01-14-2017, 17:57 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 778346 Status: Offline Thanks Meter: 34 | d821 flash problem [Solved] -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM23 Selected model: D821 Reading info...Failed! Could not detect mode! Performed by 2.4.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM23 Selected model: D821 Reading info...Failed! Could not detect mode! Performed by 2.4.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM6 Selected model: D821 Reading info...Failed! Port busyFailed! Could not detect mode! Performed by 2.4.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: D821 Reading info...OK Mode: Fastboot Model ID: hammerhead D821 16GB Device serial number: 05aca87322d833c3 Hardware: rev_11 Bootloader lock state: unlocked Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "LGD821AT-00-V10b-NXS-OCT-31-2013-KRT16M-USER-16G+ 0.oct"...OK Initializing flash...Failed! Performed by 2.4.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: D821 Reading info...OK Mode: Fastboot Model ID: hammerhead D821 16GB Device serial number: 05aca87322d833c3 Hardware: rev_11 Bootloader lock state: unlocked Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "LGD821AT-00-V10b-NXS-OCT-31-2013-KRT16M-USER-16G+ 0.oct"...OK Initializing flash...Failed! Performed by 2.4.4 Software version. after repair imei got problem. Last edited by Octopus box; 01-20-2017 at 08:45. |
01-16-2017, 08:47 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please, put the phone into Emergency (Download) Mode, then repeat Write Firmware operation again. To put the phone into Emergency (Download) Mode, power the phone off, press and hold "Vol+" button and connect USB cable. Last edited by Octopus box; 01-16-2017 at 08:52. |
01-19-2017, 18:08 | #3 (permalink) |
Member: 778346 Status: Offline Thanks Meter: 34 | thanks write done Checking data...OK Platform: LG Qualcomm Selected port: COM50 Selected model: D821 Reading info... Mode: Emergency Initializing flash...OK SW version: LGD821AT-00-V10d-NXS-XX-DEC-11-2013-KOT49H-USER- 16G+0 Android version: KeyLimePie LAF Version: 1.0 Product ID: BS08S140113000775 IMEI: 352136-06-268137-0 Target operator: ro.build.target_coun Hardware: rev_11 Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "LGD821AT-00-V10b-NXS-OCT-31-2013-KRT16M-USER-16G+ 0.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing sbl1b...OK Writing tzb...OK Writing rpmb...OK Writing abootb...OK Writing persist...OK Writing imgdata...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing system...OK Writing cache...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...Failed! Formating MPT...Failed! Finalizing...OK Writing firmware done! Performed by 2.4.4 Software version. |
