10-13-2014, 18:35 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Europe Age: 54
Member: 24581 Status: Offline Thanks Meter: 87 | D820 IMEI repair [Solved] Checking data...OK Platform: LG Qualcomm Selected port: COM76 Selected model: D820 Reading info...OK Mode: Normal Model ID: AAAAANAZ:ÿh°¿ Firmware compiled date: Oct 01 2013 Firmware compiled time: 17:00:00 Firmware released date: Nov 19 2013 Firmware released time: 10:24:33 SW Version: M8974A-1.0.25.0.23 IMEI: 352136-06-xxxxxx-1 After perform Repair IMEI operation, 3G/4G network will be unavailable! Fixing IMEI... New IMEI: 352136-17-xxxxxx-8 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Backup saved to "D820_35213606xxxxxx1_13-10-2014_19-10-11.qcn" But after restart imei is same 352136-06-xxxxxx-1 Last edited by Octopus box; 10-15-2014 at 07:01. |
10-13-2014, 19:07 | #3 (permalink) |
Member: 24581 Status: Offline Thanks Meter: 87 | Welcome to Octoplus/Octopus Box LG Software version 1.7.1 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM76 Selected model: D820 Reading info...OK Mode: Normal Model ID: AAAAANAZ:ÿh°¿ Firmware compiled date: Oct 01 2013 Firmware compiled time: 17:00:00 Firmware released date: Nov 19 2013 Firmware released time: 10:24:33 SW Version: M8974A-1.0.25.0.23 IMEI: 352136-06-447756-1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM76 Selected model: D820 Reading info...OK Mode: Normal Model ID: AAAAANAZ:ÿh°¿ Firmware compiled date: Oct 01 2013 Firmware compiled time: 17:00:00 Firmware released date: Nov 19 2013 Firmware released time: 10:24:33 SW Version: M8974A-1.0.25.0.23 IMEI: 352136-06-447756-1 After perform Repair IMEI operation, 3G/4G network will be unavailable! Fixing IMEI... New IMEI: 352136-17-447756-8 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Backup saved to "D820_352136064477561_13-10-2014_20-06-51.qcn" After this imei is same-352136064477561 |
10-14-2014, 10:33 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We have prepared and sent You test Software version to PM. Try to perform the operation by using this Software and write here the result. |
10-14-2014, 15:38 | #6 (permalink) |
Member: 24581 Status: Offline Thanks Meter: 87 | Welcome to Octoplus/Octopus Box LG Software version 1.7.1.3 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: D820 Reading info...Failed! Could not detect mode! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gadb2201 Android version: 4.4.2 Hardware: ARMv7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gadb2201 Android version: 4.4.2 Hardware: ARMv7 After perform Repair IMEI operation, 3G/4G network will be unavailable! Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ:ÿh°¿ at port COM76 Reading info...OK Mode: Normal Model ID: AAAAANAZ:ÿh°¿ Firmware compiled date: Oct 01 2013 Firmware compiled time: 17:00:00 Firmware released date: Nov 19 2013 Firmware released time: 10:24:33 SW Version: M8974A-1.0.25.0.23 IMEI: 352136-06-xxxxxx-1 SPC: 000000 Fixing IMEI... New IMEI: 352136-17-xxxxxx-8 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading Roaming List 1...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D820_35213606xxxxxx1_14-10-2014_16-03-47.qcn" Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF and press and hold "Vol+" button) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D820_35213606xxxxxx1_14-10-2014_16-16-36.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Switching to Fastboot mode...OK Unlocking Bootloader... Select "Yes" on phone screen and press "Power" button. Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*ÿh°Ç at port COM76 Send SPC...OK Writing QCN... Writing Roaming List 0...OK Writing EFS...OK Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing Provisioning Items...OK Writing QCN done! IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gadb2201 Android version: 4.4.2 Hardware: ARMv7 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gadb2201 Android version: 4.4.2 Hardware: ARMv7 IMEI NEW IS SET!!!!! |
