world first itel s31 stuck on logo fix by jtag write protect remove Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC F822MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100463832324D42004C2790E0C34F Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : F822MB Product revision : 0.0 Product serial number : (hex) 4C2790E0 Manufacturing date : 12/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF92404009 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 5087232 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/F822MB_12_04_2019_22_20_05.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. P00: GPT (00000000, 0000000F) 7.5 KB P01: (0000000F, 1FFFFFFF2) 4096 GB P02: (0000000F, 1FFFFFFF2) 4096 GB P03: para (0001E900, 00000400) 512 KB P04: logo (0001ED00, 00004000) 8 MB P05: expdb (00022D00, 00005000) 10 MB P06: frp (00027D00, 00000800) 1024 KB P07: nvdata (00028500, 00010000) 32 MB P08: metadata (00038500, 00013B00) 39.38 MB P09: oemkeystore (0004C000, 00001000) 2048 KB P10: secro (0004D000, 00003000) 6 MB P11: keystore (00050000, 00004000) 8 MB P12: system (00054000, 005AC000) 2904 MB P13: cache (00600000, 00080000) 256 MB P14: userdata (00680000, 01696C00) 11.29 GB P15: flashinfo (01D16C00, 00008000) 16 MB P16: ???????????? (200000000000000, 7D7F7FF8FC04FC01) 1.711e+10 GB P17: ???????????? (200000000000000, 7D7F7FF8FC04FC01) 1.711e+10 GB P18: �e?�??????� (FF00FFFF10FE6900, FF00FFEF058000) 1.705e+10 GB P19: ??ute?�R? (FFFFFF00FFDF9400, FF0001FF001F8900) 1.047e+06 GB P20: (FFFFFFFFFFFFFFFF, 00000001) 512 b P21: (FFFFFFFFFFFFFFFF, 00000001) 512 b EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD_12_04_2019_22_20_41.bin. File open failed. Switched to boot area partition 2. Opening C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/Samsung eMMC F822MB_12_04_2019_22_30_29.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 sW: 1.7.6; FW: 1.24. Remove write protect successfully completed. <<<<<<<<<<<<<<<<<<<<<<<<write protect remove Disconnected. Smart report info: Hash code: 00000000000000000000000000000000000000000000000000 00000000000000 Super block size : 0x00000000 Bytes Super page size : 0x00000000 Bytes Optima write size : 0x00000000 Bytes Number of banks : 0 Bank0 init bad block : 0 Bank0 runtime bad block : 0 Bank0 remain reserved block : 0 Max erase count : 0 Min erase count : 0 Avg erase count : 0 Read reclaim count : 0 Optimal trim size : 0x00000000 Bytes Max erase count (SCL) : 0 Min erase count (SCL) : 0 Avg erase count (SCL) : 0 Max erase count (MLC) : 0 Min erase count (MLC) : 0 Avg erase count (MLC) : 0 SW: 1.7.6; FW: 1.24. Switched to boot area partition 1. ERROR[011]: Read error. At sector 32 Attempting to read... Added partition BOOT1 to constructor file. Switched to boot area partition 2. Added partition BOOT2 to constructor file. Switched to user area. Added partition GPT to constructor file. Added partition nvdata to constructor file. Added partition oemkeystore to constructor file. Added partition flashinfo to constructor file. SRF "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/itel_s31.srf" has been installed successfully. Partition table has been found on device. Switched to boot area partition 1. Opening C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/Samsung eMMC F822MB_12_04_2019_22_30_05.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 1.7.6; FW: 1.24. Please select file. Switched to boot area partition 2. Opening C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/Samsung eMMC F822MB_12_04_2019_22_30_29.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 1.7.6; FW: 1.24. Remove write protect successfully completed. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC F822MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100463832324D42004C2790E0C34F Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : F822MB Product revision : 0.0 Product serial number : (hex) 4C2790E0 Manufacturing date : 12/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF92404009 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 5087232 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/F822MB_12_04_2019_22_30_52.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: nvram (00001C00, 00002800) 5 MB P03: protect1 (00004400, 00005000) 10 MB P04: protect2 (00009400, 00005000) 10 MB P05: seccfg (0000E400, 00000200) 256 KB P06: lk (0000E600, 00000300) 384 KB P07: boot (0000E900, 00008000) 16 MB P08: recovery (00016900, 00008000) 16 MB P09: para (0001E900, 00000400) 512 KB P10: logo (0001ED00, 00004000) 8 MB P11: expdb (00022D00, 00005000) 10 MB P12: frp (00027D00, 00000800) 1024 KB P13: nvdata (00028500, 00010000) 32 MB P14: metadata (00038500, 00013B00) 39.38 MB P15: oemkeystore (0004C000, 00001000) 2048 KB P16: secro (0004D000, 00003000) 6 MB P17: keystore (00050000, 00004000) 8 MB P18: system (00054000, 005AC000) 2904 MB P19: cache (00600000, 00080000) 256 MB P20: userdata (00680000, 01696C00) 11.29 GB P21: flashinfo (01D16C00, 00008000) 16 MB Partition table has been found on device. Switched to boot area partition 1. Added partition BOOT1 to constructor file. Switched to boot area partition 2. Added partition BOOT2 to constructor file. Switched to user area. Added partition proinfo to constructor file. SRF "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/itel sxxxx_s31.srf" has been installed successfully. PHONE COME STUCK ON LOGO AND NOT ACCEPT RESET OR FORMAT |
scatter write ----------------------------------------------------------------------- Selected scatter file: C:/Users/NessY/Desktop/Odin3_v3.12.3/MT6580_EMMC_Itel_itel S31_6_0_alps-mp-m0_mp1-V2_39_rlk6580_we_i_m_P27(2017_11_28_11_21)/MT6580_Android_EMMC_scatter.txt. Scatter file type 2. Opened input file: C:/Users/NessY/Desktop/Odin3_v3.12.3/MT6580_EMMC_Itel_itel S31_6_0_alps-mp-m0_mp1-V2_39_rlk6580_we_i_m_P27(2017_11_28_11_21)/preloader_rlk6580_we_i_m.bin Found 5 eMMC supported CID: eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : F722MB eMMC CID : 150100463732324D42 eMMC Vendor ID : 70 (Pretec eMMC) eMMC Model ID : 0001 eMMC Name : EH8CE8 eMMC CID : 700100454838434538 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : F822MB eMMC CID : 150100463832324D42 eMMC Vendor ID : 70 (Pretec eMMC) eMMC Model ID : 0001 eMMC Name : EHACE8 eMMC CID : 700100454841434538 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : FE12MB eMMC CID : 150100464531324D42 Scatter file parsing finished. Writing. Please wait... Write data verification is enabled. Writing partition preloader... Write data verification is enabled. Done. #greenWriting partition lk... Done. #greenWriting partition boot... Done. #greenWriting partition recovery... Done. #greenWriting partition logo... Done. #greenWriting partition frp... Done. #greenWriting partition secro... Done. #greenWriting partition system... Done. #greenWriting partition cache... Done. #greenWriting partition userdata... |
am new to jtag, what are those files you wrote at first |
