12-02-2014, 04:54 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | e400f need good firmware I have the e400f set with formware SW Version: E0_EU-M7225A-V10d-AUG-16-2012-XX phone has the problem of touch but I check the software for that reson I flash the set via support firmware ( all firmware).. after that I come to know that has the problem of touch. now I change the touch and set is ok. But problem is phone fond and picture in the display is shading...before the set is ok.So please give the good flash file before I flash Selected model: E400f Reading info...11/26/2014 7:34:30 PM > OK Mode: Normal Model ID: E400f Firmware compiled date: Nov 17 2011 Firmware compiled time: 22:00:00 Firmware released date: Aug 16 2012 Firmware released time: 13:13:14 SW Version: E0_EU-M7225A-V10d-AUG-16-2012-XX IMEI: 356661-05-577704-8 IMEI B: 356661-05-577704-8 Bluetooth address: 30:76:6F:AB:A4:80 Wi-Fi MAC address: 58:A2:B5:B5:FC9 Connecting to server support.octoplusbox.com:82... OK Authorizing...11/26/2014 7:41:03 PM > OK flashing Checking data...11/26/2014 9:26:34 PM > OK Platform: LG Qualcomm Selected port: COM50 Selected model: E400f Reading info...11/26/2014 9:26:35 PM > OK Mode: Emergency Model ID: BS/E400f/7D Opening "LGE400fAT-00-V10a-724-31-MAR-22-2012+2.oct"...11/26/2014 9:26:35 PM > OK Checking partition...11/26/2014 9:26:35 PM > OK Write BootLoaders: No Writing AMSS...11/26/2014 9:26:41 PM > OK Writing Boot Image...11/26/2014 9:26:43 PM > OK Writing Recovery Image...11/26/2014 9:26:45 PM > OK Writing Persist...11/26/2014 9:26:47 PM > OK Writing System...11/26/2014 9:28:26 PM > OK Finalizing...11/26/2014 9:28:28 PM > OK Writing firmware done! To finish the operation please power on phone and wait 3 minutes 2nd file Checking data...12/1/2014 8:42:09 PM > OK Platform: LG Qualcomm Selected port: COM52 Selected model: E400f Reading info...12/1/2014 8:42:09 PM > OK Mode: Emergency Model ID: BS/E400f/7D Opening "LGE400fAT-00-V10c-OPEN-IL-DEC-04-2012+0.oct"...> OK Checking partition...12/1/2014 8:42:10 PM > OK Write BootLoaders: No Writing AMSS...12/1/2014 8:42:16 PM > OK Writing Boot Image...12/1/2014 8:42:17 PM > OK Writing Recovery Image...12/1/2014 8:42:19 PM > OK Writing Persist...12/1/2014 8:42:22 PM > OK > Writing System...12/1/2014 8:44:00 PM > OK > Finalizing...12/1/2014 8:44:02 PM > OK Writing firmware done! To finish the operation please power on phone and wait 3 minutes 3rd file Checking data... OK Platform: LG Qualcomm Selected port: COM52 Selected model: E400f Reading info... OK Mode: Normal Model ID: E400f Firmware compiled date: Nov 17 2011 Firmware compiled time: 22:00:00 Firmware released date: Dec 4 2012 Firmware released time: 10:59:40 SW Version: E0_MX-M7225A-V10c-DEC-04-2012-XX IMEI: 356661-05-577704-8 IMEI B: 356661-05-577704-8 Bluetooth address: 30:76:6F:AB:A4:80 Wi-Fi MAC address: 58:A2:B5:B5:FC9 Opening "LGE400fAT-01-V10a-334-020-APR-07-2012+2.oct"... OK Switching to Download mode...12/1/2014 9:38:52 PM > OK Checking partition... OK Write BootLoaders: No Writing AMSS... OK Writing Boot Image... OK Writing Recovery Image... OK Writing Persist... OK Writing System... OK Finalizing... OK Writing firmware done! To finish the operation please power on phone and wait 3 minutes So please give me the flash file bro Thanks. |
12-02-2014, 07:28 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. All firmwares are OK and tested many times. What do You mean under "problem is phone fond and picture in the display is shading.."? Please make photo of phone's screen and post it here. Maybe, this is HW issue. |
12-02-2014, 10:34 | #4 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | there is no hardware issue because I have the which is good before flash the set. also the firmware is on the phone before flash the set by support files E0_EU-M7225A-V10d-AUG-16-2012-XX is it any problem..may be downgrade...? Thanks. |
12-02-2014, 12:14 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As we can see from your Software log, You have written firmwares without phone's boot loaders: Quote:
Note: if it is not possible to write firmware or during firmware writing occures error, you mandatory need to re-connect phone's battery and put the phone manualy into Emergency Mode! Note: make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Please, follow these simple precautions to avoid damaging your phone. Also try to write the latest firmware for E400 from the Support Area with phone's boot loaders also. | |
12-02-2014, 14:15 | #6 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Welcome to Octoplus/Octopus Box LG Software version 1.7.4 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM9 Selected model: E400f Reading info...Failed! Port busy -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM6 Selected model: E400f Reading info...Failed! Port busy -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM7 Selected model: E400f Reading info...OK Mode: Emergency Model ID: BS/E400f/7D Opening "LGE400fAT-00-V10c-OPEN-IL-DEC-04-2012+0.oct"...OK Checking partition...OK Write BootLoaders: Yes Checking BCPL status...OK BCPL status: 1 Unlocking BCPL...OK BCPE status: 0 Writing QCSBL_CFG...OK Writing QCSBL...OK Writing OEMSBL...OK Writing AMSS...OK Writing EMMCBOOT...OK Writing Boot Image...OK Writing Recovery Image...OK Writing Persist...OK Writing System...OK Finalizing...OK Writing firmware done! To finish the operation please power on phone and wait 3 minutes same bro how to fix this? Thanks. |
