03-12-2018, 12:24 | #1 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 451456 Status: Offline Thanks Meter: 38 | D160 factory reset status 3 [Solved] 1. i flashed lg d160 with original (converted by octopus) software 2.phone shows factory reset status 3 3. octopus software is 2.8.0 4. factory reset but no luck what i can next please... log is here Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "D16010E_00.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing rpmb...OK Writing tzb...OK Writing abootb...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing factory...OK Writing sbl1b...OK Writing cust...OK Writing system...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...Failed! Finalizing...OK Writing firmware done! Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM44 Selected model: D160 Reading info...Failed! Port busy Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM44 Selected model: D160 Reading info...Failed! Port busy Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM95 Selected model: D160 Reading info... Model ID: LG-D160 IMEI: 352934-06-376752-3 Android version: 4.4.2 Battery level: 63% SW Version: D16010e Mode: Normal Firmware compiled date: Apr 08 2014 Firmware compiled time: 01:00:00 Firmware released date: Aug 25 2015 Firmware released time: 18:07:38 SW Version: M8610B-AAAANAZM-1.0.6047 IMEI: 352934-06-376752-3 SPC: 000000 Factory reset... Setting Mini OS Status to 2...Failed! Switching to Download mode...OK Initializing flash...OK Factory reset done! Performed by 2.8.0 Software version. Last edited by Octopus box; 03-12-2018 at 13:31. |
03-12-2018, 12:55 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. What was the problem with the phone before? Why You have decided to write firmware? As I see, there was a problem with formatting MPT partition at the end of Write Firmware procedure: Quote:
Also try to connect your device as as D280 and perform "Factory Reset" operation. | |
03-12-2018, 13:23 | #3 (permalink) |
Member: 451456 Status: Offline Thanks Meter: 38 | sir i factory reset model seclected d280 but no luck. i press power + up and home and now phone is in working condition thanks sir |
The Following User Says Thank You to r_irfankhan For This Useful Post: |
