03-29-2019, 14:28 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NYC/USA
Member: 1283129 Status: Offline Thanks Meter: 135 | Read error read error read error [Solved] I am trying to read userdata partition (50GB) and always about 30 minutes into it, I get read error. This is a virgin PC, nothing running in the background, true real OEM cable plugged directly into USB port (not hub or secondary USB port), nothing else plugged into USB ports except Medusa box and phone. Don't touch PC during process. It will just disconnect 30, 40 minutes into it. Can you add a pause function or some way we can break it up? This is no problem for a small file disconnect, reconnect again but this userdata partition takes over an hour. I've been trying to read for a week now. Any suggestion? ------------------------------------------------- Save to C:/Program Files (x86)/Octoplus Pro JTAG Software/TOSHIBA THGAF8G9T43BAIRB0100 _Fri Mar 29 2019_06_08_33.mpt file... Physical partition number: 0 Reading partition userdata... ERROR[011]: Read error. At sector 5711622 Disconnected. |
03-30-2019, 11:19 | #2 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | Quote:
please poste full log operation here | |
03-31-2019, 22:49 | #3 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | Welcome to Octoplus Pro JTAG Software version 1.7.6. Started. Reader #0: Generic EMV Smartcard Reader 0 Model Settings: Interface : USB Brand : LG Model : V350AWM SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_V350AWM_USB_UFS.srf Core : Qualcomm SDM845 UFS Loader : QLoader_v1_LG Connecting... Sending loader...OK. Loader successfully initialized. INFO: Calling handler for getstorageinfo INFO: Device Total Logical Blocks: 0xeac800 INFO: Device Block Size in Bytes: 0x1000 INFO: Device Total Physical Partitions: 0x7 INFO: Device Manufacturer ID: 0x198 INFO: Device Serial Number: 0x48494241 INFO: {"storage_info": {"total_blocks":15386624, "block_size":4096, "page_size":4096, "num_physical":7, "manufacturer_id":408, "serial_num":1212760641, "fw_version":"100","mem_type":"UFS","prod_name":"T HGAF8G9T43BAIRB0100"}} INFO: UFS fInitialized: 0x1 INFO: UFS Current LUN Number: = 0x0 INFO: UFS Total Active LU: 0x7 INFO: UFS wManufacturerID: 0x198 INFO: UFS Boot Partition Enabled: 0x1 INFO: UFS Raw Device Capacity: = 0x7738000 INFO: UFS Min Block Size: 0x8 INFO: UFS Erase Block Size: 0x2000 INFO: UFS Allocation Unit Size: 0x1 INFO: UFS RPMB ReadWrite Size: = 0x40 INFO: UFS Number of Allocation Uint for This LU: 0x3ab2 INFO: UFS Logical Block Size: 0xc INFO: UFS Provisioning Type: 0x2 INFO: UFS LU Write Protect: 0x0 INFO: UFS Boot LUN ID: = 0x0 INFO: UFS Memory Type: 0x0 INFO: UFS LU Total Blocks: 0xeac800 INFO: UFS Supported Memory Types: 0x801f INFO: UFS dEnhanced1MaxNAllocU: 0x3b9c INFO: UFS wEnhanced1CapAdjFac: 0x300 INFO: UFS dEnhanced2MaxNAllocU: = 0x60 INFO: UFS wEnhanced2CapAdjFac: 0x300 INFO: UFS dEnhanced3MaxNAllocU: 0x0 INFO: UFS wEnhanced3CapAdjFac: 0x0 INFO: UFS dEnhanced4MaxNAllocU: 0x0 INFO: UFS wEnhanced4CapAdjFac: 0x0 INFO: UFS LUN Enable Bitmask: 0x7f INFO: UFS Logical Block Count: 0xeac800 INFO: UFS bConfigDescrLock: 0x0 INFO: UFS iManufacturerName String Index: 0x1 INFO: UFS iProductName String Index: 0x2 INFO: UFS iSerialNumber String Index: 0x3 INFO: UFS iOemID String Index: 0x4 INFO: UFS Inquiry Command Output: TOSHIBA THGAF8G9T43BAIRB0100 ACK e=false Device : TOSHIBA THGAF8G9T43BAIRB0100 Core : Qualcomm SDM845 UFS Page size : 4096 B Block size : 4096 B Block count : 15618048 Size : 59.58 GB (61008.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. Physical partition number: 0 Block count : 15386624 (0xEAC800) Size : 58.70 GB (60104.00 MB) P00: GPT (00000000, 00000006) 24 KB P01: mpt (00000006, 00002000) 32 MB P02: drm (00002006, 00000E00) 14 MB P03: sns (00002E06, 00000600) 6 MB P04: ssd (00003406, 00000080) 512 KB P05: persist (00003486, 00002000) 32 MB P06: misc (00005486, 00000100) 1024 KB P07: ftm (00005586, 00002000) 32 MB P08: power (00007586, 00002C00) 44 MB P09: encrypt (0000A186, 00000080) 512 KB P10: eksst (0000A206, 00000080) 512 KB P11: rct (0000A286, 00000080) 512 KB P12: fota (0000A306, 00000A00) 10 MB P13: srtc (0000AD06, 00000800) 8 MB P14: pstore (0000B506, 00000200) 2048 KB P15: els (0000B706, 00001000) 16 MB P16: carrier (0000C706, 00002800) 40 MB P17: persdata (0000EF06, 00004000) 64 MB P18: oem_a (00012F06, 00000800) 8 MB P19: oem_b (00013706, 00000800) 8 MB P20: vendor_a (00013F06, 0003E800) 1000 MB P21: vendor_b (00052706, 0003E800) 1000 MB P22: system_a (00090F06, 0011B800) 4.43 GB P23: system_b (001AC706, 0011B800) 4.43 GB P24: OP_a (002C7F06, 00028A00) 650 MB P25: OP_b (002F0906, 00028A00) 650 MB P26: userdata (00319306, 00B934F4) 46.3 GB P27: grow (00EAC7FA, 00000001) 4 KB Physical partition number: 1 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_a (00000006, 00000380) 3584 KB P02: xbl_config_a (00000386, 00000020) 128 KB Physical partition number: 2 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_b (00000006, 00000380) 3584 KB P02: xbl_config_b (00000386, 00000020) 128 KB Physical partition number: 3 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_1 (00000006, 0000001A) 104 KB P02: cdt (00000020, 00000020) 128 KB P03: ddr (00000040, 00000100) 1024 KB Physical partition number: 4 Block count : 221184 (0x36000) Size : 864.00 MB P00: GPT (00000000, 00000006) 24 KB P01: aop_a (00000006, 00000080) 512 KB P02: tz_a (00000086, 00000200) 2048 KB P03: hyp_a (00000286, 00000080) 512 KB P04: modem_a (00000306, 0000B600) 182 MB P05: mdtpsecapp_a (0000B906, 00000400) 4 MB P06: mdtp_a (0000BD06, 00002000) 32 MB P07: abl_a (0000DD06, 00000100) 1024 KB P08: dsp_a (0000DE06, 00002000) 32 MB P09: keymaster_a (0000FE06, 00000080) 512 KB P10: akmu_a (0000FE86, 00000080) 512 KB P11: boot_a (0000FF06, 00004000) 64 MB P12: cmnlib_a (00013F06, 00000080) 512 KB P13: cmnlib64_a (00013F86, 00000080) 512 KB P14: devcfg_a (00014006, 00000020) 128 KB P15: qupfw_a (00014026, 00000020) 128 KB P16: laf_a (00014046, 00003000) 48 MB P17: vbmeta_a (00017046, 00000010) 64 KB P18: dtbo_a (00017056, 00000800) 8 MB P19: storsec_a (00017856, 00000020) 128 KB P20: raw_resources_a (00017876, 00000800) 8 MB P21: sid_a (00018076, 00000080) 512 KB P22: aop_b (000180F6, 00000080) 512 KB P23: tz_b (00018176, 00000200) 2048 KB P24: hyp_b (00018376, 00000080) 512 KB P25: modem_b (000183F6, 0000B600) 182 MB P26: mdtpsecapp_b (000239F6, 00000400) 4 MB P27: mdtp_b (00023DF6, 00002000) 32 MB P28: abl_b (00025DF6, 00000100) 1024 KB P29: dsp_b (00025EF6, 00002000) 32 MB P30: keymaster_b (00027EF6, 00000080) 512 KB P31: akmu_b (00027F76, 00000080) 512 KB P32: boot_b (00027FF6, 00004000) 64 MB P33: cmnlib_b (0002BFF6, 00000080) 512 KB P34: cmnlib64_b (0002C076, 00000080) 512 KB P35: devcfg_b (0002C0F6, 00000020) 128 KB P36: qupfw_b (0002C116, 00000020) 128 KB P37: laf_b (0002C136, 00003000) 48 MB P38: vbmeta_b (0002F136, 00000010) 64 KB P39: dtbo_b (0002F146, 00000800) 8 MB P40: storsec_b (0002F946, 00000020) 128 KB P41: raw_resources_b (0002F966, 00000800) 8 MB P42: sid_b (00030166, 00000080) 512 KB P43: sec (000301E6, 00000040) 256 KB P44: devinfo (00030226, 00000040) 256 KB P45: dip (00030266, 00000100) 1024 KB P46: apdp (00030366, 00000080) 512 KB P47: msadp (000303E6, 00000080) 512 KB P48: spunvm (00030466, 00000800) 8 MB P49: limits (00030C66, 00000001) 4 KB P50: toolsfv (00030C67, 00000100) 1024 KB P51: logfs (00030D67, 00000800) 8 MB P52: sti (00031567, 00000200) 2048 KB P53: logdump (00031767, 00004000) 64 MB Physical partition number: 5 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_2 (00000006, 0000001A) 104 KB P02: modemst1 (00000020, 00000200) 2048 KB P03: modemst2 (00000220, 00000200) 2048 KB P04: fsg (00000420, 00000200) 2048 KB P05: fsc (00000620, 00000080) 512 KB Physical partition number: 6 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: frp (00000006, 00000200) 2048 KB Save to C:/Program Files (x86)/Octoplus Pro JTAG Software/TOSHIBA THGAF8G9T43BAIRB0100 _Sun Mar 31 2019_17_46_24.mpt file... Physical partition number: 0 Reading partition userdata... ERROR[011]: Read error. At sector 3297030 Disconnected. |
