11-22-2017, 10:52 | #1 (permalink) |
Major Poster Join Date: May 2016 Location: Tamil Nadu,Trichy
Member: 2568424 Status: Offline Thanks Meter: 11 | Pls Help Unable to Repair N8000 Boot SW: 1.4.8; FW: 1.22. Cancelled writing. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/samsung_gt-n8000_emmc_mag2ga.srf". Write data verification is enabled. Writing BOOT1 partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. Pls guide me to Repair Easy to Enter Download Mode Using Jig but I Have to Flash 8 diffrent Frimware with Octopus and Odin sam file also Flashing also Error With octopus Box and odin. Firmware Write Failed Whats the Problem How Can i Slove? Pls Guide me to repair on Teamviewer |
11-22-2017, 11:00 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. 1. Post here full Software log with device connection info, not reduced log, we will check. 2. As You can see from Software log, there is an error occur while writing data to eMMC: Quote:
3. Quote:
11-22-2017, 11:20 | #3 (permalink) |
Member: 2568424 Status: Offline Thanks Meter: 11 | Welcome to Medusa Pro Software version 1.4.8. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: FT SCR2000 2 Reader #3: Generic Usb Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-N8000 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/samsung_gt-n8000_emmc_mag2ga.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG2GA Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 1501004D414732474107E3076D6D8F0B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG2GA Product revision : 0.7 Product serial number : (hex) E3076D6D Manufacturing date : 08/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8A406063 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_22_11_2017_15_34_31.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.8; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: PARAM (00010000, 00004000) 8 MB P05: BOOT (00014000, 00004000) 8 MB P06: RECOVERY (00018000, 00004000) 8 MB P07: RADIO (0001C000, 00010000) 32 MB P08: CACHE (0002C000, 00190000) 800 MB P09: SYSTEM (001BC000, 002BC000) 1400 MB P10: HIDDEN (00478000, 000FA000) 500 MB P11: OTA (00572000, 00004000) 8 MB P12: USERDATA (00576000, 017E2000) 11.94 GB Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/samsung_gt-n8000_emmc_mag2ga.srf". Write data verification is enabled. Writing BOOT1 partition... Read/write verification error. Possible reasons: damaged or write protected eMMC. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-N8000 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/samsung_gt-n8000_emmc_mag2ga.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG2GA Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 1501004D414732474107E3076D6D8F0B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG2GA Product revision : 0.7 Product serial number : (hex) E3076D6D Manufacturing date : 08/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8A406063 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 1818624 Number of sectors : 2867200 Device Manufacturer : samsung Device Platform : exynos4 Build ID : KOT49H Display Build ID : KOT49H.N8000XXUDNE6 Release ID : 4.4.2 Device Model : GT-N8000 Device Name : p4noterfxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : p4noterfxx-user 4.4.2 KOT49H N8000XXUDNE6 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_22_11_2017_15_49_14.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.8; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: PARAM (00010000, 00004000) 8 MB P05: BOOT (00014000, 00004000) 8 MB P06: RECOVERY (00018000, 00004000) 8 MB P07: RADIO (0001C000, 00010000) 32 MB P08: CACHE (0002C000, 00190000) 800 MB P09: SYSTEM (001BC000, 002BC000) 1400 MB P10: HIDDEN (00478000, 000FA000) 500 MB P11: OTA (00572000, 00004000) 8 MB P12: USERDATA (00576000, 017E2000) 11.94 GB Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/samsung_gt-n8000_emmc_mag2ga.srf". Write data verification is enabled. Writing BOOT1 partition... Read/write verification error. Possible reasons: damaged or write protected eMMC. Disconnected. |
11-22-2017, 13:19 | #4 (permalink) | ||
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | As I see from your Software log, device's eMMC is write protected: Quote:
11-22-2017, 15:27 | #9 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | This can be HW problem. Try also to do "Factory Repair" ("Factory repair" tab in Software) using proper PIT file and the latest original Samsung firmware. |
11-22-2017, 16:30 | #11 (permalink) |
Member: 2568424 Status: Offline Thanks Meter: 11 | Last Trying i Have to Download all files cannot shown on partition pls Give me a N8000 16gb pit file Last edited by planethakki; 11-22-2017 at 16:38. |
