Samsung eMMC flash chips - «Remove write protect» and «eMMC geometry edit».
In addition, added support for new Samsung, LG, Lenovo, Alcatel and Oppo devices.
Octoplus Box JTAG PRO Software v.1.2.1 Release Notes:
🐙 Added «Repair devices based on MediaTek CPU's using scatter» feature!
With this feature you can repair different devices via eMMC, which are based on MediaTek CPUs.
Old and new scatter formats are supported.
To repair such devices, you should perform the next steps:
I. If device eMMC is not damaged
  1. Solder the necessary eMMC wires
  2. Connect the device
  3. Go to «Factory Repair» tab in the Software
  4. Press «Repair devices based on MediaTek CPU's using scatter» button
  5. Select proper scatter and necessary files
  6. Press «Write partitions» button
  7. Device repair is done
II. If device eMMC is damaged
If eMMC chip is damaged, you can replace it to similar Samsung eMMC chip.
You should have CID and know properties (Boot1, Boot2, RPMB partitions’ sizes) of eMMC, which you want to replace.
  1. Connect Samsung eMMC to Box (via soldering eMMC wires or via eMMC adapter)
  2. Press «eMMC geometry edit» button, enter necessary Boot1, Boot2, RPMB partitions’ sizes and set them
  3. Write proper CID of eMMC, which you want to replace
  4. Go to «Factory Repair» tab in the Software
  5. Press «Repair devices based on MediaTek CPU's using scatter» button
  6. Select proper scatter and necessary files
  7. Press «Write partitions» button
  8. After writing will be complete, replace device’s eMMC chip to programmed Samsung eMMC
  9. Assemble the device and power it on. Device repair is done
🐙 Added «Remove write protect» feature for Samsung eMMC flash chips
🐙 Added «eMMC geometry edit» feature for Samsung eMMC. With this option you can set Boot1, Boot2, RPMB partitions’ size for Samsung eMMC
🐙 Added «Boot partition enable» - you can set, whether the device is not boot enabled or select partition, that will be enabled for boot (partition1, partition2 or User area)
🐙 Added support for the following models via eMMC:
  • Samsung GT-I9060I - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
  • Samsung SM-G531H - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
  • LG F460K, F460L, F460S - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (Thanks to Mr. Hoayeu105 aka AquaSta)
  • Alcatel One Touch 4030 - Read/Write/Erase, Easy Repair, Constructor for Repair Files
  • Lenovo P780 - Read/Write/Erase, Easy Repair, Constructor for Repair Files
  • Lenovo A390 - Read/Write/Erase, Easy Repair, Constructor for Repair Files
  • Lenovo S820 - Read/Write/Erase, Easy Repair, Constructor for Repair Files
  • Lenovo A1000F - Read/Write/Erase, Easy Repair, Constructor for Repair Files
  • Oppo T29 - Read/Write/Erase, Easy Repair, Constructor for Repair Files
🐙 Added support for the following models via USB
(note: these devices are already supported via USB in old Medusa Software, they are just revised and added to Medusa Pro Software):
  • LG D160 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
  • LG D280N - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
  • LG D320N - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
  • LG D410 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
🐙 Improved erase operation (now it is up to 200 times faster)
🐙 Fixed some issues with CID edit
🐙 New features and improvements in "Content Extractor":
  • added possibility of restoration of deleted data (files, folders)! To find deleted data, select «Show deleted data» option in «Content Extractor» window and parse (read) data from device or file. Note: unfortunately, not all deleted data can be undeleted.
  • fixed errors with searching and displaying data
  • improved cashing process for video-files (in «Search media» window)
  • added more criteria for inner media-files search
  • fixed issue with window's hanging after some device been connected
  • fixed some GUI problems
🐙 Box firmware has been updated! To update firmware, it is necessary to connect the Box and only then run the Software
Please pay attention! As you may have noticed, there is a minor issue with early Medusa PRO boxes firmware update.
Non-updatable boxes are covered with warranty and entitled for replacement by authorized resellers.
It will be not possible to use new eMMC feature («eMMC geometry edit», «Boot partition enable», «Remove write protect») without updating Box firmware!
🐙 All pinouts and repair procedures described in the manual ("Help" button in the software)
http://www.youtube.com/watch?v=F5ej4IlgB4E
Download Octoplus JTAG PRO Software v.1.2.1
Find out more at: www.octoplusbox.com
The Following 9 Users Say Thank You to Gsmserver For This Useful Post:
Old 10-11-2016, 17:07   #2 (permalink)
M - Soft's Avatar
Member: 2408771
Thanks Meter: 145
Good Update Thanks Octoplus Team
Old 10-11-2016, 17:20   #3 (permalink)
M - Soft's Avatar
Member: 2408771
Thanks Meter: 145
Originally Posted by M - Soft View Post
Good Update Thanks Octoplus Box Team
please add remove frp zte Drivers
Old 10-11-2016, 17:58   #4 (permalink)
mobile mk's Avatar
Member: 1852490
Sonork: 100.1668568
Thanks Meter: 132
Great update team video not working plz upload video solve youtube error
Old 10-12-2016, 05:31   #5 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 641
Finally remove write protect... Wooow i was waiting for this update for a long time
Old 10-12-2016, 08:13   #6 (permalink)
ahmer5050's Avatar
Member: 2385819
Sonork: No More Used
Thanks Meter: 523
Nice Update,,,,,,,,,,
Old 10-12-2016, 09:55   #7 (permalink)
Member: 2281098
Sonork: 100.1662732:dp
Thanks Meter: 33
plz add moto models by usb
Old 10-12-2016, 18:42   #8 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,814
Thank you very good update i have old medusa box can i use this update or please tell me what is medusa last update
Old 10-13-2016, 01:24   #9 (permalink)
Member: 2320256
Sonork: 100.1661545
Thanks Meter: 45
Is possible to remove write protection, format emmc , emmc update firmware , repair cid like toshiba and other brands
Sent from my GT-N7100 using Tapatalk
Old 10-13-2016, 07:26   #10 (permalink)
Member: 1718952
Thanks Meter: 24
How to connect how is actoplus
Old 10-13-2016, 07:33   #11 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,812
Hi.
Unfortunately, old Medusa Box HW doesn't support work with eMMC, to use all Medusa Pro Software advantages, You should have new Medusa Pro Box with 20-pin connector: Medusa PRO Upgrade Kit - GsmServer.
Old 10-13-2016, 07:34   #12 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,812
Unfortunately, currently some of these features are supported only for Samsung eMMC chips.
Old 10-13-2016, 07:35   #13 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,812
What do You mean exactly?
The Following User Says Thank You to Medusa Box For This Useful Post:
Old 10-13-2016, 08:35   #14 (permalink)
Member: 1718952
Thanks Meter: 24
I box I
octopus
How can I will work for eMMC
Old 10-13-2016, 08:44   #15 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,812
Unfortunately, Octoplus/Octopus/old Medusa Box HW doesn't support work with eMMC; to work with eMMC, You should have new Medusa Pro Box with 20-pin connector: Medusa PRO Upgrade Kit - GsmServer.
Page generated in 0.37462 seconds with 7 queries
