11-18-2014, 16:45 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | c3300 unlocking error [Solved] Platform: LG Analog Devices Selected port: COM3 Selected baudrate: 921600 Selected model: C3300 Please reconnect battery... Port busy! Last edited by Octopus box; 11-19-2014 at 12:26. |
11-18-2014, 17:30 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | To unlock the device, try to do the next: 1. Install the latest Software version (Software). 2. Fully charge phone's battery. 3. Disconnect all other devices from PC. 4. Re-boot the PC. 5. Run the Software. 6. Select correct (Box) COM port. 7. Set (select) lower (try 115200) baud rate. 8. Connect the device to Box via LG 7050 UART cable. 9. Press "Connect" button in the Software. 10. Reconnect the battery. 11. When phone will be connected make Unlock. Should be like here: http://forum.gsmhosting.com/vbb/10210273-post2623.html. |
11-18-2014, 17:45 | #3 (permalink) | |
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
I have done all these said above, I believe this error is from "usb to serial converter", but it was installed well. Every thing is working well whenever am working with usb but with com port, it always says "port busy" plz help me an look into it. Am using window 7 ultimate. | |
