02-22-2015, 23:46 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Install lg drivers from support.. still problem exist .. than follow this thread http://forum.gsmhosting.com/vbb/f799...epair-1900120/ |
The Following User Says Thank You to zishhaider For This Useful Post: |
02-23-2015, 07:21 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Yes, mr. zishhaider is absolutely right, if here Android 5.x.x firmware in your device, You can't connect the phone in Normal Mode. You can re-flash the phone with lower Android firmware version, make Repair IMEI (or make Unlock) and then write (or to update) firmware to Android 5.0.x again. Octopus Box LG Software currently doesn't support Write Firmware for this device. To write firmware You can use "Nexus 5 Root Software" from the folder "LG/FOR UNLOCK AND REPAIR/" from the Support Area. |
02-24-2015, 07:14 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | What is the Android firmware version in the phone now? What is the IMEI and baseband in the phone? Fully charge phone's battery by using external charger and try to repeat the operation again. |
02-24-2015, 08:45 | #6 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Canada
Member: 1381685 Status: Offline Sonork: 100.1668719 Thanks Meter: 81 | 4.4.4 M8974A-2.0.50.1.17 Build Number KTU84Q IMEI - 352584062143554 Battery Full You Told Me To downgrade i did but stil giving me same problem |
02-24-2015, 12:02 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Connect the phone in Normal Mode (not in Fastboot Mode), turn on USB Debugging Mode aand repeat the operation once again. |