12-02-2014, 14:30 | #8 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
is it ok? and from e400 latest files this LGE400AT-00-V10q-EUR-XXX-DEC-05-2012+0.zip do you want to write this file bro? Thanks. | |
12-02-2014, 14:49 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | I don't want, You can try, if You want. If this will not help - check HW. Note: if it is not possible to write firmware or during firmware writing occures error, you mandatory need to re-connect phone's battery and put the phone manualy into Emergency Mode! Note: make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Please, follow these simple precautions to avoid damaging your phone. |
12-02-2014, 15:43 | #10 (permalink) | |
But I don't want to try that.if some thing then I want to buy a new phone So I try other tools Now I tried in lgetool... 1 shot only fix it..even I did not write boot loder For your help I will paste the log but find the real problem. Because we want to improve OCTOPUS. LGE Tool version: 2.40 OS Version: Windows XP [NT 5.1] Service Pack 3 Administrative privileges: yes Locale: UnitedStates / English CPU frequency: 1862 MHz Total memory: 2031 MB Free memory: 1541 MB Free space on system disk C:\: 3.00 GB Free space on disk D:\: 18.00 GB Free space on disk E:\: 36 MB Free space on disk F:\: 356 MB Free space on disk G:\: 329 MB Free space on disk H:\: 44.00 GB You have slow cpu. Correct work can only be guaranteed on cpu with frequency 2 GHz or more. You have small amount of free space on system disk C:\. Recommended free space is 5 GB or more. Connecting with E400F Connected Receiving phone info Getting phone info Model: E400F Platform: LG Qualcomm Software Platform: Android SDRAM Size: 384 MB NAND Flash Size: 1 GB CPU: MSM7225A Firmware Released: Dec 4 2012 10:59:40 Firmware Compiled: Nov 17 2011 22:00:00 Firmware Version: E400F/E0_MX-M7225A-V10c-DEC-04-2012-XX IMEI: 356661-05-577704-8 Bluetooth Address: 30:76:6F:AB:A4:80 Connect mode: Normal Info received Flashing firmware from C:/LGE400fAT-00-V10d-724-05-OCT-30-2012+0.sbf File reported model: E400F Backuping NVM to file: Backups\E400F_NVM_356661055777048_2014-12-2_20-26-8.sbf Dump NVM: Start Getting phone info... Getting phone info: OK Switching to NVM mode... Switching to NVM mode: OK Dumping NVM... Dump NVM: Finish Checking Firmware File... Checking Firmware File: OK Checking Emergency Mode... Mode: Normal Switching to Emergency Mode... Mode: Emergency Checking connect in Emergency Mode... Checking connect in Emergency Mode: OK Set Trust Mode... Set Trust Mode: OK Get DloadParams... Get DloadParams: OK Send Partition Table... Send Partition Table: OK Flashing Non-Bootable Partitions... Flashing Partition: AMSS... Initializing partition: 0x00000005 [AMSS]... Initializing partition: 0x00000005 [AMSS]: OK Writing Partition... Flashing Partition: AMSS: OK Flashing Partition: BOOT... Initializing partition: 0x00000006 [BOOT]... Initializing partition: 0x00000006 [BOOT]: OK Writing Partition... Flashing Partition: BOOT: OK Flashing Partition: RECOVERY... Initializing partition: 0x00000010 [RECOVERY]... Initializing partition: 0x00000010 [RECOVERY]: OK Writing Partition... Flashing Partition: RECOVERY: OK Flashing Partition: PERSIST... Initializing partition: 0x00000019 [PERSIST]... Initializing partition: 0x00000019 [PERSIST]: OK Writing Partition... Flashing Partition: PERSIST: OK Flashing Partition: SYSTEM... Initializing partition: 0x00000016 [SYSTEM]... Initializing partition: 0x00000016 [SYSTEM]: OK Writing Partition... Flashing Partition: SYSTEM: OK Flashing Non-Bootable Partitions: OK Dload Finalization... Dload Finalization: OK Switching to normal mode... Switching to normal mode: OK Connection established. The phone is initializing... Waiting... Flash NVM: Start Getting phone info... Getting phone info: OK Switching to NVM mode... Switching to NVM mode: OK Flashing NVM... Flashing NVM: OK Switching to normal mode... Switching to normal mode: OK Flash NVM: Finish Flashing firmware success (07:16) Must thanks to lgetool Thanks | |
12-02-2014, 15:52 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | There is nothing to improve, just need to write V10d firmware, that was in the phone before. We will try to find such firmware and upload in into the Support Area. |
12-02-2014, 16:12 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have found and uploaded "LGE400fAT-00-V10d.oct" firmware into the Support Area. If You still have the phone, try to write this firmware and say the result. |
