05-11-2016, 07:22 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Vancouver
Member: 190184 Status: Offline Thanks Meter: 31 | d820 imei repair -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd22e409 (android- [email protected]) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Fri Mar 25 07:49:22 UTC 201 Android version: 6.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Press "Grant" button on the phone every time when superuser dialog appears Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. Root access garanted! Performed by 2.2.8 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd22e409 (android- [email protected]) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Fri Mar 25 07:49:22 UTC 201 Android version: 6.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Trying to enable Diagnostics ports... Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*ÿh° at port COM14 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 17 2016 Firmware released time: 18:13:28 SW Version: M8974A-2.0.50.2.29 SPC: 000000 Fixing IMEI... New IMEI: 533598-75-332547-0 Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D820_Bad_10-05-2016_22-33-03.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Checking root access... Phone is not rooted. Please, root the phone manually! Performed by 2.2.8 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-g323bbd9 (android- [email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu Oct 9 05:57:15 UTC 201 Android version: 5.0 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Press "Grant" button on the phone every time when superuser dialog appears Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. Root access garanted! Performed by 2.2.8 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-g323bbd9 (android- [email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu Oct 9 05:57:15 UTC 201 Android version: 5.0 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*ÿh°ª at port COM14 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 07:00:00 Firmware released date: Oct 1 2014 Firmware released time: 18:16:59 SW Version: M8974A-2.0.50.2.21 SPC: 000000 Fixing IMEI... New IMEI: 533598-75-332547-0 Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D820_Bad_10-05-2016_23-12-50.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.2.8 software version. And the phone goes to bootloop with Teamwin message could not mount data.......... So in order to revive the phone i need to flash it and i can only rewrite the original IMEI from the backup files. Already tried with 5.0 and 6.1 versions and the result is same. |
05-12-2016, 04:21 | #3 (permalink) |
Member: 190184 Status: Offline Thanks Meter: 31 | Thanks for the software but alas the problem remains the same and as i figured some files got deleted when entering download mode. The phone goes in bootloop. I tried this time with 4.4.4. and 6.0.1. Just to mention that current IMEI is 0 but regardless whether i repair it first the result is same. Thanks again and looking forward to sole this issue. |
05-12-2016, 08:44 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
05-13-2016, 02:43 | #6 (permalink) |
Member: 190184 Status: Offline Thanks Meter: 31 | Welcome to Octoplus/Octopus Box LG Software version 2.2.8.2 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Performed by 2.2.8.2 software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info...Failed! Could not detect mode! Performed by 2.2.8.2 software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd22e409 (android- [email protected]) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Fri Mar 25 07:49:22 UTC 201 Android version: 6.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Performed by 2.2.8.2 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd22e409 (android- [email protected]) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Fri Mar 25 07:49:22 UTC 201 Android version: 6.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Failed! Performed by 2.2.8.2 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd22e409 (android- [email protected]) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Fri Mar 25 07:49:22 UTC 201 Android version: 6.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Press "Grant" button on the phone every time when superuser dialog appears Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. Root access garanted! Performed by 2.2.8.2 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd22e409 (android- [email protected]) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Fri Mar 25 07:49:22 UTC 201 Android version: 6.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Trying to enable Diagnostics ports... Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ:ÿh°ä at port COM22 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 17 2016 Firmware released time: 18:13:28 SW Version: M8974A-2.0.50.2.29 IMEI: 352584-06-003937-4 SPC: 552191 Fixing IMEI... New IMEI: 563254-12-478896-1 Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D820_352584060039374_12-05-2016_18-39-55.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.2.8.2 software version. |
05-13-2016, 10:40 | #8 (permalink) |
Member: 190184 Status: Offline Thanks Meter: 31 | Welcome to Octoplus/Octopus Box LG Software version 2.2.8.4 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.2.8.4 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd22e409 (android- [email protected]) (gcc version 4.8 (GCC) ) # 1 SMP PREEMPT Fri Mar 25 07:49:22 UTC 201 Android version: 6.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Press "Grant" button on the phone every time when superuser dialog appears Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. Root access garanted! Performed by 2.2.8.4 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd22e409 (android- [email protected]) (gcc version 4.8 (GCC) ) # 1 SMP PREEMPT Fri Mar 25 07:49:22 UTC 201 Android version: 6.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Trying to enable Diagnostics ports... Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*ÿh°œ at port COM22 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 17 2016 Firmware released time: 18:13:28 SW Version: M8974A-2.0.50.2.29 SPC: 000000 Fixing IMEI... New IMEI A: 256978-74-569325-7 Finalizing... Failed! Performed by 2.2.8.4 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd22e409 (android- [email protected]) (gcc version 4.8 (GCC) ) # 1 SMP PREEMPT Fri Mar 25 07:49:22 UTC 201 Android version: 6.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Trying to enable Diagnostics ports... Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*ÿh°œ at port COM22 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 17 2016 Firmware released time: 18:13:28 SW Version: M8974A-2.0.50.2.29 SPC: 000000 Fixing IMEI... New IMEI A: 256978-74-569325-7 Finalizing... Failed! Performed by 2.2.8.4 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-g323bbd9 (android- [email protected]) (gcc version 4.7 (GCC) ) # 1 SMP PREEMPT Thu Oct 9 05:57:15 UTC 201 Android version: 5.0 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Press "Grant" button on the phone every time when superuser dialog appears Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. Root access garanted! Performed by 2.2.8.4 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-g323bbd9 (android- [email protected]) (gcc version 4.7 (GCC) ) # 1 SMP PREEMPT Thu Oct 9 05:57:15 UTC 201 Android version: 5.0 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*ÿh°ª at port COM22 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 07:00:00 Firmware released date: Oct 1 2014 Firmware released time: 18:16:59 SW Version: M8974A-2.0.50.2.21 SPC: 000000 Fixing IMEI... New IMEI A: 256978-74-569325-7 Finalizing... Failed! Performed by 2.2.8.4 software version. Finalizing never ends. |