03-31-2019, 23:40 | #4 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | Welcome to Octoplus Pro JTAG Software version 1.7.6. Started. Reader #0: Generic EMV Smartcard Reader 0 Model Settings: Interface : USB Brand : LG Model : V350AWM SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_V350AWM_USB_UFS.srf Core : Qualcomm SDM845 UFS Loader : QLoader_v1_LG Connecting... Sending loader...OK. Loader successfully initialized. INFO: Calling handler for getstorageinfo INFO: Device Total Logical Blocks: 0xeac800 INFO: Device Block Size in Bytes: 0x1000 INFO: Device Total Physical Partitions: 0x7 INFO: Device Manufacturer ID: 0x198 INFO: Device Serial Number: 0x48494241 INFO: {"storage_info": {"total_blocks":15386624, "block_size":4096, "page_size":4096, "num_physical":7, "manufacturer_id":408, "serial_num":1212760641, "fw_version":"100","mem_type":"UFS","prod_name":"T HGAF8G9T43BAIRB0100"}} INFO: UFS fInitialized: 0x1 INFO: UFS Current LUN Number: = 0x0 INFO: UFS Total Active LU: 0x7 INFO: UFS wManufacturerID: 0x198 INFO: UFS Boot Partition Enabled: 0x1 INFO: UFS Raw Device Capacity: = 0x7738000 INFO: UFS Min Block Size: 0x8 INFO: UFS Erase Block Size: 0x2000 INFO: UFS Allocation Unit Size: 0x1 INFO: UFS RPMB ReadWrite Size: = 0x40 INFO: UFS Number of Allocation Uint for This LU: 0x3ab2 INFO: UFS Logical Block Size: 0xc INFO: UFS Provisioning Type: 0x2 INFO: UFS LU Write Protect: 0x0 INFO: UFS Boot LUN ID: = 0x0 INFO: UFS Memory Type: 0x0 INFO: UFS LU Total Blocks: 0xeac800 INFO: UFS Supported Memory Types: 0x801f INFO: UFS dEnhanced1MaxNAllocU: 0x3b9c INFO: UFS wEnhanced1CapAdjFac: 0x300 INFO: UFS dEnhanced2MaxNAllocU: = 0x60 INFO: UFS wEnhanced2CapAdjFac: 0x300 INFO: UFS dEnhanced3MaxNAllocU: 0x0 INFO: UFS wEnhanced3CapAdjFac: 0x0 INFO: UFS dEnhanced4MaxNAllocU: 0x0 INFO: UFS wEnhanced4CapAdjFac: 0x0 INFO: UFS LUN Enable Bitmask: 0x7f INFO: UFS Logical Block Count: 0xeac800 INFO: UFS bConfigDescrLock: 0x0 INFO: UFS iManufacturerName String Index: 0x1 INFO: UFS iProductName String Index: 0x2 INFO: UFS iSerialNumber String Index: 0x3 INFO: UFS iOemID String Index: 0x4 INFO: UFS Inquiry Command Output: TOSHIBA THGAF8G9T43BAIRB0100 ACK e=false Device : TOSHIBA THGAF8G9T43BAIRB0100 Core : Qualcomm SDM845 UFS Page size : 4096 B Block size : 4096 B Block count : 15618048 Size : 59.58 GB (61008.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. Physical partition number: 0 Block count : 15386624 (0xEAC800) Size : 58.70 GB (60104.00 MB) P00: GPT (00000000, 00000006) 24 KB P01: mpt (00000006, 00002000) 32 MB P02: drm (00002006, 00000E00) 14 MB P03: sns (00002E06, 00000600) 6 MB P04: ssd (00003406, 00000080) 512 KB P05: persist (00003486, 00002000) 32 MB P06: misc (00005486, 00000100) 1024 KB P07: ftm (00005586, 00002000) 32 MB P08: power (00007586, 00002C00) 44 MB P09: encrypt (0000A186, 00000080) 512 KB P10: eksst (0000A206, 00000080) 512 KB P11: rct (0000A286, 00000080) 512 KB P12: fota (0000A306, 00000A00) 10 MB P13: srtc (0000AD06, 00000800) 8 MB P14: pstore (0000B506, 00000200) 2048 KB P15: els (0000B706, 00001000) 16 MB P16: carrier (0000C706, 00002800) 40 MB P17: persdata (0000EF06, 00004000) 64 MB P18: oem_a (00012F06, 00000800) 8 MB P19: oem_b (00013706, 00000800) 8 MB P20: vendor_a (00013F06, 0003E800) 1000 MB P21: vendor_b (00052706, 0003E800) 1000 MB P22: system_a (00090F06, 0011B800) 4.43 GB P23: system_b (001AC706, 0011B800) 4.43 GB P24: OP_a (002C7F06, 00028A00) 650 MB P25: OP_b (002F0906, 00028A00) 650 MB P26: userdata (00319306, 00B934F4) 46.3 GB P27: grow (00EAC7FA, 00000001) 4 KB Physical partition number: 1 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_a (00000006, 00000380) 3584 KB P02: xbl_config_a (00000386, 00000020) 128 KB Physical partition number: 2 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_b (00000006, 00000380) 3584 KB P02: xbl_config_b (00000386, 00000020) 128 KB Physical partition number: 3 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_1 (00000006, 0000001A) 104 KB P02: cdt (00000020, 00000020) 128 KB P03: ddr (00000040, 00000100) 1024 KB Physical partition number: 4 Block count : 221184 (0x36000) Size : 864.00 MB P00: GPT (00000000, 00000006) 24 KB P01: aop_a (00000006, 00000080) 512 KB P02: tz_a (00000086, 00000200) 2048 KB P03: hyp_a (00000286, 00000080) 512 KB P04: modem_a (00000306, 0000B600) 182 MB P05: mdtpsecapp_a (0000B906, 00000400) 4 MB P06: mdtp_a (0000BD06, 00002000) 32 MB P07: abl_a (0000DD06, 00000100) 1024 KB P08: dsp_a (0000DE06, 00002000) 32 MB P09: keymaster_a (0000FE06, 00000080) 512 KB P10: akmu_a (0000FE86, 00000080) 512 KB P11: boot_a (0000FF06, 00004000) 64 MB P12: cmnlib_a (00013F06, 00000080) 512 KB P13: cmnlib64_a (00013F86, 00000080) 512 KB P14: devcfg_a (00014006, 00000020) 128 KB P15: qupfw_a (00014026, 00000020) 128 KB P16: laf_a (00014046, 00003000) 48 MB P17: vbmeta_a (00017046, 00000010) 64 KB P18: dtbo_a (00017056, 00000800) 8 MB P19: storsec_a (00017856, 00000020) 128 KB P20: raw_resources_a (00017876, 00000800) 8 MB P21: sid_a (00018076, 00000080) 512 KB P22: aop_b (000180F6, 00000080) 512 KB P23: tz_b (00018176, 00000200) 2048 KB P24: hyp_b (00018376, 00000080) 512 KB P25: modem_b (000183F6, 0000B600) 182 MB P26: mdtpsecapp_b (000239F6, 00000400) 4 MB P27: mdtp_b (00023DF6, 00002000) 32 MB P28: abl_b (00025DF6, 00000100) 1024 KB P29: dsp_b (00025EF6, 00002000) 32 MB P30: keymaster_b (00027EF6, 00000080) 512 KB P31: akmu_b (00027F76, 00000080) 512 KB P32: boot_b (00027FF6, 00004000) 64 MB P33: cmnlib_b (0002BFF6, 00000080) 512 KB P34: cmnlib64_b (0002C076, 00000080) 512 KB P35: devcfg_b (0002C0F6, 00000020) 128 KB P36: qupfw_b (0002C116, 00000020) 128 KB P37: laf_b (0002C136, 00003000) 48 MB P38: vbmeta_b (0002F136, 00000010) 64 KB P39: dtbo_b (0002F146, 00000800) 8 MB P40: storsec_b (0002F946, 00000020) 128 KB P41: raw_resources_b (0002F966, 00000800) 8 MB P42: sid_b (00030166, 00000080) 512 KB P43: sec (000301E6, 00000040) 256 KB P44: devinfo (00030226, 00000040) 256 KB P45: dip (00030266, 00000100) 1024 KB P46: apdp (00030366, 00000080) 512 KB P47: msadp (000303E6, 00000080) 512 KB P48: spunvm (00030466, 00000800) 8 MB P49: limits (00030C66, 00000001) 4 KB P50: toolsfv (00030C67, 00000100) 1024 KB P51: logfs (00030D67, 00000800) 8 MB P52: sti (00031567, 00000200) 2048 KB P53: logdump (00031767, 00004000) 64 MB Physical partition number: 5 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_2 (00000006, 0000001A) 104 KB P02: modemst1 (00000020, 00000200) 2048 KB P03: modemst2 (00000220, 00000200) 2048 KB P04: fsg (00000420, 00000200) 2048 KB P05: fsc (00000620, 00000080) 512 KB Physical partition number: 6 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: frp (00000006, 00000200) 2048 KB Save to C:/Program Files (x86)/Octoplus Pro JTAG Software/TOSHIBA THGAF8G9T43BAIRB0100 _Sun Mar 31 2019_17_53_07.mpt file... Physical partition number: 0 Reading partition userdata... ERROR[011]: Read error. At sector 3342086 Disconnected. |
