01-11-2018, 07:41 | #1 (permalink) |
Junior Member Join Date: Apr 2013 Location: Mashhad Age: 33
Member: 1924303 Status: Offline Thanks Meter: 7 | Huawei G525-U00 eMMC problem [Solved] I Have a Huawei G525-U00 hang on logo try to flashing this device via memory card and not ok ! i decide to change old SK Hynix eMMC on phone via new eMMC of Samsung how to repair new eMMC and install on board of phone ? please help me ????? thanks a lot ...... Last edited by Octopus box; 01-11-2018 at 17:28. |
01-11-2018, 09:56 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Quote:
01-11-2018, 10:05 | #3 (permalink) |
Member: 1924303 Status: Offline Thanks Meter: 7 | not format eMMC this read of my emmc ! Product revision : 8.6 Product serial number : (hex) 3A30B5E Manufacturing date : 01/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A4040E3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 2048 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1433600 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G1d_08_01_2018_12_16_11.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. P00: FSBL (00000001, 00000028) 20 KB P01: QCSBL (00000029, 00000258) 300 KB P02: FAT32 (00000281, 00041000) 130 MB P03: PART_6A (00042000, 00006000) 12 MB P04: OSBL (00048000, 00002000) 4 MB P05: PART_63 (0004A000, 00002000) 4 MB P06: PART_58 (0004C000, 00001800) 3072 KB P07: MODEM_ST1 (0004E000, 00001800) 3072 KB P08: MODEM_ST2 (00050000, 00001800) 3072 KB P09: APPSBL (00052000, 00002000) 4 MB P10: BOOT (00054000, 00004000) 8 MB P11: PART_60 (00058000, 0000A000) 20 MB P12: PART_6C (00062000, 00002000) 4 MB P13: EXT2FS (00064000, 00060000) 192 MB P14: EXT2FS (000C4000, 00028000) 80 MB P15: EXT2FS (000EC000, 00200000) 1024 MB P16: EXT2FS (002EC000, 00240000) 1152 MB P17: PART_6B (0052C000, 0020C000) 1048 MB |
01-11-2018, 12:07 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Ok, now as I have written above: Quote:
01-11-2018, 15:27 | #7 (permalink) |
Member: 1924303 Status: Offline Thanks Meter: 7 | Read of new eMMC : Welcome to Medusa Pro Software version 1.5.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC KJS00M Page size : 512 B Block size : 512 B Block count : 7610368 Size : 3716.00 MB --------------------------------------------------------------- CID Info CID : 1501004B4A5330304D03B47A4C839F8B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : KJS00M Product revision : 0.3 Product serial number : (hex) B47A4C83 Manufacturing date : 09/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE78A404057 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 2048 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1900544 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/KJS00M_11_01_2018_17_52_14.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. |
01-11-2018, 15:37 | #8 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | OK. As You can see from your Software log, in original eMMC Partition config was the following: Quote:
Please set correct Partition config settings as on original eMMC ("eMMC service" tab, "Boot operation mode" button), then re-connect eMMC and do "Smart Repair" operation, using SFR for Huawei G525-U00 from the Support Area. Post here the result. | ||