05-14-2016, 02:56 | #10 (permalink) |
Member: 190184 Status: Offline Thanks Meter: 31 | Welcome to Octoplus/Octopus Box LG Software version 2.2.8.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-g323bbd9 (android- [email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu Oct 9 05:57:15 UTC 201 Android version: 5.0 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*ÿh°ª at port COM22 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 07:00:00 Firmware released date: Oct 1 2014 Firmware released time: 18:16:59 SW Version: M8974A-2.0.50.2.21 SPC: 000000 Fixing IMEI... New IMEI: 398563-21-477852-1 Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "D820_Bad_13-05-2016_18-52-13.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.2.8.5 software version. It kills the phone again and sends it to bootloop with teamwin reporting missing files. |
05-17-2016, 03:43 | #11 (permalink) |
Member: 190184 Status: Offline Thanks Meter: 31 | Welcome to Octoplus/Octopus Box LG Software version 2.2.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info...Failed! Could not detect mode! Performed by 2.2.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-g88fbc66 (android- [email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Oct 20 22:18:31 UTC 201 Android version: 5.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Press "Grant" button on the phone every time when superuser dialog appears Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. Root access garanted! Performed by 2.2.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-g88fbc66 (android- [email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Oct 20 22:18:31 UTC 201 Android version: 5.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Failed! Performed by 2.2.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0OctoLGv1-gd745771-dirty ([email protected]) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #2 SMP PREEMPT Tue Apr 21 16:27:58 EEST 201 Android version: 5.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Failed! Performed by 2.2.9 software version. |
05-17-2016, 04:05 | #12 (permalink) |
Member: 190184 Status: Offline Thanks Meter: 31 | Welcome to Octoplus/Octopus Box LG Software version 2.2.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: D820 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 07:00:00 Firmware released date: Nov 17 2014 Firmware released time: 13:04:48 SW Version: M8974A-2.0.50.2.22 SPC: 000000 Fixing IMEI... New IMEI: 326978-45-521469-6 Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "D820_Bad_16-05-2016_19-58-34.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.2.9 software version. |
05-17-2016, 15:06 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, reflash the phone with 4.4.x firmware version from the Support Area, then root the phone with Nexus Root toolkit, after repeat Repair IMEI operation and post here full Software log. |
05-18-2016, 03:57 | #14 (permalink) |
Member: 190184 Status: Offline Thanks Meter: 31 | Welcome to Octoplus/Octopus Box LG Software version 2.2.9 Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info...Failed! Could not detect mode! Performed by 2.2.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-g88fbc66 (android- [email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Oct 20 22:18:31 UTC 201 Android version: 5.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Please, root the phone manually! Performed by 2.2.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM24 Selected model: D820 Reading info... Model ID: LGD820AT-0LGD820AT-00-V10c-NXS-XX-DEC-03 IMEI: 352584-06-003937-4 Android version: Battery level: 97% Mode: Emergency Initializing flash...OK SW version: LGD820AT-00-V10c-NXS-XX-DEC-03-2013-KOT49E-USER- 16G+0 LAF Version: 1.0 Product ID: HD56S140314002938 IMEI: 352584-06-003937-4 Target operator: ro.build.target_coun Hardware: rev_11 Opening "LGD820AT-00-V10a-NXS-OCT-01-2013-KFS78N-USER-16G+ 0.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing sbl1b...OK Writing tzb...OK Writing rpmb...OK Writing abootb...OK Writing persist...OK Writing imgdata...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing system...OK Writing cache...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...Failed! Formating MPT...Failed! Finalizing...OK Writing firmware done! Performed by 2.2.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM30 Selected model: D820 Reading info...Failed! Port busyFailed! Could not detect mode! Performed by 2.2.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gadb2201 (android- [email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Wed Nov 20 14:42:53 PST 201 Android version: 4.4.2 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Please, root the phone manually! Performed by 2.2.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gadb2201 (android- [email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Wed Nov 20 14:42:53 PST 201 Android version: 4.4.2 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Failed! Performed by 2.2.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: D820 Reading info... Mode: Normal Firmware compiled date: Oct 01 2013 Firmware compiled time: 17:00:00 Firmware released date: Nov 19 2013 Firmware released time: 10:24:33 SW Version: M8974A-1.0.25.0.23 SPC: 000000 Fixing IMEI... New IMEI: 745633-21-895411-1 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...Canceled! Backup saved to "D820_Bad_17-05-2016_19-54-51.qcn" Performed by 2.2.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: D820 Reading info... Mode: Normal Firmware compiled date: Oct 01 2013 Firmware compiled time: 17:00:00 Firmware released date: Nov 19 2013 Firmware released time: 10:24:33 SW Version: M8974A-1.0.25.0.23 SPC: 000000 Fixing IMEI... New IMEI: 745633-21-895411-1 Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "D820_Bad_17-05-2016_19-55-06.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.2.9 software version. |
05-18-2016, 07:57 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, make sure that You perform all steps, according Software manual, during all operation. We have checked on our phone and all are working correctly. |
