08-10-2017, 09:13 | #1 (permalink) |
Freak Poster Join Date: Jul 2012
Member: 1784601 Status: Offline Thanks Meter: 21 | Repair Samsung Galaxy Mega i9205 I want try to repair a Samsung galaxy mega gt-i9205, but in the Jtag Octoplus Box I can only find the i9200 version. The mobo seems the same. So, I want ask you if I can repair it or not. Thank you Inviato dal mio ASUS_Z017D utilizzando Tapatalk |
08-14-2017, 11:01 | #3 (permalink) |
Member: 1784601 Status: Offline Thanks Meter: 21 | I have try to repair but the box gave me this message Welcome to Octoplus JTAG Box Software version 1.9.5.4 Selected device model: Samsung GT-I9200 Connecting. Please wait... Checking data... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4BA00477, IR Length = 4. Detected TAP ID: 308930E1, IR Length = 11. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. JTAG speed : 1000 KHz. VREF level : 1.78 V CPU : Qualcomm MSM8930AB Core ID : 308930E1 ERROR[008]: Unknown flash device. Device No:ID = 0:00000000. ERROR[035]: Target device has been powered off during connect. Please connect the target device and power it on... Checking data... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. MI: Medusa JTAG init failed. ERROR[035]: Target device has been powered off during connect. Checking data... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4BA00477, IR Length = 4. Detected TAP ID: 308930E1, IR Length = 11. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. ERROR[000]: Unable to halt core. |
08-14-2017, 11:51 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | As You can see from Software log, JTAG is closed in your device: Quote:
Also, You can try to connect via eMMC and then do "Factory Repair". Note, to work with eMMC, You need to have Medusa Pro Box with 20-pin connector. Octoplus Box and old Medusa Box (not Pro) HWs don't support work with eMMC. Last edited by Octopus box; 08-14-2017 at 12:50. | |
08-14-2017, 12:13 | #5 (permalink) | |
Member: 1784601 Status: Offline Thanks Meter: 21 | I have try many times, and seems work, but after some minut I've got an error. I thinks maybe it's a problem of soldering...but the way It's not very easy to solder tiny wires to the jtag pads on the mobo Quote:
I don't have Medusa Pro. There are some discount? If I already have an Octoplus BOX? Thanks | |
08-14-2017, 12:52 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
Medusa PRO Upgrade Kit" - https://gsmserver.com/item/boxes-and...o-upgrade-kit/. No need to buy any additional activations. | |
