10-04-2017, 20:01 | #1 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Bombay. Age: 33
Member: 1960501 Status: Offline Sonork: 100.1638964 Thanks Meter: 23 | Coudn't flash LG-K520DY....(Error code: ZXLCALSZXC) Phone is only logo stuck condition,when I flashed with K520DY10g_00_1227.oct file.they shows error below... Welcome to Octoplus/Octopus Box LG Software version 2.6.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM48 Selected model: K520DY Reading info... Model ID: LG-K520DY IMEI: 357952-07-501051-3 Android version: 6.0.1 Battery level: 38% SW Version: K52010g Mode: Emergency Initializing flash...OK SW version: LGK520DYAT-00-V10g-IND-XX-DEC-27-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: HD58S160718000059 IMEI: 357952-07-501051-3 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "K520DY10g_00_1227.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing PrimaryGPT...OK Writing sbl1...OK Writing tz...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing recoverybak...OK Writing sec...OK Writing factory...OK Writing modem...OK Writing cust...OK Writing system...Failed! Error code: ZXLCALSZXD Performed by 2.6.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM48 Selected model: K520DY Reading info... Mode: Emergency Initializing flash...OK SW version: LGK520DYAT-00-V10g-IND-XX-DEC-27-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: HD58S160718000059 IMEI: 357952-07-501051-3 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "K520DY10g_00_1227.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing PrimaryGPT...OK Writing sbl1...OK Writing tz...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing recoverybak...OK Writing sec...OK Writing factory...OK Writing modem...OK Writing cust...OK Writing system...Failed! Error code: ZXLCALSZXC Performed by 2.6.6 Software version. |
The Following 2 Users Say Thank You to SMD Expert For This Useful Post: |
10-05-2017, 07:40 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. You have used too old Software version. Please download and install the latest Software version, then repeat "Write Firmware" operation again. Post here the result. Last edited by Octopus box; 10-05-2017 at 07:47. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
