10-11-2021, 17:49 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Lebanon-Beirut Age: 43
Member: 180903 Status: Offline Sonork: 100.1637253 Thanks Meter: 70 | adb lg failed [Answered] -------------------------------------------------------------------------------- Work ID: 0000000001A76B4D Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: V500EM Reading info... Performed by 3.1.5.02 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM19 Selected model: V500EM Reading info... Found model LMV500EM: ÿh0 at port COM19 Model ID: LM-V500EM IMEI: 355826-10-004568-0 Android version: 10 Battery level: 40% Mode: Normal Firmware compiled date: Dec 08 2020 Firmware compiled time: 13:00:00 Firmware released date: Apr 8 2021 Firmware released time: 11:37:40 SW Version: MPSS.HE.1.5.3.c1-00109-SM8150 _GENFUSION_PACK-8.354299.2 IMEI: 355826-10-004568-0 SPC: 000000 Performed by 3.1.5.02 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001A76BC8 Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: V500EM Reading info... Found model LMV500EM: ÿh0 at port COM19 Model ID: LM-V500EM IMEI: 355826-10-004568-0 Android version: 10 Battery level: 40% Mode: Normal Firmware compiled date: Dec 08 2020 Firmware compiled time: 13:00:00 Firmware released date: Apr 8 2021 Firmware released time: 11:37:40 SW Version: MPSS.HE.1.5.3.c1-00109-SM8150 _GENFUSION_PACK-8.354299.2 IMEI: 355826-10-004568-0 SPC: 000000 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.1.5.02 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001A76BDE Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: V500EM Reading info... Found model LMV500EM: ÿh0 at port COM19 Model ID: LM-V500EM IMEI: 355826-10-004568-0 Android version: 10 Battery level: 40% Mode: Normal Firmware compiled date: Dec 08 2020 Firmware compiled time: 13:00:00 Firmware released date: Apr 8 2021 Firmware released time: 11:37:40 SW Version: MPSS.HE.1.5.3.c1-00109-SM8150 _GENFUSION_PACK-8.354299.2 IMEI: 355826-10-004568-0 SPC: 000000 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.1.5.02 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001A76C07 Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: V500EM Reading info...Canceled! Performed by 3.1.5.02 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001A76C0C Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: V500EM Reading info... Found model LMV500EM: ÿh0 at port COM19 Model ID: LM-V500EM IMEI: 355826-10-004568-0 Android version: 10 Battery level: 40% Mode: Normal Firmware compiled date: Dec 08 2020 Firmware compiled time: 13:00:00 Firmware released date: Apr 8 2021 Firmware released time: 11:37:40 SW Version: MPSS.HE.1.5.3.c1-00109-SM8150 _GENFUSION_PACK-8.354299.2 IMEI: 355826-10-004568-0 SPC: 000000 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.1.5.02 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001A76C29 Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: V500EM Reading info... Found model LMV500EM: ÿh0 at port COM19 Model ID: LM-V500EM IMEI: 355826-10-004568-0 Android version: 10 Battery level: 41% Mode: Normal Firmware compiled date: Dec 08 2020 Firmware compiled time: 13:00:00 Firmware released date: Apr 8 2021 Firmware released time: 11:37:40 SW Version: MPSS.HE.1.5.3.c1-00109-SM8150 _GENFUSION_PACK-8.354299.2 IMEI: 355826-10-004568-0 SPC: 000000 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.1.5.02 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001A76C5F Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: V500EM Reading info... Found model LMV500EM: ÿh0 at port COM19 Model ID: LM-V500EM IMEI: 355826-10-004568-0 Android version: 10 Battery level: 41% Mode: Normal Firmware compiled date: Dec 08 2020 Firmware compiled time: 13:00:00 Firmware released date: Apr 8 2021 Firmware released time: 11:37:40 SW Version: MPSS.HE.1.5.3.c1-00109-SM8150 _GENFUSION_PACK-8.354299.2 IMEI: 355826-10-004568-0 SPC: 000000 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.1.5.02 Software version. |
10-12-2021, 07:47 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Hello. Are you sure you took these steps? Quote:
