08-26-2014, 16:21 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: burkina faso
Member: 457765 Status: Offline Thanks Meter: 77 | cannot update lg su-760 [Solved] Welcome to Octoplus/Octopus Box LG Software version 1.6.5 -------------------------------------------------------------------------------- Opening "LGSU760AT-00-V20f-450-05-MAR-22-2012+0_AP.oct"...OK Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader...OK Initializing flash...Failed! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: SU760 Opening "LGSU760AT-00-V20f-450-05-MAR-22-2012+0_AP.oct"...OK Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader...OK Initializing flash...Failed! Last edited by Octopus box; 08-29-2014 at 06:24. |
08-26-2014, 16:57 | #3 (permalink) |
Member: 457765 Status: Offline Thanks Meter: 77 | the poblem of phone is a pop up message every time with this message: sorry the application com.android.LGSetupWIZAR(process com.android.LGSEtupWizard) has stopped unexpectedly.please try again. i cannot enter to phone menu after hard reset same problem i have decided to flash phone |
08-27-2014, 07:09 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Connect the device via P999 cable (with 910k resistor) directly to PC motherboard USB port, don't use any USB hubs or PCI USB extension cards, this is important and try to write firmware again. Try to connect the phone to different PC motherboard USB ports. Try to make Repair EEPROM also. Try on another PC. If the problem is still the same - most likely, this is HW problem. |
