03-08-2017, 12:18 | #1 (permalink) |
No Life Poster Join Date: Apr 2016
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | d851 could not connect Welcome to Octoplus/Octopus Box LG Software version 2.5.9.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM17 Selected model: D851 Reading info...Failed! Could not detect mode. Performed by 2.5.9.3 Software version. |
03-08-2017, 12:39 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please, make sure that drivers are installed correctly and You read Software manual carefully: Note: To connect the phone in Normal Mode, do one of the following: 1. Enable "USB Debugging" mode; 2. Type 277634#*# or *#546368#*851# or 3845*#851#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". |
03-08-2017, 12:51 | #3 (permalink) | |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | Quote:
03-08-2017, 12:54 | #4 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | Checking data...OK Platform: LG Qualcomm Selected port: COM17 Selected model: D851 Reading info... Model ID: Unknown IMEI: 354153-06-261540-5 Android version: 4.4.2 Battery level: 46% SW Version: D85510i Mode: Emergency Initializing flash...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually Power phone OFF, press and hold "Vol+" button and connect the cable (or P999 cable) 3. Connect cable and press "Ok" button. Initializing flash... Performed by 2.5.9.3 Software version. |
03-08-2017, 13:08 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | What exactly You are trying to do? What is exact state of your phone? As we cane see from the Software log your phone's models: Quote:
03-08-2017, 13:43 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | What exactly You are trying to do? What is exact state of your phone? If You want to reflash the phone, then select correct phone mode and correct firmware file and perform Write Firmware operation. |
03-08-2017, 14:03 | #9 (permalink) | |
i tried with network repair but after baseband gone, after write sec baseband come back i decide to flash the phone and after that see the log,s now its in just download mode | |
03-08-2017, 14:44 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | If You want to reflash the phone, then select correct phone mode and correct firmware file and perform Write Firmware operation. |
03-08-2017, 15:38 | #12 (permalink) | |||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
03-08-2017, 15:43 | #13 (permalink) | |
Welcome to Octoplus/Octopus Box LG Software version 2.5.9.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM17 Selected model: D851 Reading info... Model ID: Unknown IMEI: 354153-06-261540-5 Android version: 4.4.2 Battery level: 40% SW Version: D85510i Mode: Emergency Initializing flash...OK SW version: LGD855AT-00-V10i-GLOBAL-COM-SEP-29-2014-32G+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: SM05S141108000480 IMEI: 354153-06-302843-4 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "D851_V10R_00 (2).oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.5.9.3 Software version. | |
03-08-2017, 15:44 | #14 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | now see, after flash ,. now just tell how to fix 3g 4g? Platform: LG Qualcomm Selected port: COM17 Selected model: D851 Reading info... Model ID: LG-D851 IMEI: 354153-06-302843-4 Android version: 4.4.2 Battery level: 35% SW Version: D85110r Mode: Normal Firmware compiled date: Aug 06 2014 Firmware compiled time: 17:00:00 Firmware released date: Nov 6 2014 Firmware released time: 20:03:36 SW Version: MPSS.DI.2.0.1.c1.13-00018-M8974AAAAANPZM-1.01651016.3717.1 IMEI: 354153-06-302843-4 SPC: 000000 Performed by 2.5.9.3 Software version. |
03-08-2017, 15:48 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You can try to write QCN file, after check for the network. Also, You can try to read out QCN file from other correctly working phone (same phone model) and write into your device, after check for 3g network. |
