06-06-2018, 10:43 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Such error may appear, if there is no enough powering on USB port, where You have connected Box or there is a problem with eMMC connection - present shorts on PCB or soldered wires are too long. Please disconnect all other devices from PC, connect Box directly to PC motherboard USB port (don't use any USB hubs, this is important for stable connection), then check shorts on PCB, check soldering of all wires, make each wire as short as possible (max. 3-5 CM length) and try again. Try to use another USB A-B cable to connection Box to PC. Also note, that You shouldn't connect/use any external power supply to device to power it! |
06-07-2018, 09:35 | #3 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | Welcome to Octoplus Pro JTAG Software version 1.6.0. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Broadcom Corp Contacted SmartCard 0 Reader #2: FT SCR2000 0 Reader #3: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473262110114E46A89324F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 14E46A89 Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/H4G2b_07_06_2018_13_33_34.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.0; FW: 1.23. Repairing from file "C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf". Write data verification is enabled. Switch error!!! Writing BOOT1 partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. |
06-07-2018, 09:48 | #4 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | This error: Quote:
You can try also to uncheck "Write data verification" option and then try to do "Smart Repair" or "Factory Repair" again. Most likely, this will not help to solve the problem, but You can try. Also, please look here: http://forum.gsmhosting.com/vbb/f664.../#post13155165. | |
