11-21-2018, 08:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | DM-02H after reset FRP show "your device is corrupted" [Solved] now what to do !!!! kindly share octopus team also not goes to main menu just restart on your device is corrupted try with hard reset but no luck Platform: LG Qualcomm Selected port: COM2486 Selected model: DM-02H Reading info... Model ID: DM-02H Incompatible model ID! IMEI: 357031-07-045564-1 Android version: 6.0.1 Battery level: 3% SW Version: DM02H10g Mode: Emergency Initializing flash...OK SW version: LGDM02HAT-00-V10g-440-10-DEC-13-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: PT02S160613000736 IMEI: 357031-07-045564-1 Target operator: DCM Hardware: rev_10 Performed by 2.8.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM2486 Selected model: DM-02H Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: DM-02H Incompatible model ID! IMEI: 357031-07-045564-1 Android version: 6.0.1 Battery level: 3% SW Version: DM02H10g Mode: Emergency Initializing flash...OK SW version: LGDM02HAT-00-V10g-440-10-DEC-13-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: PT02S160613000736 IMEI: 357031-07-045564-1 Target operator: DCM Hardware: rev_10 Reading partitions...OK Detecting writing method...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.8.8 Software version. Last edited by Octopus box; 11-22-2018 at 07:18. |
11-21-2018, 08:28 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Yes, try to find V10g or higher firmware for this device model and re-flash the device. Unfortunately, at the moment we don't have firmwares for this device model. |
11-21-2018, 08:31 | #4 (permalink) |
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | there is no firmware also at google ,,, what about if we read firmware from same other working phone !!!!! or we will be very thankful if share here any link of such firmware......... |
11-21-2018, 08:39 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
11-21-2018, 15:35 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have prepared and sent You new test Software version to PM, which supports writing firmwares for this device model in "*.tot" format. But mote, that writing firmware, which was read out from another phone is dangerous and may lead to phone damage! So write read firmware at your own risk only! |
11-22-2018, 06:51 | #12 (permalink) | |
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | Quote:
11-22-2018, 06:57 | #13 (permalink) |
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | problem solved thread closed ,,,,,,, i think it will be world first flashing Welcome to Octoplus/Octopus Box LG Software version 2.8.9.10 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM2486 Selected model: DM-02H Reading info... Model ID: DM-02H Incompatible model ID! IMEI: 357031-*********** Android version: 6.0.1 Battery level: 10% SW Version: DM02H10g Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LGDM02HAT-00-V10g-440-10-DEC-13-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: PT02S160613000736 IMEI: 357031-07-045564-1 Target operator: DCM Hardware: rev_10 Performed by 2.8.9.10 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM2486 Selected model: DM-02H Reading info... Model ID: DM-02H Incompatible model ID! IMEI: 357031-*********** Android version: 6.0.1 Battery level: 10% SW Version: DM02H10g Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LGDM02HAT-00-V10g-440-10-DEC-13-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: PT02S160613000736 IMEI: 357031-07-045564-1 Target operator: DCM Hardware: rev_10 Opening "LGDM02HAT-00-V10g-440-10-DEC-13-2017+0.tot"...OK Firmware version: LGDM02HAT-00-V10g-440-10-DEC-13-2017+0 Firmware model: DM-02H -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/41 PrimaryGPT...OK Writing 2/41 modem...OK Writing 3/41 sbl1...OK Writing 4/41 sbl1bak...OK Writing 5/41 rpm...OK Writing 6/41 rpmbak...OK Writing 7/41 tz...OK Writing 8/41 tzbak...OK Writing 9/41 dsp...OK Writing 10/41 dsp...OK Writing 13/41 sec...OK Writing 14/41 aboot...OK Writing 15/41 abootbak...OK Writing 16/41 boot...OK Writing 17/41 laf...OK Writing 18/41 recovery...OK Writing 19/41 recoverybak...OK Writing 20/41 factory...OK Writing 21/41 raw_resources...OK Writing 22/41 raw_resourcesbak...OK Writing 23/41 persist...OK Writing 25/41 apdp...OK Writing 26/41 msadp...OK Writing 27/41 devcfg...OK Writing 28/41 devcfgbak...OK Writing 29/41 cmnlib...OK Writing 30/41 cmnlibbak...OK Writing 31/41 cmnlib64...OK Writing 32/41 cmnlib64bak...OK Writing 33/41 keymaster...OK Writing 34/41 keymasterbak...OK Writing 35/41 system...OK Writing 36/41 system...OK Writing 37/41 system...OK Writing 38/41 system...OK Writing 39/41 system...OK Writing 40/41 system...OK Writing 41/41 BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.9.10 Software version. |
The Following 2 Users Say Thank You to lerner_ For This Useful Post: |
