05-29-2019, 10:34 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | SM-J100H Smart repair error 12 [Answered] but fail Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A48344732621101AD4461B9822B Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) AD4461B9 Manufacturing date : 08/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/H4G2b_29_05_2019_11_31_14.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. P00: PART_EE (00000001, 00743FFF) 3720 MB --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/H4G2b_29_05_2019_11_30_02.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. P00: PART_EE (00000001, 00743FFF) 3720 MB Selected pit file: G:/FLASH FILES/samsung files/j100h/south africa/SM-J100H_23-8-2017_13-57-19.pit Open file "G:/FLASH FILES/samsung files/j100h/south africa/J100HXXS0AQD2_J100HOJV0AQA1_J100HXXU0AQA1_HOME.tar .md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT... ERROR[012]: Write error. At sector 7634911. Disconnected. |