04-01-2019, 00:07 | #5 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | Welcome to Octoplus Pro JTAG Software version 1.7.6. Started. Reader #0: Generic EMV Smartcard Reader 0 Model Settings: Interface : USB Brand : LG Model : V350AWM SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_V350AWM_USB_UFS.srf Core : Qualcomm SDM845 UFS Loader : QLoader_v1_LG Connecting... Sending loader...OK. Loader successfully initialized. INFO: Calling handler for getstorageinfo INFO: Device Total Logical Blocks: 0xeac800 INFO: Device Block Size in Bytes: 0x1000 INFO: Device Total Physical Partitions: 0x7 INFO: Device Manufacturer ID: 0x198 INFO: Device Serial Number: 0x48494241 INFO: {"storage_info": {"total_blocks":15386624, "block_size":4096, "page_size":4096, "num_physical":7, "manufacturer_id":408, "serial_num":1212760641, "fw_version":"100","mem_type":"UFS","prod_name":"T HGAF8G9T43BAIRB0100"}} INFO: UFS fInitialized: 0x1 INFO: UFS Current LUN Number: = 0x0 INFO: UFS Total Active LU: 0x7 INFO: UFS wManufacturerID: 0x198 INFO: UFS Boot Partition Enabled: 0x1 INFO: UFS Raw Device Capacity: = 0x7738000 INFO: UFS Min Block Size: 0x8 INFO: UFS Erase Block Size: 0x2000 INFO: UFS Allocation Unit Size: 0x1 INFO: UFS RPMB ReadWrite Size: = 0x40 INFO: UFS Number of Allocation Uint for This LU: 0x3ab2 INFO: UFS Logical Block Size: 0xc INFO: UFS Provisioning Type: 0x2 INFO: UFS LU Write Protect: 0x0 INFO: UFS Boot LUN ID: = 0x0 INFO: UFS Memory Type: 0x0 INFO: UFS LU Total Blocks: 0xeac800 INFO: UFS Supported Memory Types: 0x801f INFO: UFS dEnhanced1MaxNAllocU: 0x3b9c INFO: UFS wEnhanced1CapAdjFac: 0x300 INFO: UFS dEnhanced2MaxNAllocU: = 0x60 INFO: UFS wEnhanced2CapAdjFac: 0x300 INFO: UFS dEnhanced3MaxNAllocU: 0x0 INFO: UFS wEnhanced3CapAdjFac: 0x0 INFO: UFS dEnhanced4MaxNAllocU: 0x0 INFO: UFS wEnhanced4CapAdjFac: 0x0 INFO: UFS LUN Enable Bitmask: 0x7f INFO: UFS Logical Block Count: 0xeac800 INFO: UFS bConfigDescrLock: 0x0 INFO: UFS iManufacturerName String Index: 0x1 INFO: UFS iProductName String Index: 0x2 INFO: UFS iSerialNumber String Index: 0x3 INFO: UFS iOemID String Index: 0x4 INFO: UFS Inquiry Command Output: TOSHIBA THGAF8G9T43BAIRB0100 e=false ACK Device : TOSHIBA THGAF8G9T43BAIRB0100 Core : Qualcomm SDM845 UFS Page size : 4096 B Block size : 4096 B Block count : 15618048 Size : 59.58 GB (61008.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. Physical partition number: 0 Block count : 15386624 (0xEAC800) Size : 58.70 GB (60104.00 MB) P00: GPT (00000000, 00000006) 24 KB P01: mpt (00000006, 00002000) 32 MB P02: drm (00002006, 00000E00) 14 MB P03: sns (00002E06, 00000600) 6 MB P04: ssd (00003406, 00000080) 512 KB P05: persist (00003486, 00002000) 32 MB P06: misc (00005486, 00000100) 1024 KB P07: ftm (00005586, 00002000) 32 MB P08: power (00007586, 00002C00) 44 MB P09: encrypt (0000A186, 00000080) 512 KB P10: eksst (0000A206, 00000080) 512 KB P11: rct (0000A286, 00000080) 512 KB P12: fota (0000A306, 00000A00) 10 MB P13: srtc (0000AD06, 00000800) 8 MB P14: pstore (0000B506, 00000200) 2048 KB P15: els (0000B706, 00001000) 16 MB P16: carrier (0000C706, 00002800) 40 MB P17: persdata (0000EF06, 00004000) 64 MB P18: oem_a (00012F06, 00000800) 8 MB P19: oem_b (00013706, 00000800) 8 MB P20: vendor_a (00013F06, 0003E800) 1000 MB P21: vendor_b (00052706, 0003E800) 1000 MB P22: system_a (00090F06, 0011B800) 4.43 GB P23: system_b (001AC706, 0011B800) 4.43 GB P24: OP_a (002C7F06, 00028A00) 650 MB P25: OP_b (002F0906, 00028A00) 650 MB P26: userdata (00319306, 00B934F4) 46.3 GB P27: grow (00EAC7FA, 00000001) 4 KB Physical partition number: 1 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_a (00000006, 00000380) 3584 KB P02: xbl_config_a (00000386, 00000020) 128 KB Physical partition number: 2 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_b (00000006, 00000380) 3584 KB P02: xbl_config_b (00000386, 00000020) 128 KB Physical partition number: 3 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_1 (00000006, 0000001A) 104 KB P02: cdt (00000020, 00000020) 128 KB P03: ddr (00000040, 00000100) 1024 KB Physical partition number: 4 Block count : 221184 (0x36000) Size : 864.00 MB P00: GPT (00000000, 00000006) 24 KB P01: aop_a (00000006, 00000080) 512 KB P02: tz_a (00000086, 00000200) 2048 KB P03: hyp_a (00000286, 00000080) 512 KB P04: modem_a (00000306, 0000B600) 182 MB P05: mdtpsecapp_a (0000B906, 00000400) 4 MB P06: mdtp_a (0000BD06, 00002000) 32 MB P07: abl_a (0000DD06, 00000100) 1024 KB P08: dsp_a (0000DE06, 00002000) 32 MB P09: keymaster_a (0000FE06, 00000080) 512 KB P10: akmu_a (0000FE86, 00000080) 512 KB P11: boot_a (0000FF06, 00004000) 64 MB P12: cmnlib_a (00013F06, 00000080) 512 KB P13: cmnlib64_a (00013F86, 00000080) 512 KB P14: devcfg_a (00014006, 00000020) 128 KB P15: qupfw_a (00014026, 00000020) 128 KB P16: laf_a (00014046, 00003000) 48 MB P17: vbmeta_a (00017046, 00000010) 64 KB P18: dtbo_a (00017056, 00000800) 8 MB P19: storsec_a (00017856, 00000020) 128 KB P20: raw_resources_a (00017876, 00000800) 8 MB P21: sid_a (00018076, 00000080) 512 KB P22: aop_b (000180F6, 00000080) 512 KB P23: tz_b (00018176, 00000200) 2048 KB P24: hyp_b (00018376, 00000080) 512 KB P25: modem_b (000183F6, 0000B600) 182 MB P26: mdtpsecapp_b (000239F6, 00000400) 4 MB P27: mdtp_b (00023DF6, 00002000) 32 MB P28: abl_b (00025DF6, 00000100) 1024 KB P29: dsp_b (00025EF6, 00002000) 32 MB P30: keymaster_b (00027EF6, 00000080) 512 KB P31: akmu_b (00027F76, 00000080) 512 KB P32: boot_b (00027FF6, 00004000) 64 MB P33: cmnlib_b (0002BFF6, 00000080) 512 KB P34: cmnlib64_b (0002C076, 00000080) 512 KB P35: devcfg_b (0002C0F6, 00000020) 128 KB P36: qupfw_b (0002C116, 00000020) 128 KB P37: laf_b (0002C136, 00003000) 48 MB P38: vbmeta_b (0002F136, 00000010) 64 KB P39: dtbo_b (0002F146, 00000800) 8 MB P40: storsec_b (0002F946, 00000020) 128 KB P41: raw_resources_b (0002F966, 00000800) 8 MB P42: sid_b (00030166, 00000080) 512 KB P43: sec (000301E6, 00000040) 256 KB P44: devinfo (00030226, 00000040) 256 KB P45: dip (00030266, 00000100) 1024 KB P46: apdp (00030366, 00000080) 512 KB P47: msadp (000303E6, 00000080) 512 KB P48: spunvm (00030466, 00000800) 8 MB P49: limits (00030C66, 00000001) 4 KB P50: toolsfv (00030C67, 00000100) 1024 KB P51: logfs (00030D67, 00000800) 8 MB P52: sti (00031567, 00000200) 2048 KB P53: logdump (00031767, 00004000) 64 MB Physical partition number: 5 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_2 (00000006, 0000001A) 104 KB P02: modemst1 (00000020, 00000200) 2048 KB P03: modemst2 (00000220, 00000200) 2048 KB P04: fsg (00000420, 00000200) 2048 KB P05: fsc (00000620, 00000080) 512 KB Physical partition number: 6 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: frp (00000006, 00000200) 2048 KB Save to C:/Program Files (x86)/Octoplus Pro JTAG Software/TOSHIBA THGAF8G9T43BAIRB0100 _Sun Mar 31 2019_19_06_15.mpt file... Physical partition number: 0 Reading partition userdata... ERROR[011]: Read error. At sector 3268358 Disconnected. |
