The tablet hangs on the Samsung logo. I connected via JTAG. There were all sections, I downloaded the first 512 MB, made a factor format, and downloaded the SRF file from the support zone, uploaded it to the tablet without the Write data verification checkbox, because if you write with this parameter, you get the error "Read / write verification error." Possible reasons: damaged or write protected eMMC ". The tablet now does not go into the download mode. How can I recover it? In the log from the support area, flash memory is not write protected, and in my memory there is write protection.
PHP Code:
Please disconnect battery and USB cable.
Selected device model: Samsung GT-N8000.
Selected file: D:/JPRO files/MODELS/Samsung GT-N8000/Samsung_GT-N8000_EMMC_MAG2GA.srf.
eMMC interface selected.
Connecting...
Page size : 512 b
Block size : 512 b
Block count : 30777344
Device : Samsung eMMC MAG2GA
CID Info
CID : 1501004D41473247410799E016B140E5
Manufacturer ID : 0X15
Device/BGA : BGA(Discrete embeded)
OEM/Application ID : 0X00
Product name : MAG2GA
Product revision : 0.7
Product serial number : (hex)99E016B1
Manufacturing date : 04/2013
CSD Info
CSD : D02701320F5903FFF6DBFFFF8A404007
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.5 (for MMC v4.41)
Boot1 size : 2048 Kbytes
Boot2 size : 2048 Kbytes
RPMB size : 128 Kbytes
Boot partition enable : Boot partition 1
Partition config : 01001000
Backup EXT_CSD saved to file D:/Projects/Octoplus_JTag/build/EXT_CSD Backups/MAG2GA_13_06_2016_16_36_56.bin.
Connect successful.
my log
PHP Code:
Model Settings:
Interface : eMMC
Brand : Samsung
Model : GT-N8000
SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_GT-N8000_EMMC_MAG2GA.srf
Voltage : 2.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
Size : 14.68 GB (15028.00 MB)
CID Info
Device/BGA : BGA (Discrete embedded)
Full name : KLMAG2GE2A-A001
Product serial number : (hex) 99E016B1
CSD Info
CSD : D02701320F5903FFF6DBFFFF8A406063
TRAN speed : 26 MHz
PERM_WRITE_PROTECT : YES
EXTCSD Info
Erase block size : 512 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 4Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x01) 00000001
Boot bus width : x4 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7659520 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
