08-12-2014, 06:57 | #1 (permalink) |
Insane Poster Join Date: Mar 2014 Location: United States, Irving
Member: 2156601 Status: Offline Thanks Meter: 3 | d851 imei repair help [Solved] -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM41 Selected model: D851 Reading info...OK Mode: Normal Model ID: D85110c Firmware compiled date: May 21 2014 Firmware compiled time: 02:00:00 Firmware released date: Jun 20 2014 Firmware released time: 21:34:45 SW Version: MPSS.DI.2.0.1.c1.13-00009-M8974AAAAANPZM-1 IMEI: 014088-00-008215-5 Fixing IMEI... New IMEI: 014088-00-008xxxxx Reading NVM...OK Backup saved to "D851_01408800008xxxx_12-08-2014_00-43-47.NVM" Switching to Download mode...OK Initializing flash...Failed! Initializing flash... |
08-12-2014, 09:02 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please switch the phone to Emergency Mode manually (To enter emergency mode, power phone OFF, press and hold "Vol+" button and connect USB cable), then make Read Info and post here Software log. |
08-15-2014, 10:07 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. To connect LG D851, please, do the next: 1. Disconnect all other devices from PC, re-boot the PC, re-start the phone. 2. Turn on USB Debugging Mode in the phone. 3. Go to "Settings->PC connection->Select USB connection method" and select "Charge phone" option. After this steps install LG PC Suite, connect the phone to PC and check whether COM port appears. |
