04-27-2018, 05:49 | #1 (permalink) |
No Life Poster Join Date: Mar 2012 Location: BHANGLADESH
Member: 1741293 Status: Offline Sonork: 100.1664286 Thanks Meter: 131 | Samsung SM-G7102 "dead" boot repair done 100% OK Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 15010038574D4233520091055FB271E3 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 8WMB3R Product revision : 0.0 Product serial number : (hex) 91055FB2 Manufacturing date : 07/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2539520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 307840 Number of sectors : 3645440 Device Manufacturer :samsung Device Platform :msm8226 Build ID :JLS36C Display Build ID :JLS36C.G7102XXUANG2 Release ID :4.3 Device Model :SM-G7102 Device Name :ms013gxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :ms013gxx-user 4.3 JLS36C G7102XXUANG2 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/8WMB3R_27_04_2018_10_40_31.bin. Connect successful. |
The Following 4 Users Say Thank You to motin123 For This Useful Post: |
07-22-2018, 10:29 | #4 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. To repair Samsung SM-G7102 via eMMC, do the next steps: 1. Install the latest Medusa Pro Software version (Medusa Box Downloads - Software, Drivers, Manual). 2. Download and install SRF (Smart Repair File) "SAMSUNG_G7102_(TEST)_THANKS_TO_MR_MIRAZG.srf" for Samsung SM-G7102 ("Download *.srf" button in Software). 3. Select Samsung SM-G7102 in the Software list (model will appear in Software list after SFR installation). 4. Solder all necessary eMMC wires accordingly to the pinout picture ("Help" or "Pinout" button in Software, VCC pin - 2.8V, VCCQ pin - 1.8V pin). 5. Connect the device to box and press "Connect" button. 6. When device will be connected successfully, do "Smart Repair" ("Smart repair" button). 7. Post here the result. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
07-22-2018, 10:51 | #6 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | You can use Mesusa Pro Software or Octoplus Pro JTAG Software, they both have the same possibilities and You can use both of these Softwares with your Octoplus Pro Box. Quote:
