12-05-2016, 17:25 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: hyderabad
Member: 390217 Status: Offline Thanks Meter: 20 | d802 flashing error Welcome to Octoplus/Octopus Box LG Software version 2.5.2 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM93 Selected model: D802 Reading info... Mode: Emergency Initializing flash...OK SW version: Android version: 53529787 LAF Version: Product ID: 53529787 IMEI: 53529787 Target operator: Hardware: -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "D80220H_00_16GB.oct"...OK Setting options...Failed! Error code: ZXLCALSZXC Performed by 2.5.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM93 Selected model: D802 Reading info... Model ID: LG-D802 IMEI: Android version: Battery level: 4% SW Version: D80220c Mode: Emergency Initializing flash...OK SW version: Android version: 53529787 LAF Version: Product ID: 53529787 IMEI: 53529787 Target operator: Hardware: -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "D80220H_00_16GB.oct"...OK Setting options...Failed! Error code: ZXLCALSZXC Performed by 2.5.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM93 Selected model: D802 Reading info... Model ID: LG-D802 IMEI: Android version: Battery level: 4% SW Version: D80220c Mode: Emergency Initializing flash...OK SW version: Android version: 53529787 LAF Version: Product ID: 53529787 IMEI: 53529787 Target operator: Hardware: -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "D80220H_00_16GB.oct"...OK Setting options...Failed! Error code: ZXLCALSZXC Performed by 2.5.2 Software version. |
12-06-2016, 08:51 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please, try to reflash the phone with another firmware or try to convert firmware on your PC, then reflash your phone. |
