12-10-2014, 08:07 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | can't reflash F200K what problem? Code: Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: F200K Reading info...OK Mode: Emergency Model ID: BS/VU2SK/1 (F200S) SW version: LGP895AT-00-V20c-KT-KR-FEB-17-2013+0 Product ID: HD52S130205001739 IMEI: 353962-05-244808-5 Opening "F200K20f.oct"...OK Initializing flash...OK Writing PrimaryGPT...Failed! Read Failed! |
12-10-2014, 08:58 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | What is the problem with your device exactly? Why do You want to write firmware? |
12-10-2014, 09:26 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Connect the phone directly to PC motherboard USB port (don't use any USB hubs or PCI USB extention cards, this is important) and try to write firmware again. Try to write another firmware. Try to write firmwares on another PC. If the problem is still the same - most likely, this is HW issue. |
