01-12-2017, 11:23 | #1 (permalink) |
Major Poster Join Date: Nov 2014 Location: Chakwal , punjab ,Pakistan
Member: 2299410 Status: Offline Thanks Meter: 10 | shv-e370k help needed Started. Reader #0: Generic EMV Smartcard Reader 0 Model Settings: Interface : JTAG Core : Qualcomm MSM8930AB Voltage : 1300 Reset : RESET, Halt After 100 ms Tap : Auto Speed : Auto Connecting... Vref level is 1.74V. Scan successfull, number of TAPs = 2. TAP 0: Id code = 4BA00477, IR length = 2. TAP 0: CPU name "Unknown", interface type = 0. TAP 11: WARNING: IR length mismatch, expected IR length = 0, scanned IR length = 0. TAP 1: Id code = 308930E1, IR length = 0. TAP 1: CPU name "Qualcomm MSM8930AB", interface type = 9. Enabling ARM Core... ERROR030Nothing found. Vref level is 1.74V. Nothing found. ERROR[001]: Can not connect. No target device present. Model Settings: Interface : JTAG Core : Qualcomm MSM8930AB Voltage : 1300 Reset : RESET, Halt After 100 ms Tap : Auto Speed : Auto Connecting... Vref level is 1.73V. Scan successfull, number of TAPs = 2. TAP 0: Id code = 4BA00477, IR length = 2. TAP 0: CPU name "Unknown", interface type = 0. TAP 11: WARNING: IR length mismatch, expected IR length = 0, scanned IR length = 0. TAP 1: Id code = 308930E1, IR length = 0. TAP 1: CPU name "Qualcomm MSM8930AB", interface type = 9. Enabling ARM Core... ERROR030Nothing found. Vref level is 1.73V. Nothing found. ERROR[001]: Can not connect. No target device present. Model Settings: Interface : JTAG Core : Qualcomm MSM8930AB Voltage : 1300 Reset : RESET, Halt After 100 ms Tap : Auto Speed : Auto Connecting... Vref level is 1.73V. Scan successfull, number of TAPs = 2. TAP 0: Id code = 4BA00477, IR length = 2. TAP 0: CPU name "Unknown", interface type = 0. TAP 11: WARNING: IR length mismatch, expected IR length = 0, scanned IR length = 0. TAP 1: Id code = 308930E1, IR length = 0. TAP 1: CPU name "Qualcomm MSM8930AB", interface type = 9. Enabling ARM Core... Nothing found. ERROR[002]: Unsupported device. Model Settings: Interface : JTAG Core : Qualcomm MSM8930AB Voltage : 1300 Reset : RESET, Halt After 100 ms Tap : Auto Speed : Auto Connecting... Vref level is 1.74V. Nothing found. Vref level is 1.74V. Nothing found. ERROR[001]: Can not connect. No target device present. Model Settings: Interface : JTAG Core : Qualcomm MSM8930AB Voltage : 1300 Reset : RESET, Halt After 100 ms Tap : Auto Speed : Auto Connecting... Vref level is 1.74V. Nothing found. Vref level is 1.74V. Nothing found. ERROR[001]: Can not connect. No target device present. |
01-12-2017, 12:20 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Quote:
Also, You can try to install the latest version of old Medusa Software 2.6.1.2 (Medusa Box Downloads - Software, Drivers, Manual), select SHV-E370K from Software list and press "Help" button to look at JTAG pinout picture. Try to connect the phone using this Software and post here the result. Last edited by Octopus box; 01-12-2017 at 12:59. | |
The Following User Says Thank You to Medusa Box For This Useful Post: |
