08-24-2014, 06:53 | #1 (permalink) |
Insane Poster Join Date: Nov 2013
Member: 2061249 Status: Offline Thanks Meter: 18 | d851 imei repair HELP [Solved] Selected port: COM7 Selected model: D851 Reading info...OK Mode: Emergency Initializing flash...OK Model ID: LG-D851 SW version: LGD851AT-01-V10c-310-260-JUN-20-2014+0 LAF Version: 1.0 Product ID: IMEI: 014088-00-00821x-x Target operator: TMO Hardware: rev_10 Battery level: 39% Fixing IMEI... New IMEI: 014088-00-008219-7 Switching to Normal mode... Found model D85110c at port COM7 Reading NVM...OK Backup saved to "D851_0140880000821xx_17-08-2014_18-56-15.NVM" Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF and press and hold "Vol+" button) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D851_0140880000821xx_17-08-2014_19-06-24.SEC" Writing security area...Failed! Error code: ZXLCALSZXD i get this error code every time. others have solved this issue. please let me know thank you Last edited by Octopus box; 08-27-2014 at 16:43. |
08-24-2014, 09:52 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Hello. Please use the latest Software version (Software) and post here new software log. Also, please upload somewhere security backup file "D851_0140880000821xx_17-08-2014_19-06-24.SEC" and post here the link. We will research and say You the result. |
08-24-2014, 22:18 | #4 (permalink) | |
Member: 2061249 Status: Offline Thanks Meter: 18 | Quote:
https://www.dropbox.com/s/vkp1hm4bw7...30-18.SEC?dl=0 | |
08-25-2014, 04:15 | #5 (permalink) | |
Insane Poster Join Date: Mar 2014 Location: United States, Irving
Member: 2156601 Status: Offline Thanks Meter: 3 | same error also using latest version Quote: ----------------------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM51 Selected model: D851 Reading info...OK Mode: Emergency Initializing flash...OK Model ID: LG-D851 SW version: LGD851AT-01-V10c-310-260-JUN-20-2014+0 LAF Version: 1.0 Product ID: IMEI: 014088-00-008215-5 Target operator: TMO Hardware: rev_10 Battery level: 75% Reading partition...OK Reading security area...OK Backup saved to "D851_0140880000821xx_24-08-2014_22-10-43.SEC" Writing security area...Failed! Error code: ZXLCALSZXD | |
08-27-2014, 10:00 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | We have prepared and sent You test Software version to PM. Try to repeat the operation by using this Software and post here log. |
08-27-2014, 16:30 | #7 (permalink) |
Member: 2156601 Status: Offline Thanks Meter: 3 | SOLVED Platform: LG Qualcomm Selected port: COM51 Selected model: D851 Reading info...OK Mode: Normal Model ID: D85110c Firmware compiled date: May 21 2014 Firmware compiled time: 02:00:00 Firmware released date: Jun 20 2014 Firmware released time: 21:34:45 SW Version: MPSS.DI.2.0.1.c1.13-00009-M8974AAAAANPZM-1 IMEI: 014088-00-00821x-x Fixing IMEI... New IMEI: 014088-00-00821x-x Reading NVM...OK Backup saved to "D851_0140880000821xx_27-08-2014_09-53-51.NVM" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D851_0140880000821xx_27-08-2014_09-58-57.SEC" Writing security area...OK Switching to Normal mode... Found model D85110c at port COM51 Checking data...OK Writing NVM...OK NVM succesfully repaired. IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). thanks!! |
The Following User Says Thank You to kdm_2809 For This Useful Post: |
08-28-2014, 06:24 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Yes, of course, we have sent You test Software version to PM. Try to repeat the operation by using this Software and post here log. |
08-31-2014, 09:12 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | @ hectorm37166 Hello. Yes, of course, we have sent You test Software version to PM. Try to repeat the operation by using this Software and post here log. |
