Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus JTAG
Old 11-28-2018, 15:40   #1 (permalink)
Gsmserver's Avatar
Member: 21077
Thanks Meter: 95,254
Post 🐙 Octoplus JTAG PRO v.1.7.0 is out! 🐙
Octoplus PRO JTAG v.1.7.0 is out! MTK support via USB, new models and new loaders were added!
Added possibility to work with MediaTek CPU-based devices via USB.
Added support for many new devices (via USB and eMMC).
Added new USB Qualcomm Loaders for different vendors' devices to the list of Software and to Software Loaders’ Data Base.
New “Live logs” uploaded into the Support Area.
Octoplus PRO JTAG Software v.1.7.0 Release Notes:
🐙 Added possibility to work with MediaTek CPU-based devices via USB: Write Firmware using scatter ("MTK Factory Repair"), Read/Write/Erase Full Flash/Custom Flash operations are supported.
To connect MediaTek CPU-based device you need to do the following steps: select "USB" interface option in the Software, select "Brand: Custom Settings", select "Device (Core): MTK Custom" and press "Connect" button.
Then select proper DA file, preloader and AUTH file (if necessary), and press "Continue" button. After successful connection supported operations will be available.
🐙 Added support for the following models via eMMC:
  • Alcatel 5011 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. neeykocat)
  • Alcatel 5054N - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. neeykocat)
  • Blu Studio 7 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
  • Condor PGN-403 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. Starkrimes)
  • Condor TAB 785R-3G 16GB - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. Starkrimes)
  • Gionee Pioneer P2S - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. Starkrimes)
  • LG M250E - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. Starkrimes)
  • Motorola XT1025 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. Starkrimes)
  • Motorola XT1775 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
  • Motorola XT1794 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
  • Motorola XT1527 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
  • OPPO 1201 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. Starkrimes)
  • Samsung SM-G390F - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
  • Samsung SM-G531F - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. Pijush Das)
  • Samsung SM-J327T - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. GSMTEAGER)
  • Samsung SM-J730GM - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. GSMTEAGER)
  • Samsung SM-S550TL - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
  • Vivo 1723 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files
🐙 Added support for the following models via USB:
  • Asus X003 (thanks to Mr. Paappan Mobiles)
  • Huawei Y635-L01 (thanks to Mr. abdelouahabido)
  • Nokia TA-1029 (thanks to Mr. Paappan Mobiles)
  • STREAM B3 MAXI (thanks to Mr. rebainoor)
  • Xiaomi Mi 5 (MDI1) (thanks to Mr. Pijush Das)
  • Xiaomi Mi 5 (thanks to Mr. rebainoor)
🐙 Added 15+ new unique Qualcomm USB Loaders to Software Loaders’ Data Base (Read/Write/Full Erase operations are supported).
🐙 New “Live logs” uploaded into the Support Area.
🐙 Some adjustments and improvements were made.
🐙 All pinouts and repair procedures are described in the manual ("Help" button in the software).
Download Octoplus PRO JTAG Software v.1.7.0
Find out more at: www.octoplusbox.com
The Following 15 Users Say Thank You to Gsmserver For This Useful Post:
Old 12-01-2018, 06:51   #2 (permalink)
Member: 2776492
Thanks Meter: 32
thanks for update ,,
can we remove frp,,mi account,screen lock,,with new mtk update,
plz confirm,
Old 12-01-2018, 14:48   #3 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 22,578
Possibilities released above, this is the instrument and if You know proper adresses of neccessary signatures, You can try to patch/erase them and reset proper locks.
Old 12-05-2018, 06:08   #4 (permalink)
Member: 2680150
Thanks Meter: 8
mtk custom emmc repir usb how to make this repair, Da file, Preloder, authentication file, how to collect file plase tell
octoplus pro
Old 12-05-2018, 06:35   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
Usually, DA, preloader and AUTH files are inside on original firmware package, you should find firmware and necessary files by yourself.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 12-07-2018, 17:50   #6 (permalink)
Member: 1989571
thank for update ( Samsung SM-J730GM - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files )
Old 12-11-2018, 03:10   #7 (permalink)
Member: 2715751
Thanks Meter: 25
thank for update.........
Page generated in 0.28323 seconds with 7 queries