04-01-2019, 09:14 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please, try to reconnect your device to USB 2.0 port version and try to read into *.bin file format. |
04-01-2019, 16:58 | #7 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | Device and box in USB 2.0 directly on motherboard. Same result. Real original USB cables. Nothing running in background. Nothing else plugged into USB (except wireless mouse). I can read and write other models like US998, etc no problem but with V350AWM always disconnect. Welcome to Octoplus Pro JTAG Software version 1.7.6. Started. Reader #0: Generic Usb Smart Card Reader 0 Model Settings: Interface : USB Brand : LG Model : V350AWM SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_V350AWM_USB_UFS.srf Core : Qualcomm SDM845 UFS Loader : QLoader_v1_LG Connecting... Sending loader...OK. Loader successfully initialized. INFO: Calling handler for getstorageinfo INFO: Device Total Logical Blocks: 0xeac800 INFO: Device Block Size in Bytes: 0x1000 INFO: Device Total Physical Partitions: 0x7 INFO: Device Manufacturer ID: 0x198 INFO: Device Serial Number: 0x48494241 INFO: {"storage_info": {"total_blocks":15386624, "block_size":4096, "page_size":4096, "num_physical":7, "manufacturer_id":408, "serial_num":1212760641, "fw_version":"100","mem_type":"UFS","prod_name":"T HGAF8G9T43BAIRB0100"}} INFO: UFS fInitialized: 0x1 INFO: UFS Current LUN Number: = 0x0 INFO: UFS Total Active LU: 0x7 INFO: UFS wManufacturerID: 0x198 INFO: UFS Boot Partition Enabled: 0x1 INFO: UFS Raw Device Capacity: = 0x7738000 INFO: UFS Min Block Size: 0x8 INFO: UFS Erase Block Size: 0x2000 INFO: UFS Allocation Unit Size: 0x1 INFO: UFS RPMB ReadWrite Size: = 0x40 INFO: UFS Number of Allocation Uint for This LU: 0x3ab2 INFO: UFS Logical Block Size: 0xc INFO: UFS Provisioning Type: 0x2 INFO: UFS LU Write Protect: 0x0 INFO: UFS Boot LUN ID: = 0x0 INFO: UFS Memory Type: 0x0 INFO: UFS LU Total Blocks: 0xeac800 INFO: UFS Supported Memory Types: 0x801f INFO: UFS dEnhanced1MaxNAllocU: 0x3b9c INFO: UFS wEnhanced1CapAdjFac: 0x300 INFO: UFS dEnhanced2MaxNAllocU: = 0x60 INFO: UFS wEnhanced2CapAdjFac: 0x300 INFO: UFS dEnhanced3MaxNAllocU: 0x0 INFO: UFS wEnhanced3CapAdjFac: 0x0 INFO: UFS dEnhanced4MaxNAllocU: 0x0 INFO: UFS wEnhanced4CapAdjFac: 0x0 INFO: UFS LUN Enable Bitmask: 0x7f INFO: UFS Logical Block Count: 0xeac800 INFO: UFS bConfigDescrLock: 0x0 INFO: UFS iManufacturerName String Index: 0x1 INFO: UFS iProductName String Index: 0x2 INFO: UFS iSerialNumber String Index: 0x3 INFO: UFS iOemID String Index: 0x4 INFO: UFS Inquiry Command Output: TOSHIBA THGAF8G9T43BAIRB0100 e=false ACK Device : TOSHIBA THGAF8G9T43BAIRB0100 Core : Qualcomm SDM845 UFS Page size : 4096 B Block size : 4096 B Block count : 15618048 Size : 59.58 GB (61008.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. Physical partition number: 0 Block count : 15386624 (0xEAC800) Size : 58.70 GB (60104.00 MB) P00: GPT (00000000, 00000006) 24 KB P01: mpt (00000006, 00002000) 32 MB P02: drm (00002006, 00000E00) 14 MB P03: sns (00002E06, 00000600) 6 MB P04: ssd (00003406, 00000080) 512 KB P05: persist (00003486, 00002000) 32 MB P06: misc (00005486, 00000100) 1024 KB P07: ftm (00005586, 00002000) 32 MB P08: power (00007586, 00002C00) 44 MB P09: encrypt (0000A186, 00000080) 512 KB P10: eksst (0000A206, 00000080) 512 KB P11: rct (0000A286, 00000080) 512 KB P12: fota (0000A306, 00000A00) 10 MB P13: srtc (0000AD06, 00000800) 8 MB P14: pstore (0000B506, 00000200) 2048 KB P15: els (0000B706, 00001000) 16 MB P16: carrier (0000C706, 00002800) 40 MB P17: persdata (0000EF06, 00004000) 64 MB P18: oem_a (00012F06, 00000800) 8 MB P19: oem_b (00013706, 00000800) 8 MB P20: vendor_a (00013F06, 0003E800) 1000 MB P21: vendor_b (00052706, 0003E800) 1000 MB P22: system_a (00090F06, 0011B800) 4.43 GB P23: system_b (001AC706, 0011B800) 4.43 GB P24: OP_a (002C7F06, 00028A00) 650 MB P25: OP_b (002F0906, 00028A00) 650 MB P26: userdata (00319306, 00B934F4) 46.3 GB P27: grow (00EAC7FA, 00000001) 4 KB Physical partition number: 1 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_a (00000006, 00000380) 3584 KB P02: xbl_config_a (00000386, 00000020) 128 KB Physical partition number: 2 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_b (00000006, 00000380) 3584 KB P02: xbl_config_b (00000386, 00000020) 128 KB Physical partition number: 3 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_1 (00000006, 0000001A) 104 KB P02: cdt (00000020, 00000020) 128 KB P03: ddr (00000040, 00000100) 1024 KB Physical partition number: 4 Block count : 221184 (0x36000) Size : 864.00 MB P00: GPT (00000000, 00000006) 24 KB P01: aop_a (00000006, 00000080) 512 KB P02: tz_a (00000086, 00000200) 2048 KB P03: hyp_a (00000286, 00000080) 512 KB P04: modem_a (00000306, 0000B600) 182 MB P05: mdtpsecapp_a (0000B906, 00000400) 4 MB P06: mdtp_a (0000BD06, 00002000) 32 MB P07: abl_a (0000DD06, 00000100) 1024 KB P08: dsp_a (0000DE06, 00002000) 32 MB P09: keymaster_a (0000FE06, 00000080) 512 KB P10: akmu_a (0000FE86, 00000080) 512 KB P11: boot_a (0000FF06, 00004000) 64 MB P12: cmnlib_a (00013F06, 00000080) 512 KB P13: cmnlib64_a (00013F86, 00000080) 512 KB P14: devcfg_a (00014006, 00000020) 128 KB P15: qupfw_a (00014026, 00000020) 128 KB P16: laf_a (00014046, 00003000) 48 MB P17: vbmeta_a (00017046, 00000010) 64 KB P18: dtbo_a (00017056, 00000800) 8 MB P19: storsec_a (00017856, 00000020) 128 KB P20: raw_resources_a (00017876, 00000800) 8 MB P21: sid_a (00018076, 00000080) 512 KB P22: aop_b (000180F6, 00000080) 512 KB P23: tz_b (00018176, 00000200) 2048 KB P24: hyp_b (00018376, 00000080) 512 KB P25: modem_b (000183F6, 0000B600) 182 MB P26: mdtpsecapp_b (000239F6, 00000400) 4 MB P27: mdtp_b (00023DF6, 00002000) 32 MB P28: abl_b (00025DF6, 00000100) 1024 KB P29: dsp_b (00025EF6, 00002000) 32 MB P30: keymaster_b (00027EF6, 00000080) 512 KB P31: akmu_b (00027F76, 00000080) 512 KB P32: boot_b (00027FF6, 00004000) 64 MB P33: cmnlib_b (0002BFF6, 00000080) 512 KB P34: cmnlib64_b (0002C076, 00000080) 512 KB P35: devcfg_b (0002C0F6, 00000020) 128 KB P36: qupfw_b (0002C116, 00000020) 128 KB P37: laf_b (0002C136, 00003000) 48 MB P38: vbmeta_b (0002F136, 00000010) 64 KB P39: dtbo_b (0002F146, 00000800) 8 MB P40: storsec_b (0002F946, 00000020) 128 KB P41: raw_resources_b (0002F966, 00000800) 8 MB P42: sid_b (00030166, 00000080) 512 KB P43: sec (000301E6, 00000040) 256 KB P44: devinfo (00030226, 00000040) 256 KB P45: dip (00030266, 00000100) 1024 KB P46: apdp (00030366, 00000080) 512 KB P47: msadp (000303E6, 00000080) 512 KB P48: spunvm (00030466, 00000800) 8 MB P49: limits (00030C66, 00000001) 4 KB P50: toolsfv (00030C67, 00000100) 1024 KB P51: logfs (00030D67, 00000800) 8 MB P52: sti (00031567, 00000200) 2048 KB P53: logdump (00031767, 00004000) 64 MB Physical partition number: 5 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_2 (00000006, 0000001A) 104 KB P02: modemst1 (00000020, 00000200) 2048 KB P03: modemst2 (00000220, 00000200) 2048 KB P04: fsg (00000420, 00000200) 2048 KB P05: fsc (00000620, 00000080) 512 KB Physical partition number: 6 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: frp (00000006, 00000200) 2048 KB Save to C:/Program Files (x86)/Octoplus Pro JTAG Software file... Physical partition number: 0 Reading partition carrier... Done. Reading is finished. SW: 1.7.6; FW: 1.24. Save to C:/Program Files (x86)/Octoplus Pro JTAG Software file... Physical partition number: 0 Reading partition userdata... ERROR[011]: Read error. At sector 3306246 Disconnected. |
