01-10-2017, 11:48 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | D295 IMEI Repair failed [Solved] i try with P999 cable, normal usb cable but always failled,i connected phone @ direct port not a usb hub... Last edited by Octopus box; 01-11-2017 at 10:17. |
01-10-2017, 15:34 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please download and install the latest Software version (http://octoplusbox.com/en/download/software/), try and post here the result. Last edited by Octopus box; 01-10-2017 at 15:50. |
01-11-2017, 08:47 | #3 (permalink) | |
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | Quote:
-------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM84 Selected model: D295 Reading info... Mode: Emergency Initializing flash...OK SW version: LGD295AT-00-V10i-GLOBAL-COM-FEB-12-2015+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: CT69S140918003440 IMEI: 000000-00-000000-0 Target operator: GLOBAL Hardware: rev_10 Fixing IMEI... New IMEI A: 356274-06-048311-3 Finalizing... Failed! Performed by 2.5.6 Software version. | |
01-11-2017, 09:05 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | OK, we have prepared test Software version for You. Please download it form the Support Area ("LG/TEST SOFTWARE/" folder), then repeat Repair IMEI operation and post here full Software log. Last edited by Octopus box; 01-11-2017 at 09:24. |
01-11-2017, 09:30 | #5 (permalink) | |
Welcome to Octoplus/Octopus Box LG Software version 2.5.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM84 Selected model: D295 Reading info... Model ID: LG-D295 IMEI: 000000-00-000000-0 Android version: 4.4.2 Battery level: 69% SW Version: D29510i Mode: Emergency Initializing flash...OK SW version: LGD295AT-00-V10i-GLOBAL-COM-FEB-12-2015+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: CT69S140918003440 IMEI: 000000-00-000000-0 Target operator: GLOBAL Hardware: rev_10 Fixing IMEI... New IMEI B: 356274-06-048312-1 Skip Read/Write QCN Do you want to create security backup? Switching to Normal mode... Found model WX_PROJE at port COM84 Writing security area...OK Rebooting phone... Found model WX_PROJE at port COM84 IMEI B successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.5.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM84 Selected model: D295 Reading info... Model ID: LG-D295 IMEI: 000000-00-000000-0 Android version: 4.4.2 Battery level: 69% SW Version: D29510i Mode: Normal Firmware compiled date: Jul 14 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 12 2015 Firmware released time: 13:21:15 SW Version: M8610B-AAAANAZM-1.0.6056 IMEI: 000000-00-000000-0 IMEI B: 356274-06-048312-1 SPC: 000000 Fixing IMEI... New IMEI A: 356274-06-048311-3 Finalizing... Failed! Performed by 2.5.6 Software version. ok now i will try with tested ver, and i will report you.. | |
01-11-2017, 09:53 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, download and install test Software version (which we have prepared for You) from the Support Area ("LG/TEST SOFTWARE/" folder) then repeat Repair IMEI operation. Post here full Software log. |
01-11-2017, 10:03 | #7 (permalink) |
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | Thanks alot Octopus box Product Supporter, you are reailly geat and helpful person Welcome to Octoplus/Octopus Box LG Software version 2.5.6.2 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM84 Selected model: D295 Reading info... Mode: Emergency Initializing flash...OK SW version: LGD295AT-00-V10i-GLOBAL-COM-FEB-12-2015+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: CT69S140918003440 IMEI: 000000-00-000000-0 Target operator: GLOBAL Hardware: rev_10 Fixing IMEI... New IMEI A: 356274-06-048312-1 Finalizing... Failed! Fixing IMEI... New IMEI: 356274-06-048312-1 Skip Read/Write QCN Do you want to create security backup? Switching to Normal mode... Found model WX_PROJE at port COM84 Writing security area...OK Rebooting phone... Found model WX_PROJE at port COM84 IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.5.6.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM84 Selected model: D295 Reading info... Model ID: LG-D295 IMEI: 000000-00-000000-0 Android version: 4.4.2 Battery level: 60% SW Version: D29510i Mode: Emergency Initializing flash...OK SW version: LGD295AT-00-V10i-GLOBAL-COM-FEB-12-2015+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: CT69S140918003440 IMEI: 356274-06-048312-1 Target operator: GLOBAL Hardware: rev_10 Fixing IMEI... New IMEI B: 356274-06-048311-3 Skip Read/Write QCN Do you want to create security backup? Switching to Normal mode... Found model WX_PROJE at port COM84 Writing security area...OK Rebooting phone... Found model WX_PROJE at port COM84 IMEI B successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.5.6.2 Software version. |
The Following 3 Users Say Thank You to vickyjadhav6161 For This Useful Post: |
