06-05-2017, 06:46 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 940 | D295 imei null and baseband unknow solved with full flashing [Solved] -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: D295 Reading info... Could not detect mode! Performed by 2.6.7 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: D295 Reading info... Could not detect mode! Performed by 2.6.7 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM50 Selected model: D295 Reading info...Failed! Could not detect mode. Performed by 2.6.7 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM50 Selected model: D295 Reading info... Mode: Normal Performed by 2.6.7 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM50 Selected model: D295 Reading info... Model ID: LG-D295 IMEI: 356274-06-123627-0 Android version: 4.4.2 Battery level: 51% SW Version: D29510d Mode: Emergency Initializing flash...OK SW version: LGD295AT-00-V10d-ESA-XX-FEB-12-2015+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: CT69S141026003356 IMEI: 356274-06-123627-0 Target operator: GLOBAL Hardware: rev_10 Performed by 2.6.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM50 Selected model: D295 Reading info... Model ID: LG-D295 IMEI: 356274-06-123627-0 Android version: 4.4.2 Battery level: 51% SW Version: D29510d Mode: Emergency Initializing flash...OK SW version: LGD295AT-00-V10d-ESA-XX-FEB-12-2015+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: CT69S141026003356 IMEI: 356274-06-123627-0 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "D295_v10d_IND_2.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing rpmb...OK Writing tzb...OK Writing abootb...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing factory...OK Writing sbl1b...OK Writing cust...OK Writing system...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.6.7 Software version. |
The Following User Says Thank You to Deni's For This Useful Post: |