04-01-2019, 17:12 | #8 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | Welcome to Octoplus Pro JTAG Software version 1.7.6. Started. Reader #0: Generic Usb Smart Card Reader 0 Model Settings: Interface : USB Brand : LG Model : V350AWM SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_V350AWM_USB_UFS.srf Core : Qualcomm SDM845 UFS Loader : QLoader_v1_LG Connecting... Sending loader...OK. Loader successfully initialized. INFO: Calling handler for getstorageinfo INFO: Device Total Logical Blocks: 0xeac800 INFO: Device Block Size in Bytes: 0x1000 INFO: Device Total Physical Partitions: 0x7 INFO: Device Manufacturer ID: 0x198 INFO: Device Serial Number: 0x48494241 INFO: {"storage_info": {"total_blocks":15386624, "block_size":4096, "page_size":4096, "num_physical":7, "manufacturer_id":408, "serial_num":1212760641, "fw_version":"100","mem_type":"UFS","prod_name":"T HGAF8G9T43BAIRB0100"}} INFO: UFS fInitialized: 0x1 INFO: UFS Current LUN Number: = 0x0 INFO: UFS Total Active LU: 0x7 INFO: UFS wManufacturerID: 0x198 INFO: UFS Boot Partition Enabled: 0x1 INFO: UFS Raw Device Capacity: = 0x7738000 INFO: UFS Min Block Size: 0x8 INFO: UFS Erase Block Size: 0x2000 INFO: UFS Allocation Unit Size: 0x1 INFO: UFS RPMB ReadWrite Size: = 0x40 INFO: UFS Number of Allocation Uint for This LU: 0x3ab2 INFO: UFS Logical Block Size: 0xc INFO: UFS Provisioning Type: 0x2 INFO: UFS LU Write Protect: 0x0 INFO: UFS Boot LUN ID: = 0x0 INFO: UFS Memory Type: 0x0 INFO: UFS LU Total Blocks: 0xeac800 INFO: UFS Supported Memory Types: 0x801f INFO: UFS dEnhanced1MaxNAllocU: 0x3b9c INFO: UFS wEnhanced1CapAdjFac: 0x300 INFO: UFS dEnhanced2MaxNAllocU: = 0x60 INFO: UFS wEnhanced2CapAdjFac: 0x300 INFO: UFS dEnhanced3MaxNAllocU: 0x0 INFO: UFS wEnhanced3CapAdjFac: 0x0 INFO: UFS dEnhanced4MaxNAllocU: 0x0 INFO: UFS wEnhanced4CapAdjFac: 0x0 INFO: UFS LUN Enable Bitmask: 0x7f INFO: UFS Logical Block Count: 0xeac800 INFO: UFS bConfigDescrLock: 0x0 INFO: UFS iManufacturerName String Index: 0x1 INFO: UFS iProductName String Index: 0x2 INFO: UFS iSerialNumber String Index: 0x3 INFO: UFS iOemID String Index: 0x4 INFO: UFS Inquiry Command Output: TOSHIBA THGAF8G9T43BAIRB0100 ACK e=false Device : TOSHIBA THGAF8G9T43BAIRB0100 Core : Qualcomm SDM845 UFS Page size : 4096 B Block size : 4096 B Block count : 15618048 Size : 59.58 GB (61008.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. Physical partition number: 0 Block count : 15386624 (0xEAC800) Size : 58.70 GB (60104.00 MB) P00: GPT (00000000, 00000006) 24 KB P01: mpt (00000006, 00002000) 32 MB P02: drm (00002006, 00000E00) 14 MB P03: sns (00002E06, 00000600) 6 MB P04: ssd (00003406, 00000080) 512 KB P05: persist (00003486, 00002000) 32 MB P06: misc (00005486, 00000100) 1024 KB P07: ftm (00005586, 00002000) 32 MB P08: power (00007586, 00002C00) 44 MB P09: encrypt (0000A186, 00000080) 512 KB P10: eksst (0000A206, 00000080) 512 KB P11: rct (0000A286, 00000080) 512 KB P12: fota (0000A306, 00000A00) 10 MB P13: srtc (0000AD06, 00000800) 8 MB P14: pstore (0000B506, 00000200) 2048 KB P15: els (0000B706, 00001000) 16 MB P16: carrier (0000C706, 00002800) 40 MB P17: persdata (0000EF06, 00004000) 64 MB P18: oem_a (00012F06, 00000800) 8 MB P19: oem_b (00013706, 00000800) 8 MB P20: vendor_a (00013F06, 0003E800) 1000 MB P21: vendor_b (00052706, 0003E800) 1000 MB P22: system_a (00090F06, 0011B800) 4.43 GB P23: system_b (001AC706, 0011B800) 4.43 GB P24: OP_a (002C7F06, 00028A00) 650 MB P25: OP_b (002F0906, 00028A00) 650 MB P26: userdata (00319306, 00B934F4) 46.3 GB P27: grow (00EAC7FA, 00000001) 4 KB Physical partition number: 1 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_a (00000006, 00000380) 3584 KB P02: xbl_config_a (00000386, 00000020) 128 KB Physical partition number: 2 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_b (00000006, 00000380) 3584 KB P02: xbl_config_b (00000386, 00000020) 128 KB Physical partition number: 3 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_1 (00000006, 0000001A) 104 KB P02: cdt (00000020, 00000020) 128 KB P03: ddr (00000040, 00000100) 1024 KB Physical partition number: 4 Block count : 221184 (0x36000) Size : 864.00 MB P00: GPT (00000000, 00000006) 24 KB P01: aop_a (00000006, 00000080) 512 KB P02: tz_a (00000086, 00000200) 2048 KB P03: hyp_a (00000286, 00000080) 512 KB P04: modem_a (00000306, 0000B600) 182 MB P05: mdtpsecapp_a (0000B906, 00000400) 4 MB P06: mdtp_a (0000BD06, 00002000) 32 MB P07: abl_a (0000DD06, 00000100) 1024 KB P08: dsp_a (0000DE06, 00002000) 32 MB P09: keymaster_a (0000FE06, 00000080) 512 KB P10: akmu_a (0000FE86, 00000080) 512 KB P11: boot_a (0000FF06, 00004000) 64 MB P12: cmnlib_a (00013F06, 00000080) 512 KB P13: cmnlib64_a (00013F86, 00000080) 512 KB P14: devcfg_a (00014006, 00000020) 128 KB P15: qupfw_a (00014026, 00000020) 128 KB P16: laf_a (00014046, 00003000) 48 MB P17: vbmeta_a (00017046, 00000010) 64 KB P18: dtbo_a (00017056, 00000800) 8 MB P19: storsec_a (00017856, 00000020) 128 KB P20: raw_resources_a (00017876, 00000800) 8 MB P21: sid_a (00018076, 00000080) 512 KB P22: aop_b (000180F6, 00000080) 512 KB P23: tz_b (00018176, 00000200) 2048 KB P24: hyp_b (00018376, 00000080) 512 KB P25: modem_b (000183F6, 0000B600) 182 MB P26: mdtpsecapp_b (000239F6, 00000400) 4 MB P27: mdtp_b (00023DF6, 00002000) 32 MB P28: abl_b (00025DF6, 00000100) 1024 KB P29: dsp_b (00025EF6, 00002000) 32 MB P30: keymaster_b (00027EF6, 00000080) 512 KB P31: akmu_b (00027F76, 00000080) 512 KB P32: boot_b (00027FF6, 00004000) 64 MB P33: cmnlib_b (0002BFF6, 00000080) 512 KB P34: cmnlib64_b (0002C076, 00000080) 512 KB P35: devcfg_b (0002C0F6, 00000020) 128 KB P36: qupfw_b (0002C116, 00000020) 128 KB P37: laf_b (0002C136, 00003000) 48 MB P38: vbmeta_b (0002F136, 00000010) 64 KB P39: dtbo_b (0002F146, 00000800) 8 MB P40: storsec_b (0002F946, 00000020) 128 KB P41: raw_resources_b (0002F966, 00000800) 8 MB P42: sid_b (00030166, 00000080) 512 KB P43: sec (000301E6, 00000040) 256 KB P44: devinfo (00030226, 00000040) 256 KB P45: dip (00030266, 00000100) 1024 KB P46: apdp (00030366, 00000080) 512 KB P47: msadp (000303E6, 00000080) 512 KB P48: spunvm (00030466, 00000800) 8 MB P49: limits (00030C66, 00000001) 4 KB P50: toolsfv (00030C67, 00000100) 1024 KB P51: logfs (00030D67, 00000800) 8 MB P52: sti (00031567, 00000200) 2048 KB P53: logdump (00031767, 00004000) 64 MB Physical partition number: 5 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_2 (00000006, 0000001A) 104 KB P02: modemst1 (00000020, 00000200) 2048 KB P03: modemst2 (00000220, 00000200) 2048 KB P04: fsg (00000420, 00000200) 2048 KB P05: fsc (00000620, 00000080) 512 KB Physical partition number: 6 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: frp (00000006, 00000200) 2048 KB Physical partition number: 0 Added partition GPT to constructor file. Physical partition number: 0 Added partition mpt to constructor file. Physical partition number: 0 Added partition drm to constructor file. Physical partition number: 0 Added partition sns to constructor file. Physical partition number: 0 Added partition ssd to constructor file. Physical partition number: 0 Added partition persist to constructor file. Physical partition number: 0 Added partition misc to constructor file. Physical partition number: 0 ERROR[011]: Read error. At sector 25990 Disconnected. |
