11-17-2018, 17:56 | #1 (permalink) |
Insane Poster Join Date: Oct 2017
Member: 2771367 Status: Offline Thanks Meter: 16 | Samsung SM-J727VPP test point request [Answered] Last edited by Octopus box; 11-18-2018 at 12:38. |
11-18-2018, 12:38 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Unfortunately, at the moment we don't have eMMC ISP pinout for this device model. Here is eMMC pinout picture, which send us Mr. Quetzaltloani, for Samsung SM-J727P: https://www.4shared.com/photo/ODJwKwJHda/pinout.html It should be the same or similar for SM-J727VPP. Try to solder wires accordingly to this pinout picture and try to connect the device. Also You can remove eMMC chip from phone's PCB, solder necessary wires directly to eMMC chip contacts (or use proper eMMC adapter), do "Factory Repair" ("Factory repair" tab in Software) using proper PIT file and the latest available original Samsung firmware for this device model and then solder chip back to PCB. If You have enough experience, You can try to repair this device by this way. |
11-19-2018, 23:25 | #4 (permalink) |
Member: 2771367 Status: Offline Thanks Meter: 16 | Hello octopus good picture for points but I am doing everything I connect points and content to box don and get to factory repair Samsung factory repair I select pit and firmware 4file and writing portions to finished don after I see device not power am remove device from box and points connect with battery power on nothing the device still like before nothing download nothing boot nothing Qualcomm usb .tomorrow I will send log please tell me how to unbrick my device |
11-20-2018, 12:35 | #7 (permalink) |
Member: 2771367 Status: Offline Thanks Meter: 16 | Welcome to Octoplus Pro JTAG Software version 1.6.9. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100513331334242004691E41D8459 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) 4691E41D Manufacturing date : 08/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 6864896 Device Manufacturer :Verizon Device Platform :msm8953 Build ID :NRD90M Display Build ID :NRD90M.J727VPPVRU1AQK4 Release ID :7.0 Device Model :SM-J727VPP Device Name :j7popltevzwpp Architecture ABI :arm64-v8a Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi Build Description :j7popltevzwpp-user 7.0 NRD90M J727VPPVRU1AQK4 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/Q313BB_ظ،ظ©_ظ،ظ،_ظ¢ظ*ظ،ظ¨_ظ¢ظ¢_ظConnect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000400) 512 KB P04: rpm (00002C00, 00000400) 512 KB P05: tz (00003000, 00001000) 2048 KB P06: aboot (00004000, 00001000) 2048 KB P07: sec (00005000, 00000200) 256 KB P08: lksecapp (00005200, 00000400) 512 KB P09: keymaster (00005600, 00000400) 512 KB P10: cmnlib (00005A00, 00000200) 256 KB P11: fsg (00005C00, 00002000) 4 MB P12: cmnlib64 (00007C00, 00000200) 256 KB P13: pad (00007E00, 00000200) 256 KB P14: modemst1 (00008000, 00002000) 4 MB P15: modemst2 (0000A000, 00002000) 4 MB P16: efs (0000E000, 00008000) 16 MB P17: fsc (00016000, 00001A00) 3328 KB P18: ssd (00017A00, 00000200) 256 KB P19: devcfg (00017C00, 00000200) 256 KB P20: apdp (00017E00, 00000100) 128 KB P21: msadp (00017F00, 00000100) 128 KB P22: param (00018000, 00006000) 12 MB P23: backup (0001E000, 00002000) 4 MB P24: boot (00020000, 00010000) 32 MB P25: recovery (00030000, 00010000) 32 MB P26: bota (00040000, 00004000) 8 MB P27: fota (00044000, 00002000) 4 MB P28: persist (00046000, 00010000) 32 MB P29: persistent (00056000, 00000800) 1024 KB P30: steady (00056800, 00002000) 4 MB P31: keystore (00058800, 00000800) 1024 KB P32: config (00059000, 00000800) 1024 KB P33: dsp (00059800, 00008000) 16 MB P34: modem (00061800, 00030000) 96 MB P35: apnhlos (00091800, 00012000) 36 MB P36: reserved2 (000A3800, 00000800) 1024 KB P37: system (000A4000, 0068C000) 3352 MB P38: cache (00730000, 0012C000) 600 MB P39: carrier (0085C000, 00008000) 16 MB P40: userdata (00864000, 014F5FD8) 10.48 GB Selected pit file: C:/Users/Lifesecrat/Desktop/New Folder (3)/J7POP_USA_VZW.pit Open file "C:/Users/Lifesecrat/Desktop/New Folder (3)/AP_J727VVRU1AQF3_CL11702197_QB14088163_REV00_user_ low_ship_MULTI_CERT_meta.tar.md5". Open file "C:/Users/Lifesecrat/Desktop/New Folder (3)/BL_J727VVRU1AQF3_CL11702197_QB14088163_REV00_user_ low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/Lifesecrat/Desktop/New Folder (3)/CP_J727VVRU1AQF3_CP6766222_CL11702197_QB14088163_R EV00_user_low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/Lifesecrat/Desktop/New Folder (3)/CSC_VZW_J727VVZW1AQF3_CL11702197_QB14088163_REV00_ user_low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition SBL1... Done. Writing partition RPM... Done. Writing partition TZ... Done. Writing partition ABOOT... Done. Writing partition SEC... Done. Writing partition LKSECAPP... Done. Writing partition KEYMASTER... Done. Writing partition CMNLIB... Done. Writing partition DEVCFG... Done. Writing partition APDP... Done. Writing partition MSADP... Done. Writing partition BOOT... Done. Writing partition RECOVERY... Done. Writing partition PERSIST... Done. Writing partition DSP... Done. Writing partition MODEM... Done. Writing partition APNHLOS... Done. Writing partition SYSTEM... Done. Writing partition CACHE... Done. Writing is finished. SW: 1.6.9; FW: 1.24. Disconnected. |
11-20-2018, 12:54 | #8 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | As I see, there was firmware J727VPPVRU1AQK4 for SM-J727VPP in your device before repairing, but You have written firmware J727VVRU1AQF3 for SM-J727V. Try to use the same firmware as was in the device before (J727VPPVRU1AQK4) or try to use higher firmware version (J727VPPVRS2ARF1 or J727VPPVRS2ARC1) for "Factory Repair" operation. |
11-20-2018, 23:10 | #12 (permalink) |
Member: 2771367 Status: Offline Thanks Meter: 16 | Writing MBR... ERROR[012]: Write error. #redAt sector 0. This is my problem after connect tomorrow I will send you log please any fix for this I very tired from this device i |
