12-28-2018, 16:34 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Brazil
Member: 232960 Status: Offline Thanks Meter: 419 | Whre's "erase selected partition" ? Need this for a Moto XT1640 remove FRP, but can't conect usb, can't repair it, "reset FRP" botton in octoplus pro Jtag dont remove FRP....so unique solution is erase FRP partition...but where's? |
12-28-2018, 18:53 | #4 (permalink) |
Member: 232960 Status: Offline Thanks Meter: 419 | I found a old Medusa pro 1.4.4.exe is the same as Octoplus and solve my problem, but can developers bring back this important fuction on News softwares? I dont know why they removed it .... "Erase selected partitions" on "Partition Manager" Code: Welcome to Medusa Pro Software version 1.4.4. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC QX13MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 150100515831334D4207475DF245A353 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX13MB Product revision : 0.7 Product serial number : (hex) 475DF245 Manufacturing date : 10/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QX13MB_28_12_2018_14_56_50.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.4; FW: 1.22. P00: GPT (00000000, 00000100) P01: modem (00000100, 00032000) P02: fsc (00032100, 00000002) P03: ssd (00032102, 00000010) P04: sbl1 (00032112, 00000400) P05: sbl1bak (00032512, 00000400) P06: rpm (00032912, 000001B0) P07: rpmbak (00032D12, 000001B0) P08: tz (00033112, 00000718) P09: tzbak (00033D12, 00000718) P10: hyp (00034912, 000000C0) P11: hypbak (00034D12, 000000C0) P12: dsp (00035112, 00008000) P13: modemst1 (0003D112, 00001000) P14: modemst2 (0003E112, 00001000) P15: DDR (0003F200, 00000040) P16: fsg (0003F240, 00004000) P17: sec (00043240, 00000020) P18: aboot (00043300, 00000BB8) P19: abootbak (00043F00, 00000BB8) P20: logs (00044B00, 00001000) P21: utags (00045B00, 00000400) P22: utagsBackup (00045F00, 00000400) P23: cid (00046300, 00000100) P24: logo (00046400, 00008000) P25: clogo (0004E400, 00008000) P26: metadata (00056400, 00000400) P27: kpan (00056800, 00004000) P28: boot (0005A800, 00008000) P29: recovery (00062800, 000080C8) P30: persist (0006A900, 00010000) P31: misc (0007A900, 00000800) P32: config (0007B100, 00000040) P33: limits (0007B200, 00000040) P34: mota (0007B300, 00000800) P35: devcfg (0007BB00, 00000200) P36: dip (0007BD00, 00000800) P37: syscfg (0007C500, 00000400) P38: cmnlib (0007C900, 00000188) P39: keymaster (0007CB00, 000001B8) P40: frp (0007CD00, 00000400) P41: padC (0007D100, 0000AF00) P42: sp (00088000, 00004000) P43: hw (0008C000, 00004000) P44: customize (00090000, 00010000) P45: oem (000A0000, 00148000) P46: cache (001E8000, 00080000) P47: system (00268000, 00500000) P48: userdata (00768000, 032C5F00) Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/QX13MB_Gpt_0x_0x_28_12_2018_14_56_50.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.4.4; FW: 1.22. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/QX13MB_Cid_0x_0x_28_12_2018_14_56_50.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.4.4; FW: 1.22. Erasing. Please wait... Erasing partition frp... Done. Done Disconnected. SW: 1.4.4; FW: 1.22. |
12-28-2018, 18:54 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,102 | here how to erase specific partition by select one by one : after suuccessful connect mobile you have this : if erase option not enable you need clic in partitions to get erase enabled : after that you can erase any custom partition and you will see this : |
The Following 5 Users Say Thank You to rebainoor For This Useful Post: |
12-28-2018, 22:36 | #8 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,102 | I know major users dont know and tired to use this erase option because its good and easy if its in partition manager tab And this erase option in medusa pro soft its an Real erase not zerote partition be carfully if you dont know what you do |
The Following 3 Users Say Thank You to rebainoor For This Useful Post: |
