Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus JTAG
Old 04-12-2019, 21:41   #1 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 490
Thumbs up world first itel s31 stuck on logo fix by jtag write protect remove
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC F822MB
Page size : 512 B
Block size : 512 B
Block count : 30535680
Size : 14.56 GB (14910.00 MB)
CID Info
CID : 150100463832324D42004C2790E0C34F
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : F822MB
Product revision : 0.0
Product serial number : (hex) 4C2790E0
Manufacturing date : 12/2016
CSD Info
CSD : D02701320F5903FFF6DBFFEF92404009
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 1Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 5087232 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/F822MB_12_04_2019_22_20_05.bin.
Connect successful.
SW: 1.7.6; FW: 1.24.
P00: GPT (00000000, 0000000F) 7.5 KB
P01: (0000000F, 1FFFFFFF2) 4096 GB
P02: (0000000F, 1FFFFFFF2) 4096 GB
P03: para (0001E900, 00000400) 512 KB
P04: logo (0001ED00, 00004000) 8 MB
P05: expdb (00022D00, 00005000) 10 MB
P06: frp (00027D00, 00000800) 1024 KB
P07: nvdata (00028500, 00010000) 32 MB
P08: metadata (00038500, 00013B00) 39.38 MB
P09: oemkeystore (0004C000, 00001000) 2048 KB
P10: secro (0004D000, 00003000) 6 MB
P11: keystore (00050000, 00004000) 8 MB
P12: system (00054000, 005AC000) 2904 MB
P13: cache (00600000, 00080000) 256 MB
P14: userdata (00680000, 01696C00) 11.29 GB
P15: flashinfo (01D16C00, 00008000) 16 MB
P16: ???????????? (200000000000000, 7D7F7FF8FC04FC01) 1.711e+10 GB
P17: ???????????? (200000000000000, 7D7F7FF8FC04FC01) 1.711e+10 GB
P18: �e?�??????� (FF00FFFF10FE6900, FF00FFEF058000) 1.705e+10 GB
P19: ??ute?�R? (FFFFFF00FFDF9400, FF0001FF001F8900) 1.047e+06 GB
P20: (FFFFFFFFFFFFFFFF, 00000001) 512 b
P21: (FFFFFFFFFFFFFFFF, 00000001) 512 b
EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD_12_04_2019_22_20_41.bin.
File open failed.
Switched to boot area partition 2.
Opening C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/Samsung eMMC F822MB_12_04_2019_22_30_29.bin file...
Reading. Please wait... Done.
Elapsed time 00:00:01
sW: 1.7.6; FW: 1.24.
Remove write protect successfully completed. <<<<<<<<<<<<<<<<<<<<<<<<write protect remove
Disconnected.
Smart report info:
Hash code: 00000000000000000000000000000000000000000000000000 00000000000000
Super block size : 0x00000000 Bytes
Super page size : 0x00000000 Bytes
Optima write size : 0x00000000 Bytes
Number of banks : 0
Bank0 init bad block : 0
Bank0 runtime bad block : 0
Bank0 remain reserved block : 0
Max erase count : 0
Min erase count : 0
Avg erase count : 0
Read reclaim count : 0
Optimal trim size : 0x00000000 Bytes
Max erase count (SCL) : 0
Min erase count (SCL) : 0
Avg erase count (SCL) : 0
Max erase count (MLC) : 0
Min erase count (MLC) : 0
Avg erase count (MLC) : 0
Switched to boot area partition 1.
ERROR[011]: Read error.
At sector 32
Attempting to read...
Added partition BOOT1 to constructor file.
Added partition BOOT2 to constructor file.
Switched to user area.
Added partition GPT to constructor file.
Added partition nvdata to constructor file.
Added partition oemkeystore to constructor file.
Added partition flashinfo to constructor file.
SRF "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/itel_s31.srf" has been installed successfully.
Partition table has been found on device.
Opening C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/Samsung eMMC F822MB_12_04_2019_22_30_05.bin file...
Please select file.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/F822MB_12_04_2019_22_30_52.bin.
Connect successful.
P00: GPT (00000000, 00000400) 512 KB
P01: proinfo (00000400, 00001800) 3072 KB
P02: nvram (00001C00, 00002800) 5 MB
P03: protect1 (00004400, 00005000) 10 MB
P04: protect2 (00009400, 00005000) 10 MB
P05: seccfg (0000E400, 00000200) 256 KB
P06: lk (0000E600, 00000300) 384 KB
P07: boot (0000E900, 00008000) 16 MB
P08: recovery (00016900, 00008000) 16 MB
P09: para (0001E900, 00000400) 512 KB
P10: logo (0001ED00, 00004000) 8 MB
P11: expdb (00022D00, 00005000) 10 MB
P12: frp (00027D00, 00000800) 1024 KB
P13: nvdata (00028500, 00010000) 32 MB
P14: metadata (00038500, 00013B00) 39.38 MB
P15: oemkeystore (0004C000, 00001000) 2048 KB
P16: secro (0004D000, 00003000) 6 MB
P17: keystore (00050000, 00004000) 8 MB
P18: system (00054000, 005AC000) 2904 MB
P19: cache (00600000, 00080000) 256 MB
P20: userdata (00680000, 01696C00) 11.29 GB
P21: flashinfo (01D16C00, 00008000) 16 MB
Added partition proinfo to constructor file.
SRF "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/itel sxxxx_s31.srf" has been installed successfully.
PHONE COME STUCK ON LOGO AND NOT ACCEPT RESET OR FORMAT
The Following User Says Thank You to nessyb For This Useful Post:
Old 04-12-2019, 23:23   #2 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 490
scatter write
Selected scatter file: C:/Users/NessY/Desktop/Odin3_v3.12.3/MT6580_EMMC_Itel_itel S31_6_0_alps-mp-m0_mp1-V2_39_rlk6580_we_i_m_P27(2017_11_28_11_21)/MT6580_Android_EMMC_scatter.txt.
Scatter file type 2.
Opened input file: C:/Users/NessY/Desktop/Odin3_v3.12.3/MT6580_EMMC_Itel_itel S31_6_0_alps-mp-m0_mp1-V2_39_rlk6580_we_i_m_P27(2017_11_28_11_21)/preloader_rlk6580_we_i_m.bin
Found 5 eMMC supported CID:
eMMC Vendor ID : 15 (Samsung eMMC)
eMMC Model ID : 0001
eMMC Name : F722MB
eMMC CID : 150100463732324D42
eMMC Vendor ID : 70 (Pretec eMMC)
eMMC Name : EH8CE8
eMMC CID : 700100454838434538
eMMC Name : F822MB
eMMC CID : 150100463832324D42
eMMC Name : EHACE8
eMMC CID : 700100454841434538
eMMC Name : FE12MB
eMMC CID : 150100464531324D42
Scatter file parsing finished.
Writing. Please wait...
Write data verification is enabled.
Writing partition preloader... Write data verification is enabled.
Done.
#greenWriting partition lk... Done.
#greenWriting partition boot... Done.
#greenWriting partition recovery... Done.
#greenWriting partition logo... Done.
#greenWriting partition frp... Done.
#greenWriting partition secro... Done.
#greenWriting partition system... Done.
#greenWriting partition cache... Done.
#greenWriting partition userdata...
Old 04-13-2019, 18:50   #3 (permalink)
Member: 2601900
Thanks Meter: 329
am new to jtag, what are those files you wrote at first
Page generated in 0.31634 seconds with 7 queries
