06-14-2014, 23:36 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Italy
Member: 329458 Status: Offline Thanks Meter: 153 | D802 no sim inserted I have: - Performed firmware upgrade - Repaired security - Repairde NWM - Repaired IMEI But also show No Sim I have checked sim reader and all seems ok... Any idea to solve or to check where is the problem? |
06-15-2014, 08:08 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Are You sure your phone is unlocked? Try to perform the Unlock operation. Also, this can be HW problem. Try to use different SIM cards, try to insert Motorola test card and check, whether SIM card is accepted. |
06-15-2014, 09:17 | #3 (permalink) |
Member: 329458 Status: Offline Thanks Meter: 153 | Welcome to Octoplus/Octopus Box LG Software version 1.5.9 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM41 Selected model: D802 Reading info...OK Mode: Normal Model ID: AAAAANAZ: ÿh°Ì Firmware compiled date: Jan 12 2014 Firmware compiled time: 00:00:00 Firmware released date: Feb 11 2014 Firmware released time: 13:55:33 SW Version: M8974A-AAAANAZM-1.0.190084 IMEI: 358300-05-776518-4 Unlocking... Reading NVM...OK Backup saved to "D802_358300057765184_15-06-2014_10-11-26.NVM" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D802_358300057765184_15-06-2014_10-14-40.SEC" Writing security area...OK Switching to Normal mode... Found model AAAAANAZ* ÿh°´ at port COM41 Checking data...OK Writing NVM...OK NVM succesfully repaired. Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). The strange thing is Model ID... Could this be the problem? |
06-15-2014, 09:25 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
Try also to do the next: 1. Make Repair Security. 2. Perform the Repair IMEI operation. 3. Make Repair NVM. 4. Re-flash the phone. If this will not help - most likely, this is HW problem. | |
