Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus JTAG
Old 08-13-2018, 09:30   #1 (permalink)
Member: 2632063
Thanks Meter: 45
Samsung SM-J100H repair question [Answered]
Erasing and again smart repair, but same problem.
Old 08-13-2018, 09:43   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,715
Hello.
Try to do "Smart Repair" again without Boot1 partition (uncheck "Boot1") and post full Software log, not screenshot. Also after repairing, re-connect the device and post full Software log with the device info, we will check.
Old 08-14-2018, 13:44   #3 (permalink)
Member: 2632063
Thanks Meter: 45
ERROR[012]: Write error.
Started.
Reader #0: Generic EMV Smartcard Reader 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-J100H
SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Hynix eMMC H4G2b
Page size : 512 B
Block size : 512 B
Block count : 7634944
CID Info
CID : 90014A4834473262110145C3304B22B5
Manufacturer ID : 0X90
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4A
Product name : H4G2b
Product revision : 0.1
Product serial number : (hex) 45C3304B
Manufacturing date : 02/2015
CSD Info
CSD : D07F01320F5903FFFFFFFFEF8A4040DB
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 80 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.6 (for MMC v4.5, v4.51)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x08) 00001000
Boot partition enable : Boot partition 1
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 1908736 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Not found
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_14_08_2018_17_37_41.bin.
Connect successful.
SW: 1.6.5; FW: 1.24.
Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf".
Write data verification is enabled.
Switched to boot area partition 1.
Writing BOOT1 partition... Done.
Switched to user area.
Writing GPT partition... Done.
Writing SBOOT partition... Done.
Writing SBOOT2 partition... Done.
Writing wfixnv1 partition... Done.
Writing wfixnv2 partition... Done.
Writing tdfixnv1 partition... Done.
Writing tdfixnv2 partition... Done.
Writing WDSP partition... Done.
Writing MODEM partition... Done.
Writing MODEM2 partition... Done.
Writing TDDSP partition... Done.
Writing wruntimenv1 partition...
At sector 75776
Attempting to write...
Done.
Writing wruntimenv2 partition... Done.
Writing tdruntimenv1 partition... Done.
Writing tdruntimenv2 partition... Done.
Writing PARAM partition... Done.
Writing efs partition... Done.
Smart Repair is successfully complete.
Disconnected.
Old 08-14-2018, 14:21   #4 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,715
Do repair without BOOT1 and post here log.
Old 08-14-2018, 15:50   #5 (permalink)
Member: 1971793
Thanks Meter: 3
J100h usually die emmc, you should replace emmc
Old 08-15-2018, 14:23   #6 (permalink)
Member: 2632063
Thanks Meter: 45
Welcome to Medusa Pro Software version 1.6.5.
Started.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-J100H
SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.SRF
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Partition config : (0x48) 01001000
(Bus width = 1Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Not found
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_15_08_2018_18_21_48.bin.
Connect successful.
Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.SRF".
Read/write verification error. Possible reasons: damaged or write protected eMMC.
Disconnected.
Old 08-15-2018, 14:37   #7 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,715
This error:
means, that there is a problem with eMMC (it is damaged or write protected, this is usual problem with Hynix eMMC H4G2b) and Software can't write data correctly to it. In this case only the solution is a chip replacement.
Page generated in 0.30110 seconds with 7 queries
