10-11-2016, 07:28 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: cameroon
Member: 260658 Status: Offline Thanks Meter: 184 | D850 kill switch bricked help please help me to kick phone out in qualcomm mode Welcome to Octoplus/Octopus Box LG Software version 2.4.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.Failed! Performed by 2.4.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.OK Performed by 2.4.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.OK Performed by 2.4.5 Software version. thank you in advance |
10-11-2016, 07:37 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please, disconnect test point, remove battery from the phone, after insert battery and try to power on phone again, post here result. |
10-11-2016, 07:54 | #5 (permalink) |
Member: 260658 Status: Offline Thanks Meter: 184 | custommer bring phone for frp problem, when connect optimus cable its show on screen: DOWNLOAD DISABLED BY KILL SWITH, its way i make test point on phone |
10-11-2016, 08:06 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Deactivate Kill Switch neither test points can't damage your device, please try to reconnect test pints and repeat Deactivate Kill Switch operation again, make sure that You install correct drivers according to the Software manual. |
10-13-2016, 16:33 | #7 (permalink) | |
Member: 260658 Status: Offline Thanks Meter: 184 | Quote:
Welcome to Octoplus/Octopus Box LG Software version 2.4.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM83 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.OK Sending loader...OK Connecting to server ... Failed! Performed by 2.4.5 Software version. | |
10-14-2016, 12:03 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please, try on another clean PC with win 7 / 8 /10, currently win XP isn't officially supported. If You don't have another PC, then try to do next: 1. Connect phone to PC. 2. Release test points. 3. Press Deactivate Kill Switch button. 4. Post here full Software log. Also, please check which phone model exactly do You have D850, D855 or D851? Last edited by Octopus box; 10-14-2016 at 12:34. |
10-14-2016, 12:17 | #11 (permalink) | |
10-14-2016, 13:15 | #12 (permalink) |
Member: 260658 Status: Offline Thanks Meter: 184 | i try with v2.3.9 Welcome to Octoplus/Octopus Box LG Software version 2.3.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM85 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.Canceled! Performed by 2.3.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM85 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.OK Sending loader...OK Connecting to server ...OK Initializing device...Failed! Error code: Performed by 2.3.9 software version. |
10-14-2016, 13:55 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please contact us to Skype, or Yahoo! Messenger, we will check where can be the problem. Our contacts You can find in our profile. |
