04-22-2019, 12:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | no phone connected [Answered] Model Settings: Interface : eMMC Brand : Samsung Model : GT-I9195 SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_GT-I9195_EMMC.srf Voltage : 2.8V Bus Mode : 4 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present |
04-23-2019, 08:55 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Quote:
1. You have connected battery or USB cable. Before connecting the device You must disconnect the battery and the USB cable, and then connect the device without power, this is important! 2. Some wires are soldered incorrectly. Carefully check soldering of all wires. 3. In the process of soldering, the resistors were burned (damaged) by using soldering iron or the pin pads on the board to which wires were soldered were damaged. Need replace damaged resistors and restore the pin pads on the board. 4. The ends of wires that were soldered, had not been cleared. Wire, that comes complete with Medusa Pro Box, is covered with an insulator, so before soldering need to clean the ends of each wire. 5. Soldered wires are too long. Make each wire as short as possible (3-5 CM length). 6. For GND connection use more thicker wire. Check all of them and try to connect the device again. Also the problem can be with eMMC adapter, which You use. Please use Medusa Pro adapter. | |
04-24-2019, 12:45 | #3 (permalink) | |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | Quote:
Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : D855 SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/LG_D855_EMMC_SDW16G.srf Voltage : 2.8V Bus Mode : 4 bits Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. | |
04-24-2019, 14:40 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, use short same wire for GND connections, after repeat Connect operation again |
04-24-2019, 14:41 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | If the problem will still remain with connected box to PC, open Device manager make screenshot of USB, COM port sections and post here. |
04-24-2019, 15:37 | #7 (permalink) | |
Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : D855 SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/LG_D855_EMMC_SDW16G.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Sandisk eMMC SDW32G Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 45010053445733324701B31700C391CD Manufacturer ID : 0X45 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : SDW32G Product revision : 0.1 Product serial number : (hex) B31700C3 Manufacturing date : 09/2014 --------------------------------------------------------------- CSD Info CSD : D00F00320F5903FFFFFFFFEF8A40401F CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 10 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 14385152 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 720896 Number of sectors : 4227072 Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/SDW32G_24_04_2019_15_33_49.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. Repairing from file "C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/LG_D855_EMMC_SDW16G.srf". Write data verification is enabled. Writing GPT partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. | |
04-25-2019, 08:27 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, try to clean all contacts of USB port of your Box, try to use another USB cable and try to use another USB 2.0 port on your PC |
