06-13-2015, 20:01 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Minneapolis MN USA
Member: 1815016 Status: Offline Thanks Meter: 77 | D851 Initializing Flash Failed Welcome to Octoplus/Octopus Box LG Software version 1.9.8 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1147 Selected model: D851 Reading info... Model ID: LG-D851 IMEI: 014088-00-130470-7 Android version: 4.4.2 Battery level: 100% Mode: Normal Firmware compiled date: Aug 06 2014 Firmware compiled time: 17:00:00 Firmware released date: Nov 6 2014 Firmware released time: 20:03:36 SW Version: MPSS.DI.2.0.1.c1.13-00018-M8974AAAAANPZM-1.01651016.3717.1 IMEI: 014088-00-130470-7 SPC: 000000 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1147 Selected model: D851 Reading info... Model ID: LG-D851 IMEI: 014088-00-130470-7 Android version: 4.4.2 Battery level: 100% Mode: Normal Firmware compiled date: Aug 06 2014 Firmware compiled time: 17:00:00 Firmware released date: Nov 6 2014 Firmware released time: 20:03:36 SW Version: MPSS.DI.2.0.1.c1.13-00018-M8974AAAAANPZM-1.01651016.3717.1 IMEI: 014088-00-130470-7 SPC: 000000 Fixing IMEI... New IMEI: 014088-00-130570-4 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D851_014088001304707_13-06-2015_13-41-14.qcn" Switching to Download mode...OK Initializing flash...Failed! Initializing flash... Ay suggestions? |
06-14-2015, 04:47 | #2 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2051424 Status: Offline Thanks Meter: 16 | Uninstall LG drivers. Install latest LG Drivers. http://octoplusbox.com/files/drivers...Ver_3.12.3.exe |
06-15-2015, 10:13 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please try to do the next: 1. Install required drivers, as suggested mr.BubluMian/ 2. Enable "Skip Read/Write QCN during Repair IMEI operation" option. 3. Manually put the phone into Emergency/Download Mode (To enter emergency mode, power phone OFF, press and hold "Vol+" button and connect USB cable). 4. Repeat "Repair IMEI" operation. Try to use both simple Micro USB and P999 cable (with 910kOm resistor) for connection. Post the result and full Software log of the operation. |
06-17-2015, 21:49 | #4 (permalink) |
Freak Poster Join Date: May 2013
Member: 1939108 Status: Offline Thanks Meter: 44 | i have the exact same problem with 3 difrent phone same model, first toght it was sw on phone and flashed support firmware with sane result, 2 more devices with same result, try it both above sugestions with no luck Welcome to Octoplus/Octopus Box LG Software version 1.9.7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM279 Selected model: D851 Reading info... Mode: Emergency Initializing flash...OK SW version: LGD851AT-00-V10m-310-260-AUG-22-2014+0 LAF Version: 1.0 Product ID: SM06S140726001931 IMEI: 014089-00-080806-0 Target operator: TMO Hardware: rev_10 Fixing IMEI... New IMEI: 358xxxxxxxxxxx Skip Read/Write QCN Reading partition...Failed! Error code: ZXLCALSZXD |
06-17-2015, 22:30 | #5 (permalink) | |
Member: 1815016 Status: Offline Thanks Meter: 77 | Quote:
The Following User Says Thank You to namos23 For This Useful Post: |