04-01-2019, 17:34 | #9 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | Welcome to Octoplus Pro JTAG Software version 1.7.5. Started. Reader #0: Generic Usb Smart Card Reader 0 Model Settings: Interface : USB Brand : LG Model : V350AWM SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_V350AWM_USB_UFS.srf Core : Qualcomm SDM845 UFS Loader : QLoader_v1_LG Connecting... Sending loader...OK. Loader successfully initialized. INFO: Calling handler for getstorageinfo INFO: Device Total Logical Blocks: 0xeac800 INFO: Device Block Size in Bytes: 0x1000 INFO: Device Total Physical Partitions: 0x7 INFO: Device Manufacturer ID: 0x198 INFO: Device Serial Number: 0x48494241 INFO: {"storage_info": {"total_blocks":15386624, "block_size":4096, "page_size":4096, "num_physical":7, "manufacturer_id":408, "serial_num":1212760641, "fw_version":"100","mem_type":"UFS","prod_name":"T HGAF8G9T43BAIRB0100"}} INFO: UFS fInitialized: 0x1 INFO: UFS Current LUN Number: = 0x0 INFO: UFS Total Active LU: 0x7 INFO: UFS wManufacturerID: 0x198 INFO: UFS Boot Partition Enabled: 0x1 INFO: UFS Raw Device Capacity: = 0x7738000 INFO: UFS Min Block Size: 0x8 INFO: UFS Erase Block Size: 0x2000 INFO: UFS Allocation Unit Size: 0x1 INFO: UFS RPMB ReadWrite Size: = 0x40 INFO: UFS Number of Allocation Uint for This LU: 0x3ab2 INFO: UFS Logical Block Size: 0xc INFO: UFS Provisioning Type: 0x2 INFO: UFS LU Write Protect: 0x0 INFO: UFS Boot LUN ID: = 0x0 INFO: UFS Memory Type: 0x0 INFO: UFS LU Total Blocks: 0xeac800 INFO: UFS Supported Memory Types: 0x801f INFO: UFS dEnhanced1MaxNAllocU: 0x3b9c INFO: UFS wEnhanced1CapAdjFac: 0x300 INFO: UFS dEnhanced2MaxNAllocU: = 0x60 INFO: UFS wEnhanced2CapAdjFac: 0x300 INFO: UFS dEnhanced3MaxNAllocU: 0x0 INFO: UFS wEnhanced3CapAdjFac: 0x0 INFO: UFS dEnhanced4MaxNAllocU: 0x0 INFO: UFS wEnhanced4CapAdjFac: 0x0 INFO: UFS LUN Enable Bitmask: 0x7f INFO: UFS Logical Block Count: 0xeac800 INFO: UFS bConfigDescrLock: 0x0 INFO: UFS iManufacturerName String Index: 0x1 INFO: UFS iProductName String Index: 0x2 INFO: UFS iSerialNumber String Index: 0x3 INFO: UFS iOemID String Index: 0x4 INFO: UFS Inquiry Command Output: TOSHIBA THGAF8G9T43BAIRB0100 ACK e=false Device : TOSHIBA THGAF8G9T43BAIRB0100 Core : Qualcomm SDM845 UFS Page size : 4096 B Block size : 4096 B Block count : 15618048 Size : 59.58 GB (61008.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.7.5; FW: . Physical partition number: 0 Block count : 15386624 (0xEAC800) Size : 58.70 GB (60104.00 MB) P00: GPT (00000000, 00000006) 24 KB P01: mpt (00000006, 00002000) 32 MB P02: drm (00002006, 00000E00) 14 MB P03: sns (00002E06, 00000600) 6 MB P04: ssd (00003406, 00000080) 512 KB P05: persist (00003486, 00002000) 32 MB P06: misc (00005486, 00000100) 1024 KB P07: ftm (00005586, 00002000) 32 MB P08: power (00007586, 00002C00) 44 MB P09: encrypt (0000A186, 00000080) 512 KB P10: eksst (0000A206, 00000080) 512 KB P11: rct (0000A286, 00000080) 512 KB P12: fota (0000A306, 00000A00) 10 MB P13: srtc (0000AD06, 00000800) 8 MB P14: pstore (0000B506, 00000200) 2048 KB P15: els (0000B706, 00001000) 16 MB P16: carrier (0000C706, 00002800) 40 MB P17: persdata (0000EF06, 00004000) 64 MB P18: oem_a (00012F06, 00000800) 8 MB P19: oem_b (00013706, 00000800) 8 MB P20: vendor_a (00013F06, 0003E800) 1000 MB P21: vendor_b (00052706, 0003E800) 1000 MB P22: system_a (00090F06, 0011B800) 4.43 GB P23: system_b (001AC706, 0011B800) 4.43 GB P24: OP_a (002C7F06, 00028A00) 650 MB P25: OP_b (002F0906, 00028A00) 650 MB P26: userdata (00319306, 00B934F4) 46.3 GB P27: grow (00EAC7FA, 00000001) 4 KB Physical partition number: 1 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_a (00000006, 00000380) 3584 KB P02: xbl_config_a (00000386, 00000020) 128 KB Physical partition number: 2 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_b (00000006, 00000380) 3584 KB P02: xbl_config_b (00000386, 00000020) 128 KB Physical partition number: 3 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_1 (00000006, 0000001A) 104 KB P02: cdt (00000020, 00000020) 128 KB P03: ddr (00000040, 00000100) 1024 KB Physical partition number: 4 Block count : 221184 (0x36000) Size : 864.00 MB P00: GPT (00000000, 00000006) 24 KB P01: aop_a (00000006, 00000080) 512 KB P02: tz_a (00000086, 00000200) 2048 KB P03: hyp_a (00000286, 00000080) 512 KB P04: modem_a (00000306, 0000B600) 182 MB P05: mdtpsecapp_a (0000B906, 00000400) 4 MB P06: mdtp_a (0000BD06, 00002000) 32 MB P07: abl_a (0000DD06, 00000100) 1024 KB P08: dsp_a (0000DE06, 00002000) 32 MB P09: keymaster_a (0000FE06, 00000080) 512 KB P10: akmu_a (0000FE86, 00000080) 512 KB P11: boot_a (0000FF06, 00004000) 64 MB P12: cmnlib_a (00013F06, 00000080) 512 KB P13: cmnlib64_a (00013F86, 00000080) 512 KB P14: devcfg_a (00014006, 00000020) 128 KB P15: qupfw_a (00014026, 00000020) 128 KB P16: laf_a (00014046, 00003000) 48 MB P17: vbmeta_a (00017046, 00000010) 64 KB P18: dtbo_a (00017056, 00000800) 8 MB P19: storsec_a (00017856, 00000020) 128 KB P20: raw_resources_a (00017876, 00000800) 8 MB P21: sid_a (00018076, 00000080) 512 KB P22: aop_b (000180F6, 00000080) 512 KB P23: tz_b (00018176, 00000200) 2048 KB P24: hyp_b (00018376, 00000080) 512 KB P25: modem_b (000183F6, 0000B600) 182 MB P26: mdtpsecapp_b (000239F6, 00000400) 4 MB P27: mdtp_b (00023DF6, 00002000) 32 MB P28: abl_b (00025DF6, 00000100) 1024 KB P29: dsp_b (00025EF6, 00002000) 32 MB P30: keymaster_b (00027EF6, 00000080) 512 KB P31: akmu_b (00027F76, 00000080) 512 KB P32: boot_b (00027FF6, 00004000) 64 MB P33: cmnlib_b (0002BFF6, 00000080) 512 KB P34: cmnlib64_b (0002C076, 00000080) 512 KB P35: devcfg_b (0002C0F6, 00000020) 128 KB P36: qupfw_b (0002C116, 00000020) 128 KB P37: laf_b (0002C136, 00003000) 48 MB P38: vbmeta_b (0002F136, 00000010) 64 KB P39: dtbo_b (0002F146, 00000800) 8 MB P40: storsec_b (0002F946, 00000020) 128 KB P41: raw_resources_b (0002F966, 00000800) 8 MB P42: sid_b (00030166, 00000080) 512 KB P43: sec (000301E6, 00000040) 256 KB P44: devinfo (00030226, 00000040) 256 KB P45: dip (00030266, 00000100) 1024 KB P46: apdp (00030366, 00000080) 512 KB P47: msadp (000303E6, 00000080) 512 KB P48: spunvm (00030466, 00000800) 8 MB P49: limits (00030C66, 00000001) 4 KB P50: toolsfv (00030C67, 00000100) 1024 KB P51: logfs (00030D67, 00000800) 8 MB P52: sti (00031567, 00000200) 2048 KB P53: logdump (00031767, 00004000) 64 MB Physical partition number: 5 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_2 (00000006, 0000001A) 104 KB P02: modemst1 (00000020, 00000200) 2048 KB P03: modemst2 (00000220, 00000200) 2048 KB P04: fsg (00000420, 00000200) 2048 KB P05: fsc (00000620, 00000080) 512 KB Physical partition number: 6 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: frp (00000006, 00000200) 2048 KB Physical partition number: 0 Added partition GPT to constructor file. Physical partition number: 0 Added partition mpt to constructor file. Physical partition number: 0 Added partition drm to constructor file. Physical partition number: 0 Added partition sns to constructor file. Physical partition number: 0 Added partition ssd to constructor file. Physical partition number: 0 Added partition persist to constructor file. Physical partition number: 0 Added partition misc to constructor file. Physical partition number: 0 ERROR[011]: Read error. At sector 23942 Disconnected. |
