01-08-2015, 17:19 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Italy
Member: 329458 Status: Offline Thanks Meter: 153 | d855 with lollipop does not connect to pc [Solved] When i try to read phone info software say me that couldn't detect mode. Why? I have updated driver and use p999 cable. Last edited by Octopus box; 01-09-2015 at 07:32. |
01-08-2015, 17:28 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. We didn't test connection with the Andorid 5.0.x firmwares. Have You performed the next steps: Go to "Settings -> Networks -> Tethering & Networks -> Turn on "USB tethering"? |
01-08-2015, 17:49 | #3 (permalink) |
Member: 329458 Status: Offline Thanks Meter: 153 | Yes, i have performed these operation. With normale usb cable phone was recognized correctly from pc as LG Mobile Serial Port... With P999 cable phone was not recognized from pc... Any solution? |
01-08-2015, 18:49 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try do exactly the next with both micro USB and P999 cables: 1. Connect the phone directly to PC. 2. Select "Charge only" connection mode. 3. Go to "Settings -> Networks -> Tethering & Networks -> Turn on "USB tethering". 4. Try to perform desired operation. If problem will be the same with both cables, then, on your own risk, You can try to downgrade firmware version of the phone to 4.4.4 with original flasher. Currently no other solution. |
