10-15-2014, 09:23 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: poland krakow
Member: 389207 Status: Offline Thanks Meter: 61 | E960 repair imei - whats wrong? -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM5 Selected model: E960 Searching Diagnostic Ports...OK Reading info...OK Mode: Fastboot Model ID: mako 16GB Device serial number: 021eaf7acf99a653 Hardware: rev_11 Bootloader lock state: unlocked -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: E960 Searching Diagnostic Ports...OK Reading info...OK Mode: Fastboot Model ID: mako 16GB Device serial number: 021eaf7acf99a653 Hardware: rev_11 Bootloader lock state: unlocked Switching to Normal mode... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Checking root access... Phone is not rooted. Sending exploit...OK Checking root access... Phone is already rooted. Root access garanted! Diagnostics ports are enbled! Switching to Serial Port... And program hang in this, nothing more or sometimes show Failed! In device manager i saw LGE AndroidNet for diagnostics port com 18 LGE AndroidNet usb serial port 17 |
10-15-2014, 09:30 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please disconnect all other devices from PC, re-boot the PC, fully charge phone's battery, put the phone into Emergency/Download Mode manually (disconnect the cable, power phone off, press and hold "Vol-" + "Vol+" buttons and connect the cable) and perform the Repair IMEI operation from Emergency/Download Mode. Post here the result. |
10-15-2014, 09:37 | #3 (permalink) |
Member: 389207 Status: Offline Thanks Meter: 61 | Welcome to Octoplus/Octopus Box LG Software version 1.7.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: E960 Searching Diagnostic Ports...OK Reading info...Failed! Could not detect mode! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM134 Selected model: E960 Searching Diagnostic Ports...OK Reading info...OK Mode: Emergency Model ID: BS/J1A/1 (LG-E960) SW version: LGE960AT-00-V10d-NXS-XX-MAR-04-2013-JVP15L- FACTORY+0 Product ID: PT01S1362 IMEI: 356489- Fixing IMEI... New IMEI: 356489- Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "E960_356489_15-10-2014_10-33-50.SEC" Analyzing security...OK Writing security area...OK IMEI successfully fixed! Rebooting phone... But if i make *#06# i see IMEI and nothing more. HW damage? |
10-15-2014, 09:47 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to re-flash the phone and then make Repair IMEI again. If IMEI still will not present after this, this can be HW issue. |
10-15-2014, 11:26 | #6 (permalink) |
Member: 389207 Status: Offline Thanks Meter: 61 | Wierd. Phone dont show imei, but when i make "repair security" octoplus readed correctly backup with imei.. E960_35648905_15-10-2014_12-23-22.SEC Another things - when i manually flash phone with fastboot (newest 4.4.4 official occam-ktu84p-factory-b6ac3ad6) fastboot flash recovery, system etc. Phone dont boot - only logo Nexus. Wipe dont help. When i flashed Phone with 4.2.2 occam-jdq39-factory-345dc199 Phone boot normal... |
10-15-2014, 11:34 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to write different firmwares from the Support Area. If the problem is the same - most likely, this is HW issue. |
