01-07-2015, 00:20 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: India
Member: 350719 Status: Offline Sonork: 100.1623850 Thanks Meter: 157 | D802 error Platform: LG Qualcomm Selected port: COM24 Selected model: D802 Reading info...OK Mode: Normal Fixing IMEI... New IMEI: 358xxxxxxxxxxx Skip Read/Write QCN Switching to Download mode...Failed! Please perform the fole... Found model D802 at port COM24 Internal error! Error code: Z1AL3CAS2Q -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM24 Selected model: D802 Reading info...OK Mode: Normal Checking data...OK Writing NVM...OK NVM succesfully r Checking data...OK Platform: LG Qualcomm Selected port: COM24 Selected model: D802 Reading info...OK Mode: Normal Fixing IMEI... New IMEI: 3586xxxxxxx Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D802_Bad_07-01-2015_02-14-38.SEC" Writing security area...OK Switching to Normal mode... Found model D802 at port COM24 Internal error! Error code: Z1AL3CAS2Q -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM24 Selected model: D802 Reading info...OK Mode: Normal Fixing IMEI... New IMEI: 3586xxxxxx Reading QCN... Send SPC...Failed! Backup saved to "D802_Bad_07-01-2015_02-15-46.qcn" |
01-07-2015, 08:02 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. 1. Install the latest Software versino (Software). 2. Fully charge phone's battery by using external charger. 3. Connect the phone directly to motherboard USB port, don't use any USB hubs or PCI USB extention cards, this is important. 4. Perform the operations again. 5. Try to use LG P999 cable with 910 kOhm resistor inside instead of standart Micro USB cable. 6. Try to perform the operation on another PC. |
01-07-2015, 11:12 | #3 (permalink) |
Member: 350719 Status: Offline Sonork: 100.1623850 Thanks Meter: 157 | Checking data...OK Platform: LG Qualcomm Selected port: COM91 Selected model: D802 Reading info...OK Mode: Normal Fixing IMEI... New IMEI: 35863xxxxxxxxx Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF and press and hold "Vol+" button) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D802_Bad_07-01-2015_11-07-18.SEC" Writing security area...OK Switching to Normal mode... Found model D802 at port COM91 IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). but same problem sir (imei null) |
01-07-2015, 11:52 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
