10-30-2018, 14:46 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Mars Age: 40
Member: 38084 Status: Offline Thanks Meter: 115 | Samsung SM-G900F repair question [Answered] Welcome to Medusa Pro Software version 1.6.5. Started. Reader #0: Generic EMV Smartcard Reader 0 Reader #1: Generic EMV Smartcard Reader 1 Reader #2: Generic EMV Smartcard Reader 2 Reader #3: Generic EMV Smartcard Reader 3 Reader #4: Generic EMV Smartcard Reader 4 Reader #5: Generic EMV Smartcard Reader 5 Reader #6: Generic EMV Smartcard Reader 6 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G900F SRF : D:/CELSW/OCTOPLUS/MEDUSA PRO/firmwareFolder/SAMSUNG_SM-G900F_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Unknown eMMC Page size : 512 B Block size : 512 B Block count : 1336067739 Size : 637.09 GB (652376.83 MB) --------------------------------------------------------------- CID Info CID : 3C3C00000000000000000000000000FB Manufacturer ID : 0X3C Device/BGA : Device (removable) OEM/Application ID : 0X00 Product name : Product revision : 0.0 Product serial number : (hex) 0 Manufacturing date : 00/2013 --------------------------------------------------------------- CSD Info CSD : 5A5A00000000000000000000000000E9 CSD structure : CSD version No. 1.1 SPEC version : Allocated by MMCA Data read access time1: 0.0005 ms TRAN speed : 0 MHz READ block length : 1 Bytes WP group enable : NO PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 64512 Kbytes Boot1 size : 4992 Kbytes Boot2 size : 4992 Kbytes RPMB size : 11264 Kbytes Partition config : (0x59) 01011001 Boot partition enable : Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x8F) 10001111 Boot bus width : Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : Use single data rate + High Speed timings in boot operation RST_n function : (0x02) RST_n signal is permanently disabled Max enhanced data size: 1507979264 Kbytes Partitions attribute : 0x86 Part setting completed: 0xA6 GP partition 1 size : 2812 MB GP partition 2 size : 1968 MB GP partition 3 size : 3244 MB GP partition 4 size : 788 MB Enhanced area size : (0x96400000) 2404 MB Enhanced area start : (0x7D8BC600) 2009 MB ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file D:/CELSW/OCTOPLUS/MEDUSA PRO/EXT_CSD Backups/_30_10_2018_14_40_17.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.5; FW: 1.24. Repairing from file "D:/CELSW/OCTOPLUS/MEDUSA PRO/firmwareFolder/SAMSUNG_SM-G900F_EMMC.srf". Write data verification is enabled. Writing GPT partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. Last edited by Octopus box; 10-30-2018 at 15:22. |
10-30-2018, 14:49 | #3 (permalink) |
Member: 38084 Status: Offline Thanks Meter: 115 | Selected pit file: D:/CEL/SAMSUNG/G900F S5/6.0.1_G900FXXS1CQD4_ITV/KLTE_EUR_OPEN_HIDDEN50M.pit Open file "D:/CEL/SAMSUNG/G900F S5/6.0.1_G900FXXS1CQD4_ITV/BL_G900FXXS1CQD4_CL9493471_QB13120509_REV00_user_l ow_ship_MULTI_CERT.tar.md5". Writing MBR... ERROR[012]: Write error. At sector 0. Disconnected. |
10-30-2018, 15:21 | #4 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As You can see from your Software log, You have not connected the device correctly or eMMC has HW problems - eMMC size (capacity) can't be 637.09 GB: Quote:
