Member: 2851795
Thanks Meter: 21 | Log directly from eMMC Quote:
Welcome to Octoplus Pro JTAG Software version 1.7.6.
Started.
Reader #0: Generic EMV Smartcard Reader 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 4 bits
Bus speed : Auto
Connecting...
Device : Toshiba eMMC 032G34
Page size : 512 B
Block size : 512 B
Block count : 61071360
Size : 29.12 GB (29820.00 MB)
CID Info
CID : 11010030333247333400F55197C24343
Manufacturer ID : 0X11
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : 032G34
Product revision : 0.0
Product serial number : (hex) F55197C2
Manufacturing date : 04/2016
CSD Info
CSD : D02700328F5903FFFFFFFFE7864000A7
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 4096 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 15269888 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/032G34_05_08_2019_12_04_49.bin.
Connect successful.
SW: 1.7.6; FW: 1.24.
P00: GPT (00000000, 00020000) 64 MB
P01: modem (00020000, 0002A000) 84 MB
P02: fsc (00060000, 00000002) 1024 b
P03: ssd (00060002, 00000010) 8 KB
P04: sbl1 (00060012, 00000400) 512 KB
P05: sbl1bak (00060412, 00000400) 512 KB
P06: rpm (00060812, 00000400) 512 KB
P07: rpmbak (00060C12, 00000400) 512 KB
P08: tz (00061012, 00001000) 2048 KB
P09: tzbak (00062012, 00001000) 2048 KB
P10: hyp (00063012, 00000400) 512 KB
P11: hypbak (00063412, 00000400) 512 KB
P12: dsp (00063812, 00008000) 16 MB
P13: modemst1 (0006B812, 00000C00) 1536 KB
P14: modemst2 (0006C412, 00000C00) 1536 KB
P15: DDR (00080000, 00000040) 32 KB
P16: fsg (00080040, 00000C00) 1536 KB
P17: sec (00080C40, 00000020) 16 KB
P18: splash (000A0000, 00005800) 11 MB
P19: aboot (000C0000, 00000800) 1024 KB
P20: abootbak (000C0800, 00000800) 1024 KB
P21: boot (000C1000, 00020000) 64 MB
P22: recovery (000E1000, 00020000) 64 MB
P23: devinfo (00101000, 00000800) 1024 KB
P24: system (00101800, 00500000) 2560 MB
P25: cache (00620000, 00080000) 256 MB
P26: persist (006A0000, 00010000) 32 MB
P27: misc (006B0000, 00000800) 1024 KB
P28: keystore (006B0800, 00000400) 512 KB
P29: config (006B0C00, 00000040) 32 KB
P30: oem (006B0C40, 00020000) 64 MB
P31: limits (006E0000, 00000040) 32 KB
P32: mota (00700000, 00000400) 512 KB
P33: devcfg (00700400, 00000200) 256 KB
P34: dip (00700600, 00000800) 1024 KB
P35: mdtp (00700E00, 00010000) 32 MB
P36: cust (00710E00, 00100000) 512 MB
P37: syscfg (00810E00, 00000400) 512 KB
P38: mcfg (00811200, 00002000) 4 MB
P39: cmnlib (00820000, 00000200) 256 KB
P40: keymaster (00820200, 00000200) 256 KB
P41: cmnlibbak (00820400, 00000200) 256 KB
P42: keymasterbak (00820600, 00000200) 256 KB
P43: apdp (00840000, 00000200) 256 KB
P44: msadp (00840200, 00000200) 256 KB
P45: dpo (00840400, 00000010) 8 KB
P46: userdata (00840410, 031FDBCF) 25 GB