05-01-2019, 18:01 | #13 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | Is there some partitions in LG V35/V40 not possible to read? Like read protected? I'm trying with many cables, many computers, different smart card readers. It gives read error. Maybe 1/10 chance I can read 1GB without it disconnecting. |
05-01-2019, 18:02 | #14 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | Welcome to Octoplus Pro JTAG Software version 1.7.5. Started. Reader #0: Generic Usb Smart Card Reader 0 Model Settings: Interface : USB Brand : LG Model : V350AWM SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_V350AWM_USB_UFS.srf Core : Qualcomm SDM845 UFS Loader : QLoader_v1_LG Connecting... Sending loader...OK. Loader successfully initialized. INFO: Calling handler for getstorageinfo INFO: Device Total Logical Blocks: 0xeac800 INFO: Device Block Size in Bytes: 0x1000 INFO: Device Total Physical Partitions: 0x7 INFO: Device Manufacturer ID: 0x198 INFO: Device Serial Number: 0x48494241 INFO: {"storage_info": {"total_blocks":15386624, "block_size":4096, "page_size":4096, "num_physical":7, "manufacturer_id":408, "serial_num":1212760641, "fw_version":"300","mem_type":"UFS","prod_name":"T HGAF8G9T43BAIRB0300"}} INFO: UFS fInitialized: 0x1 INFO: UFS Current LUN Number: = 0x0 INFO: UFS Total Active LU: 0x7 INFO: UFS wManufacturerID: 0x198 INFO: UFS Boot Partition Enabled: 0x1 INFO: UFS Raw Device Capacity: = 0x7738000 INFO: UFS Min Block Size: 0x8 INFO: UFS Erase Block Size: 0x2000 INFO: UFS Allocation Unit Size: 0x1 INFO: UFS RPMB ReadWrite Size: = 0x40 INFO: UFS Number of Allocation Uint for This LU: 0x3ab2 INFO: UFS Logical Block Size: 0xc INFO: UFS Provisioning Type: 0x2 INFO: UFS LU Write Protect: 0x0 INFO: UFS Boot LUN ID: = 0x0 INFO: UFS Memory Type: 0x0 INFO: UFS LU Total Blocks: 0xeac800 INFO: UFS Supported Memory Types: 0x801f INFO: UFS dEnhanced1MaxNAllocU: 0x3b9c INFO: UFS wEnhanced1CapAdjFac: 0x300 INFO: UFS dEnhanced2MaxNAllocU: = 0x60 INFO: UFS wEnhanced2CapAdjFac: 0x300 INFO: UFS dEnhanced3MaxNAllocU: 0x0 INFO: UFS wEnhanced3CapAdjFac: 0x0 INFO: UFS dEnhanced4MaxNAllocU: 0x0 INFO: UFS wEnhanced4CapAdjFac: 0x0 INFO: UFS LUN Enable Bitmask: 0x7f INFO: UFS Logical Block Count: 0xeac800 INFO: UFS bConfigDescrLock: 0x0 INFO: UFS iManufacturerName String Index: 0x1 INFO: UFS iProductName String Index: 0x2 INFO: UFS iSerialNumber String Index: 0x3 INFO: UFS iOemID String Index: 0x4 INFO: UFS Inquiry Command Output: TOSHIBA THGAF8G9T43BAIRB0300 ACK e=false Device : TOSHIBA THGAF8G9T43BAIRB0300 Core : Qualcomm SDM845 UFS Page size : 4096 B Block size : 4096 B Block count : 15618048 Size : 59.58 GB (61008.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.7.5; FW: 1.24. Physical partition number: 0 Block count : 15386624 (0xEAC800) Size : 58.70 GB (60104.00 MB) P00: GPT (00000000, 00000006) 24 KB P01: mpt (00000006, 00002000) 32 MB P02: drm (00002006, 00000E00) 14 MB P03: sns (00002E06, 00000600) 6 MB P04: ssd (00003406, 00000080) 512 KB P05: persist (00003486, 00002000) 32 MB P06: misc (00005486, 00000100) 1024 KB P07: ftm (00005586, 00002000) 32 MB P08: power (00007586, 00002C00) 44 MB P09: encrypt (0000A186, 00000080) 512 KB P10: eksst (0000A206, 00000080) 512 KB P11: rct (0000A286, 00000080) 512 KB P12: fota (0000A306, 00000A00) 10 MB P13: srtc (0000AD06, 00000800) 8 MB P14: pstore (0000B506, 00000200) 2048 KB P15: els (0000B706, 00001000) 16 MB P16: operatorlogging (0000C706, 00001000) 16 MB P17: eri (0000D706, 00000800) 8 MB P18: carrier (0000DF06, 00002800) 40 MB P19: persdata (00010706, 00004000) 64 MB P20: oem_a (00014706, 00000800) 8 MB P21: oem_b (00014F06, 00000800) 8 MB P22: vendor_a (00015706, 00048000) 1152 MB P23: vendor_b (0005D706, 00048000) 1152 MB P24: system_a (000A5706, 0011B800) 4.43 GB P25: system_b (001C0F06, 0011B800) 4.43 GB P26: OP_a (002DC706, 00028800) 648 MB P27: OP_b (00304F06, 00028800) 648 MB P28: userdata (0032D706, 00B7F0F4) 45.99 GB P29: grow (00EAC7FA, 00000001) 4 KB Physical partition number: 1 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_a (00000006, 00000380) 3584 KB P02: xbl_config_a (00000386, 00000020) 128 KB Physical partition number: 2 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_b (00000006, 00000380) 3584 KB P02: xbl_config_b (00000386, 00000020) 128 KB Physical partition number: 3 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_1 (00000006, 0000001A) 104 KB P02: cdt (00000020, 00000020) 128 KB P03: ddr (00000040, 00000100) 1024 KB Physical partition number: 4 Block count : 221184 (0x36000) Size : 864.00 MB P00: GPT (00000000, 00000006) 24 KB P01: aop_a (00000006, 00000080) 512 KB P02: tz_a (00000086, 00000200) 2048 KB P03: hyp_a (00000286, 00000080) 512 KB P04: modem_a (00000306, 0000B600) 182 MB P05: mdtpsecapp_a (0000B906, 00000400) 4 MB P06: mdtp_a (0000BD06, 00002000) 32 MB P07: abl_a (0000DD06, 00000100) 1024 KB P08: dsp_a (0000DE06, 00002000) 32 MB P09: keymaster_a (0000FE06, 00000080) 512 KB P10: akmu_a (0000FE86, 00000080) 512 KB P11: boot_a (0000FF06, 00004000) 64 MB P12: cmnlib_a (00013F06, 00000080) 512 KB P13: cmnlib64_a (00013F86, 00000080) 512 KB P14: devcfg_a (00014006, 00000020) 128 KB P15: qupfw_a (00014026, 00000020) 128 KB P16: laf_a (00014046, 00003000) 48 MB P17: vbmeta_a (00017046, 00000010) 64 KB P18: dtbo_a (00017056, 00000800) 8 MB P19: storsec_a (00017856, 00000020) 128 KB P20: raw_resources_a (00017876, 00000800) 8 MB P21: sid_a (00018076, 00000080) 512 KB P22: aop_b (000180F6, 00000080) 512 KB P23: tz_b (00018176, 00000200) 2048 KB P24: hyp_b (00018376, 00000080) 512 KB P25: modem_b (000183F6, 0000B600) 182 MB P26: mdtpsecapp_b (000239F6, 00000400) 4 MB P27: mdtp_b (00023DF6, 00002000) 32 MB P28: abl_b (00025DF6, 00000100) 1024 KB P29: dsp_b (00025EF6, 00002000) 32 MB P30: keymaster_b (00027EF6, 00000080) 512 KB P31: akmu_b (00027F76, 00000080) 512 KB P32: boot_b (00027FF6, 00004000) 64 MB P33: cmnlib_b (0002BFF6, 00000080) 512 KB P34: cmnlib64_b (0002C076, 00000080) 512 KB P35: devcfg_b (0002C0F6, 00000020) 128 KB P36: qupfw_b (0002C116, 00000020) 128 KB P37: laf_b (0002C136, 00003000) 48 MB P38: vbmeta_b (0002F136, 00000010) 64 KB P39: dtbo_b (0002F146, 00000800) 8 MB P40: storsec_b (0002F946, 00000020) 128 KB P41: raw_resources_b (0002F966, 00000800) 8 MB P42: sid_b (00030166, 00000080) 512 KB P43: sec (000301E6, 00000040) 256 KB P44: devinfo (00030226, 00000040) 256 KB P45: dip (00030266, 00000100) 1024 KB P46: apdp (00030366, 00000080) 512 KB P47: msadp (000303E6, 00000080) 512 KB P48: spunvm (00030466, 00000800) 8 MB P49: limits (00030C66, 00000001) 4 KB P50: toolsfv (00030C67, 00000100) 1024 KB P51: logfs (00030D67, 00000800) 8 MB P52: sti (00031567, 00000200) 2048 KB P53: logdump (00031767, 00004000) 64 MB Physical partition number: 5 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_2 (00000006, 0000001A) 104 KB P02: modemst1 (00000020, 00000200) 2048 KB P03: modemst2 (00000220, 00000200) 2048 KB P04: fsg (00000420, 00000200) 2048 KB P05: fsc (00000620, 00000080) 512 KB Physical partition number: 6 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: frp (00000006, 00000200) 2048 KB Save to C:/Program Files (x86)/Octoplus Pro JTAG Software/v40att file... Physical partition number: 0 Reading partition vendor_b... ERROR[011]: Read error. At sector 562950 Disconnected. |
05-01-2019, 18:07 | #15 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | Welcome to Octoplus Pro JTAG Software version 1.7.5. Started. Reader #0: Generic Usb Smart Card Reader 0 Model Settings: Interface : USB Brand : LG Model : V350AWM SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_V350AWM_USB_UFS.srf Core : Qualcomm SDM845 UFS Loader : QLoader_v1_LG Connecting... Sending loader...OK. Loader successfully initialized. INFO: Calling handler for getstorageinfo INFO: Device Total Logical Blocks: 0xeac800 INFO: Device Block Size in Bytes: 0x1000 INFO: Device Total Physical Partitions: 0x7 INFO: Device Manufacturer ID: 0x198 INFO: Device Serial Number: 0x48494241 INFO: {"storage_info": {"total_blocks":15386624, "block_size":4096, "page_size":4096, "num_physical":7, "manufacturer_id":408, "serial_num":1212760641, "fw_version":"300","mem_type":"UFS","prod_name":"T HGAF8G9T43BAIRB0300"}} INFO: UFS fInitialized: 0x1 INFO: UFS Current LUN Number: = 0x0 INFO: UFS Total Active LU: 0x7 INFO: UFS wManufacturerID: 0x198 INFO: UFS Boot Partition Enabled: 0x1 INFO: UFS Raw Device Capacity: = 0x7738000 INFO: UFS Min Block Size: 0x8 INFO: UFS Erase Block Size: 0x2000 INFO: UFS Allocation Unit Size: 0x1 INFO: UFS RPMB ReadWrite Size: = 0x40 INFO: UFS Number of Allocation Uint for This LU: 0x3ab2 INFO: UFS Logical Block Size: 0xc INFO: UFS Provisioning Type: 0x2 INFO: UFS LU Write Protect: 0x0 INFO: UFS Boot LUN ID: = 0x0 INFO: UFS Memory Type: 0x0 INFO: UFS LU Total Blocks: 0xeac800 INFO: UFS Supported Memory Types: 0x801f INFO: UFS dEnhanced1MaxNAllocU: 0x3b9c INFO: UFS wEnhanced1CapAdjFac: 0x300 INFO: UFS dEnhanced2MaxNAllocU: = 0x60 INFO: UFS wEnhanced2CapAdjFac: 0x300 INFO: UFS dEnhanced3MaxNAllocU: 0x0 INFO: UFS wEnhanced3CapAdjFac: 0x0 INFO: UFS dEnhanced4MaxNAllocU: 0x0 INFO: UFS wEnhanced4CapAdjFac: 0x0 INFO: UFS LUN Enable Bitmask: 0x7f INFO: UFS Logical Block Count: 0xeac800 INFO: UFS bConfigDescrLock: 0x0 INFO: UFS iManufacturerName String Index: 0x1 INFO: UFS iProductName String Index: 0x2 INFO: UFS iSerialNumber String Index: 0x3 INFO: UFS iOemID String Index: 0x4 INFO: UFS Inquiry Command Output: TOSHIBA THGAF8G9T43BAIRB0300 ACK e=false Device : TOSHIBA THGAF8G9T43BAIRB0300 Core : Qualcomm SDM845 UFS Page size : 4096 B Block size : 4096 B Block count : 15618048 Size : 59.58 GB (61008.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.7.5; FW: 1.24. Physical partition number: 0 Block count : 15386624 (0xEAC800) Size : 58.70 GB (60104.00 MB) P00: GPT (00000000, 00000006) 24 KB P01: mpt (00000006, 00002000) 32 MB P02: drm (00002006, 00000E00) 14 MB P03: sns (00002E06, 00000600) 6 MB P04: ssd (00003406, 00000080) 512 KB P05: persist (00003486, 00002000) 32 MB P06: misc (00005486, 00000100) 1024 KB P07: ftm (00005586, 00002000) 32 MB P08: power (00007586, 00002C00) 44 MB P09: encrypt (0000A186, 00000080) 512 KB P10: eksst (0000A206, 00000080) 512 KB P11: rct (0000A286, 00000080) 512 KB P12: fota (0000A306, 00000A00) 10 MB P13: srtc (0000AD06, 00000800) 8 MB P14: pstore (0000B506, 00000200) 2048 KB P15: els (0000B706, 00001000) 16 MB P16: operatorlogging (0000C706, 00001000) 16 MB P17: eri (0000D706, 00000800) 8 MB P18: carrier (0000DF06, 00002800) 40 MB P19: persdata (00010706, 00004000) 64 MB P20: oem_a (00014706, 00000800) 8 MB P21: oem_b (00014F06, 00000800) 8 MB P22: vendor_a (00015706, 00048000) 1152 MB P23: vendor_b (0005D706, 00048000) 1152 MB P24: system_a (000A5706, 0011B800) 4.43 GB P25: system_b (001C0F06, 0011B800) 4.43 GB P26: OP_a (002DC706, 00028800) 648 MB P27: OP_b (00304F06, 00028800) 648 MB P28: userdata (0032D706, 00B7F0F4) 45.99 GB P29: grow (00EAC7FA, 00000001) 4 KB Physical partition number: 1 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_a (00000006, 00000380) 3584 KB P02: xbl_config_a (00000386, 00000020) 128 KB Physical partition number: 2 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl_b (00000006, 00000380) 3584 KB P02: xbl_config_b (00000386, 00000020) 128 KB Physical partition number: 3 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_1 (00000006, 0000001A) 104 KB P02: cdt (00000020, 00000020) 128 KB P03: ddr (00000040, 00000100) 1024 KB Physical partition number: 4 Block count : 221184 (0x36000) Size : 864.00 MB P00: GPT (00000000, 00000006) 24 KB P01: aop_a (00000006, 00000080) 512 KB P02: tz_a (00000086, 00000200) 2048 KB P03: hyp_a (00000286, 00000080) 512 KB P04: modem_a (00000306, 0000B600) 182 MB P05: mdtpsecapp_a (0000B906, 00000400) 4 MB P06: mdtp_a (0000BD06, 00002000) 32 MB P07: abl_a (0000DD06, 00000100) 1024 KB P08: dsp_a (0000DE06, 00002000) 32 MB P09: keymaster_a (0000FE06, 00000080) 512 KB P10: akmu_a (0000FE86, 00000080) 512 KB P11: boot_a (0000FF06, 00004000) 64 MB P12: cmnlib_a (00013F06, 00000080) 512 KB P13: cmnlib64_a (00013F86, 00000080) 512 KB P14: devcfg_a (00014006, 00000020) 128 KB P15: qupfw_a (00014026, 00000020) 128 KB P16: laf_a (00014046, 00003000) 48 MB P17: vbmeta_a (00017046, 00000010) 64 KB P18: dtbo_a (00017056, 00000800) 8 MB P19: storsec_a (00017856, 00000020) 128 KB P20: raw_resources_a (00017876, 00000800) 8 MB P21: sid_a (00018076, 00000080) 512 KB P22: aop_b (000180F6, 00000080) 512 KB P23: tz_b (00018176, 00000200) 2048 KB P24: hyp_b (00018376, 00000080) 512 KB P25: modem_b (000183F6, 0000B600) 182 MB P26: mdtpsecapp_b (000239F6, 00000400) 4 MB P27: mdtp_b (00023DF6, 00002000) 32 MB P28: abl_b (00025DF6, 00000100) 1024 KB P29: dsp_b (00025EF6, 00002000) 32 MB P30: keymaster_b (00027EF6, 00000080) 512 KB P31: akmu_b (00027F76, 00000080) 512 KB P32: boot_b (00027FF6, 00004000) 64 MB P33: cmnlib_b (0002BFF6, 00000080) 512 KB P34: cmnlib64_b (0002C076, 00000080) 512 KB P35: devcfg_b (0002C0F6, 00000020) 128 KB P36: qupfw_b (0002C116, 00000020) 128 KB P37: laf_b (0002C136, 00003000) 48 MB P38: vbmeta_b (0002F136, 00000010) 64 KB P39: dtbo_b (0002F146, 00000800) 8 MB P40: storsec_b (0002F946, 00000020) 128 KB P41: raw_resources_b (0002F966, 00000800) 8 MB P42: sid_b (00030166, 00000080) 512 KB P43: sec (000301E6, 00000040) 256 KB P44: devinfo (00030226, 00000040) 256 KB P45: dip (00030266, 00000100) 1024 KB P46: apdp (00030366, 00000080) 512 KB P47: msadp (000303E6, 00000080) 512 KB P48: spunvm (00030466, 00000800) 8 MB P49: limits (00030C66, 00000001) 4 KB P50: toolsfv (00030C67, 00000100) 1024 KB P51: logfs (00030D67, 00000800) 8 MB P52: sti (00031567, 00000200) 2048 KB P53: logdump (00031767, 00004000) 64 MB Physical partition number: 5 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: ALIGN_TO_128K_2 (00000006, 0000001A) 104 KB P02: modemst1 (00000020, 00000200) 2048 KB P03: modemst2 (00000220, 00000200) 2048 KB P04: fsg (00000420, 00000200) 2048 KB P05: fsc (00000620, 00000080) 512 KB Physical partition number: 6 Block count : 2048 (0x800) Size : 8.00 MB P00: GPT (00000000, 00000006) 24 KB P01: frp (00000006, 00000200) 2048 KB Save to C:/Program Files (x86)/Octoplus Pro JTAG Software/v40att file... Physical partition number: 0 Reading partition vendor_b... ERROR[011]: Read error. At sector 454406 Disconnected. |
